Done - thanks for the info @hunterlester
Updated 28 April to add:
The mock routing app pack from @whiteoutmashups
The SAFE-VFS virtual drive from @anon71598723
And the SAFEthing IoT framework from @bochaco
And also to pimp the mock routing functionality a bit.
Updated 07 May to add:
Information about the SAFE Browser with Authenticator and the example apps.
Thanks for keeping this updated @JPL. This is a valuable resource which I keep using myself and also share to answer questions on slack etc
Great work here @JPL can I suggest you add a âUpdated Dateâ (in this case May 7, 2017) to a single line - bold - after you intro and before the â10 Key factsâŠâ
Looking something like this.
âŠ
âŠanything wrong or missed anything vital.
Last Update May 7, 2017
10 Key Facts For New Users
- SAFEâŠ
âŠ
This to make it very clear the list is current relative to the posting date.
Seems like a very reasonable request. Consider it done ![]()
I canât seem to edit this any more. Is there some sort of limit to the number of edits?
Mods @anon40790172 @frabrunelle @neo @Melvin @Krekc - I think Iâve hit a time limit for editing this post. From the Discourse forum it seems this is something admins can change. Can you check please?
Can you try now :)? if you use @ moderators we all get a notification btw!
Ah OK, Iâm not normally a mod-botherer! Nope still canât edit anything apart from the title.
Tried again - itâs working I can edit now. Thanks
Shared this topic with MaidSafe Asia and we found it to be very important.
Made it a sticky post on our forums and we translated it into many languages, including Indonesian, Vietnamese and Korean, with more to come soon.
Thanks for all your work in this area, @JPL ! Making a difference!
Woo. Iâm now a translated author. What a boost to the ego
Seriously, really glad itâs helping boost understanding of the project. Keep up the good work.
I am ready to translate it in French.
This post is what drove me to maid in the first place.
Just let me know what you need in pm and give me a few days and I will post back it to you.
this is great! I am pure newbie here, and have been wondering whatâs going on. Thank you.
French version.
Le réseau SAFE en 10 points essentiels
Beaucoup de progrÚs ont été réalisés derniÚrement, et, grùce aux apparitions de @nicklambert dans les media
au prix du MAID qui se comporte trĂšs honorablement (touchons du bois), et Ă lâĂ©quipe, qui donne des prĂ©sentations partout dans le monde, nous pouvons nous attendre Ă voir arriver de nombreux curieux qui vont venir ici pour comprendre de quoi il sâagit.
Il y a de nombreuses informations au sujet de SAFE sur les forums, sur le site de Maidsafe, dans les docs, le Wiki, sur Github, Youtube et les podcasts, ou encore sur beaucoup de blogs, mais il faut savoir oĂč chercher. Par ailleurs, tous ces progrĂšs rendent vite caduques les informations essentielles et il est important de les tenir Ă jour.
Jâai donc pensĂ© quâil Ă©tait nĂ©cessaire dâexposer par Ă©crit les points les plus importants, Ă lâattention des trois groupes suivants : 1) les nĂ©ophytes qui veulent comprendre ce quâest vraiment SAFE 2) les traders et autres vĂ©tĂ©rans du domaine des cryptos 3) les dĂ©veloppeurs qui sâintĂ©ressent Ă lâĂ©cosystĂšme et veulent dĂ©velopper des applications autour de SAFE.
Tous ces points sont dĂ©libĂ©rĂ©ment dĂ©veloppĂ©s de maniĂšre courte et simple, car je prĂ©vois de les mettre Ă jour rĂ©guliĂšrement Ă mesure que de nouvelles avancĂ©es sont faites et que lâexcitation qui devance la sortie du Beta augmente. Cette note se veut interactive, donc nâhĂ©sitez pas Ă me faire savoir si jâai oubliĂ© quelque chose dâimportant ou si tout simplement jâai fait une erreur.
DerniĂšre mise Ă jour : 28 Mai 2017
10 points Ă retenir pour les neophytes.
SAFE (« Secure Access For Everyone ») est un rĂ©seau, comme internet, Ă la diffĂ©rence quâil est constituĂ© des appareils Ă©lectroniques privĂ©s de ses utilisateurs, et non de serveurs centralisĂ©s- [voir cette vidĂ©o dâintroduction]
Cela rend SAFE plus sĂ©curisĂ©, plus rĂ©sistant Ă la censure et impermĂ©able aux attaques gouvernementales, criminelles ou dâorganisations privĂ©es. [pourquoi câest important]
SAFE est dĂ©veloppĂ© par lâentreprise Ă©cossaise MaidSafe. Le rĂ©seau est actuellement en phase de test [voir la feuille de route]. Le test nâest pas ouvert au public en ce moment, bien que des versions antĂ©rieures lâaient dĂ©jĂ Ă©tĂ©. Un prochain test public sera bientĂŽt disponible. Lâannonce de ce test interviendra prochainement, Ă lâoccasion de bulletins hebdomadaires effectuĂ©s par les dĂ©veloppeurs (tous les jeudi soirs).
Actuellement, le réseau fonctionne grùce à la combinaison de serveurs virtuels ainsi que des ordinateurs personnels des utilisateurs. à terme, les serveurs virtuels seront progressivement éliminés pour laisser place à un réseau complÚtement autonome et autosuffisant qui fonctionnera grùce aux ordinateurs et smartphones de ses utilisateurs.
Lâapplication de base que vous devez vous procurer est le navigateur de SAFE et son systĂšme dâauthentification (pour se connecter au rĂ©seau). Sâil nây a pas de rĂ©seau test disponible pour lâinstant, le navigateur de SAFE permet nĂ©anmoins dâimiter le routage et donc de simuler provisoirement le rĂ©seau afin de crĂ©er un compte et de publier un site comme si vous Ă©tiez en ligne (bien que vous ne puissiez Ă©videmment pas le partager). Vous pouvez Ă©galement essayer dâautres applications qui sont dĂ©veloppĂ©es pour SAFE. Une fois que vous avez créé un compte, vous pouvez tĂ©lĂ©charger des donnĂ©es ou bien en mettre en ligne et crĂ©er un site web en utilisant lâapplication de dĂ©monstration. NB : vu quâactuellement le rĂ©seau est hors ligne jusquâau prochain test, les fonctionnalitĂ©s de ces applications sont temporairement limitĂ©es.
Les donnĂ©es stockĂ©es sur le rĂ©seau sont soit publiques (et peuvent ĂȘtre partagĂ©es avec les tout le monde) soit privĂ©es (vous seul pouvez les voir). Pour publier un site web safe:// , concevez le hors connexion, et uploadez les fichiers et dossiers en mode public, en utilisant lâapp de dĂ©mo. Toujours avec cette mĂȘme application, publiez le site, et visionnez le grĂące au navigateur de SAFE. Pour stocker des donnĂ©es privĂ©es, uploadez en mode privĂ©. Rien de plus simple !
Si votre ordinateur et votre connexion internet sont raisonnablement rapides, vous pouvez Ă©galement aider Maidsafe Ă dĂ©bugger le systĂšme en maintenant un coffre (une chambre forte pour les fragments de fichiers encryptĂ©s). Vous nâĂȘtes pas obligĂ©s de maintenir un coffre afin dâutiliser toutes les autres fonctionnalitĂ©s de SAFE. NB : Comme actuellement le rĂ©seau est hors ligne jusquâau prochain test, vous ne pouvez pas pour maintenir de coffre en ce moment.
Dans un future proche, les coffres seront utilisĂ©s pour gĂ©rer une devise interne appelĂ©e Safecoin, que vous pourrez acquĂ©rir ou dĂ©penser sur le rĂ©seau. Ce nâest pas encore prĂȘt, mais un peu de patienceâŠ
Si vous oubliez vos identifiants, vous ne pourrez pas les recouvrer â vous devrez crĂ©er un autre compte, alors ne les perdez pas !
Pour plus dâinformations et pour comprendre comment SAFE fonctionne, jetez un Ćil au Wiki. Il y a des vidĂ©os dâintroduction et dâinformation sur maidesafe.net.
10 points Ă retenir pour les cryptotraders.
MaidSafecoin est un gage (un token), qui a Ă©tĂ© crĂ©e lors dâune levĂ©e de fonds publique en 2014 afin de soutenir le projet. Il peut ĂȘtre traitĂ© sur le marchĂ©, mais pas encore « produit »: Pour crĂ©er de la masse monĂ©taire, les gens qui sâintĂ©ressent au bitcoin utilisent lâanalogie de lâexploitation miniĂšre. Ici, sur le forum de SAFE, il sâagit plutĂŽt dâexploitation agricole. On ne parle pas de miner du bitcoin, mais de « farmer » du Safecoin. Câest bien du blĂ© quâil sâagit aprĂšs tout
! En français on emploiera donc lâexpression « rĂ©colter » -
Quand le rĂ©seau SAFE sera lancĂ©, les MaidSafeCoin seront convertis dans la crypo-devise finale du rĂ©seau, le Safecoin sur la base de 1 pour 1, [plus dâinformation sur le Wiki]
Les MaidSafeCoin (MAID) sâĂ©changent actuellement sur Poloniex, Bittrex, Livecoin, Yuanbao et ShapeShift.io . Pour sâen procurer il faut dâabord acheter du bitcoin puis le convertir en MAID. Attention aux MAID sur dâautres places dâĂ©change â ça pourrait ĂȘtre des faux.
Les MaidSafeCoin sont basĂ©s sur le protocole OMNI, et peuvent ĂȘtre emmagasinĂ©s en ligne dans un portefeuille Omniwallet ou hors ligne sur du hardware spĂ©cialisĂ© ou paper wallet traditionnel.
Quand SAFE sera lancĂ©, vous serez en mesure de rĂ©colter des Safecoin en offrant vos ressources au rĂ©seau (CPU et espace de votre disque). Pas de blockchain ici, ni de proof-of-work ; tout marche sur preuve de capacitĂ©. [plus dâinformation sur la façon de rĂ©colter des Safecoin sur le Wiki]
Ne pas se baser sur la blockchain permet dâĂ©viter les nombreux Ă©cueils du bitcoin, victime son succĂšs (transactions lentesâŠ) et de rĂ©soudre les problĂšmes dâĂ©chelle et de gestion de masse.
Vous trouverez une discussion trÚs détaillée sur les différences entre le Bitcoin et le Safecoin sur cette page.
Les Safecoin serviront Ă acheter de lâespace, Ă monnayer des services sur SAFE, et Ă payer tous ceux qui contribuent Ă fournir des ressources au rĂ©seau pour lâexploiter.
Il est envisagĂ© que les dĂ©veloppeurs dâapplications seront payĂ©s pour leur travail. [Pour plus de dĂ©tails, mais regardez ici, et dâautres discussions sur ce forum]
Quelques problĂšmes restent Ă rĂ©soudre, notamment les questions liĂ©es Ă la divisibilitĂ© de la devise. Un SafeCoin vĂ©hicule des donnĂ©es ; ce nâest pas quâun chiffre sur la blockchain, donc il est plus difficile Ă diviser en centimes quâune crypto-devise de base. [Ă ce sujetâŠ]
10 point à retenir pour les développeurs.
Vous pouvez dâores et dĂ©jĂ dĂ©velopper des applications pour SAFE
Le safeApp DOM API est le point dâentrĂ©e pour interagir avec SAFE. Les modules du rĂ©seau SAFE cotĂ© client se trouvent ici. Notez bien que lâAPI et les librairies sont amenĂ©es Ă Ă©voluer considĂ©rablement.
Certains membres de la communautĂ© sâentraident pour maĂźtriser lâ utilisation des API de SAFE et documentent leurs progrĂšs. [exemple : Lâintro aux Nodes pour les SAFE apps]
Le cĆur de SAFE est surtout Ă©crit en Rust. Les applications Ă©crites en Rust peuvent y accĂ©der directement [Un peu plus de lecture ici]
Les apps peuvent ĂȘtre Ă©crites dans tous langages, bien que JavaScript /Node.js sont les plus adĂ©quats. La documentation pour Safe-js se trouve ici, et pour Safe-node-js ici. Il se peut que certaines doc ne soient plus Ă jour. Un API JAVA (pour Android) est en cours dâĂ©laboration.
Il y a de nombreux tutoriels disponibles pour vous aider Ă apprendre les API dont une application dâemails, une app de traitement de texte, une app de crĂ©ation de site web avec les commentaires intĂ©grĂ©s et enfin une app de vidĂ©o confĂ©rence. Vous pouvez les tĂ©lĂ©charger tous dans le mĂȘme pack [plus de tutos ici]. Les derniĂšres avancĂ©es incluent un disque dur virtuel SAFE-VFS et un cadre de travail pour lâIoT (lâinternet des objets) SAFEthing, une version web de lâapp de dĂ©mo, et enfin Frames, une plateforme dâĂ©change de vidĂ©os.
Une sĂ©lection dâapp et dâautres Ă©chantillons divers sont disponibles sur demande auprĂšs de @whiteoutmashups.
Il y a un site dĂ©diĂ© aux dĂ©veloppeurs SAFE Dev Forum sur lequel vous pouvez poser toutes vos questions un peu techniques. Les forums MaidSafe en Asie on Ă©tĂ© créés dans le but de rĂ©unir et lier les dĂ©veloppeurs de ce continent. Par ailleurs, il y a des catĂ©gories locales sur le forum qui sâadressent spĂ©cialement aux hispanophones, russophones et germanophones.
Les autres endroits oĂč vous pouvez discuter de lâavancĂ©e de SAFE sont Riot, Reddit et Slack.
TrĂšs prochainement un nouveau type de donnĂ©es, « mutable data » ou donnĂ©es altĂ©rables, vont ĂȘtre introduites, qui permettront de crĂ©er des sites dynamiques : toute la communautĂ© est trĂšs excitĂ©e par cette perspective !!! [ Ă lire les donnĂ©es altĂ©rables RFC]
Hey, you know for a private banker youâre not such a bad guy ![]()
Awesome, posted it.
Thanks so much for your time!
Stellar post!!
Iâm wondering when the âfarmingâ can begin and if the average person will have enough hard drive space to contribute properly!
Also wondering if we can commit âcloudâ storage into this farming process (google drive, cloud, etc).
Very interesting stuff, looking forward to whatâs next!
Ah the question everyone eventually asks even if not in the forum ![]()
We donât know since this is ground breaking development, although it has progressed a lot in the last year. The next testnet is due âsoonâ Keep reading the dev updates every thursday in the Development category.
As to drive space, well my experience is that most non-geeks actually have 1/2 their drive space free and now-a-days that is like 1/2 TB to 1TB and that should be plenty.
Cloud storage is probably not going to work because of the access times to serve up data and since the rewards go to the âquickestâ farmer to serve up the chunk it is unlikely âcloudâ storage will succeed often enough to make it worth while
BUT if you were to use cloud computing with attached storage then you will likely do better than the average home setup. But then you have the costs of running your âcloudâ computing.
We (users/farmers) have used âcloudâ computing in past testnets and they have worked well.
