If your ‘reply to post’ is immediately below the post it doesn’t show differently from a ‘reply to topic’. Might be better if it did. Is that the explanation?
I use this button. Is that the right one? It then implies that it’s going to reply to you, but often when I send the reply, it doesn’t actually do that.
It’s just done it for this post too @happybeing . Happy to be corrected if I’m just being a complete dummy here.
Yes, I’ve just done the same but it doesn’t show differently because there are no intervening posts by others.
Ah right, ok! So will you still get a notification to say that I’ve replied to this post here?
Yes, and you should have one for this.
Right ok, glad to solve that little mystery, haha! It was confusing me because it didn’t indicate the reply to like it does with the non-consecutive posts.
@chriso (and others): You might have noticed that I talk about the Debian Rust team as something beside me, and indeed I a not part of that team in Debian despite my working on packaging Rust libraries now. Reason is that I disagree with how to maintain packages.
Today I was made aware of a blog post from a fellow Debian developer which shines some light on how the Rust team packages Rust crates, from the point of view of someone with a differing opinion. Regardless of your own opinion on which approach is “better”, that blog post may help gain knowledge on some of the peculiarities of Debian packaging that I (highly likely) have failed to communicate: https://diziet.dreamwidth.org/10559.html
I think you may have pasted the wrong link!
Indeed - corrected now. Thanks!
xor_name
has now been accepted into Debian, and is (or will be, in a few hours) available for install as part of the unstable
branch of Debian. If no severe bugs is discovered it will trickle into the testing
branch in a week, and then into next stable
Debian when released next year.
Developer information about the package is at rust-xor-name - Debian Package Tracker and user-oriented information is (in few hours) at Debian -- Package Search Results -- rust-xor-name
As mentioned yesterday, now it is in - and today some of the the autotesting has caught up which might be helpful in understanding that machinery:
At rust-xor-name - Debian Package Tracker in the middle section “testing migration” is now notices that autopkgtest
has succeeded for some archs and is ongoing for others, and that piuparts
has succeeded as well - with links to each in case you wanna learn more about those. Also, in the right section “links” is an entry “logs” tracking automatic package building for both officially supported architectures and unsupported ones (although it seems none of the unsupported ones support Rust, so irrelevant for this package specifically).
[ update, few days later - because this shitty chat system won’t let me have a monologue here… ]
xor_name
has now been accepted into the testing
branch of Debian.
NB! The name testing
describes the Debian system as a whole, not the individual package: Packages known unstable should be uploaded to the special experimental
branch.
The development tracker currently shows no ongoing tests in the middle section (only a minor issue is noted which didn’t affect progress), and in a few hours the left section “versions” should be updated to reflect that the package is available not only in the unstable
branch but also testing
If severe issues are spotted, they should be corrected in a new release to unstable
. Failure to do that will cause the package to get kicked from testing
. Same might happen for packages in stable as well, but we try very hard to not kick packages from stable
since that is used by millions of users in production.
Please someone say something here - anything, really.
Because the system blocks me from holding a monologue…
Any updates from you @jonas?
Now that I asked, lets hope that you are allowed.
Thanks, @Josh
(I had written a more elaborate status but when learning my posting right was blocked I dropped that…)
Yes, I have posted an update at https://bugs.debian.org/1008016
I also tag each draft release, and mention progress on reducing embedded crates in changelog.
I did a little moderator magic that hopefully results in the system giving you more monologue rights.
Thanks, @Sascha
Heh - seems that also granted me “access a private lounge area”…
My main client for the past 5 years - and my only source of income for the past 2 years - have cancelled our contract.
This might affect my work on packaging Safenet - time will tell how…
Maybe I will need to spend time on stuff less aligned with my work here, and have less spare time and energy to work on this.
Or maybe (especially if I choose to ignore reality and just continue work without pay until I crash hard - which I shouldn’t do) I will have more time for this.
I suspect this is not the best place, but cannot hurt to try: If anyone happens to know of someone in need of a Debian packaging expert (20+ years of experience, official maintainer of 600 packages - 1% of Debian) then please shout.
Sorry to hear this @jonas, and just as you were making progress!
Your work would seem worth of support in some way, perhaps the @BambooGarden fund? I’m not sure if it fits the criteria set out so far but it’s worth finding out if an application would be likely considered and what it should look like.
That sounds interesting - do you have a URI for that fund?
[update weeks later, due to annoying posting constraints]
Aaaand now I sent off an application - crossing fingers…
Thanks again, @happybeing
Thanks! I will try explore that
