Web Hosting Manager - Network operation is not possible as there is insufficient balance
Hi,
I was adding a site and got this error message.
Does this balance get reset at some point?
How do I start using it again?
You can only use 1000 puts per account in the alpha 2 network
If you need more puts for development it probably will make sense to go with the mock versions.
But if you just want another account you can write a message to the recipient @moderators and you will get an additional token
