Weather report
I had zero success downloading this or anything else until I manually wiped my bootstrap_cache directory.
Once deleted, everything sprang into life, using ant.
I tried an existing version of AntTP and that didn’t work either. So, I just built a new version with autonomi 0.5.3 libraries. That didn’t work either, until the cache was deleted above. Now it is flying again, including resolving pointers/registers within a few seconds.
So, deleting the stale bootstrap directory seems to be necessary, at least for my ubuntu setup.
Right, thanks.
This was honestly just not something that came up during the testing we done.
Didn’t really account for people out in the wild having old versions of the bootstrap cache. I thought it wasn’t working correctly.
Glad we’ve discovered it. I will add a post to the release thread.
made my scratchpad speed tests consistently fail…….
No - that’s the forked Scratchpad… Maybe… Hey the ant client does support Scratchpad read too doesn’t it? Can we read it from the there?
willie@gagarin:~$ ant scratchpad --help
Operations related to scratchpad management
Usage: ant scratchpad [OPTIONS]
Commands:
generate-key Generate a new general scratchpad key from which all your scratchpad keys can be derived (using their names)
cost Estimate cost to create a scratchpad
create Create a new scratchpad
share Share a scratchpad secret key with someone else. Sharing this key means that the other party will have permanent read and write access to the scratchpad
get Get the contents of an existing scratchpad from the network
edit Edit the contents of an existing scratchpad
list List owned scratchpads
help Print this message or the help of the given subcommand(s)
Options:
–timeout <CONNECTION_TIMEOUT>
The maximum duration to wait for a connection to the network before timing out
-x, --no-verify
Prevent verification of data storage on the network.
      This may increase operation speed, but offers no guarantees that operations were successful.
-h, --help
Print help (see a summary with ‘-h’)
ant scratchpad get -s 3a728f71282bd68fcbc6da9e335b46c1122e30eb4dc1ab4ba5c96ef65d365f47
(running here now … we’ll see where it ends)
^C
willie@gagarin:~$ time ant scratchpad get -s 3a728f71282bd68fcbc6da9e335b46c1122e30eb4dc1ab4ba5c96ef65d365f47
Logging to directory: “/home/willie/.local/share/autonomi/client/logs/log_2025-08-01_21-52-25”
Connecting to the Autonomi network…
Connected to the network
Retrieving scratchpad from network…
:white_check_mark: Successfully loaded scratchpad:
Address: 8e2d0725e1ef3847b21f1e8c2e37c28797717fbff4139d1fff74ff17162fc9f9473f96149c21f3b8f47d38847de3fbd7
Counter: 711
Data: this is a test
real 0m6.853s
user 0m0.416s
sys 0m0.222s
Connecting to the Autonomi network...
Retrieving scratchpad from network...
Error:
   0: Failed to retrieve scratchpad from network
   1: Record could not be found.
   ant-cli/src/commands/scratchpad.rs:152
funnily that’s no rubbish which means it’s the data I wrote in there by hand to resolve the fork
so you get the right state with the ant client - I just get fails
You might need to try clearing the bootstrap cache too.
I got the forking error:
❯ ant scratchpad get -s 3a728f71282bd68fcbc6da9e335b46c1122e30eb4dc1ab4ba5c96ef65d365f47
Logging to directory: "/home/chris/.local/share/autonomi/client/logs/log_2025-08-01_21-54-46"
Error:
   1: Got multiple conflicting scratchpads with the latest version, the fork can be resolved by putting a new scratchpad with a higher counter
sadly I did run that rm command after @Toivo posted it … and it doesn’t help
What about a file download? Does that work for you?
hmmm - no - not working either
I’m on macOS
location is the same - right?
running rm -rf ~/.local/share/autonomi/bootstrap_cache a second time
I guess the location is different here - no share/autonomi/ existing
Possibly not.
I’ll find the macOS and Windows locations…
/// The default location is platform specific:
///  - Linux: $HOME/.local/share/autonomi/bootstrap_cache/bootstrap_cache_<network_id>.json
///  - macOS: $HOME/Library/Application Support/autonomi/bootstrap_cache/bootstrap_cache_<network_id>.json
///  - Windows: C:\Users\<username>\AppData\Roaming\autonomi\bootstrap_cache\bootstrap_cache_<network_id>.json
rm -rf ~/Library/Application\ Support/autonomi/bootstrap_cache
and the file download works now - testing scratchpad now
Error:
That was the same failure I had.
OK, it looks like the data is retrievable but there is something else wrong.
I will feed this back internally and see if we can shift focus here.
thank you for your patience :slight_smile:
Are we in danger of being taken seriously :laughing:
Don’t mess it up now :stuck_out_tongue_winking_eye:
Do we really need this?
