you are missing the ``.``` at the end of the download command
This @aatonnomicc guy really is a smart one
willie@gagarin:~/projects/maidsafe/autonomi$ which ant
sh: 0: getcwd() failed: No such file or directory
/home/willie/.local/bin/ant
hmmmmmm
but leave and re-enter ~/projects/maidsafe/autonomi and all is normal
Confused but not terribly concerned
whats your
ant --version
saying to it ?
willie@gagarin:~/projects/maidsafe/autonomi$ ant --version
Autonomi Client v0.4.4
Network version: ant/1.0/1
Package version: 2025.7.1.3
Git info: main / 94d378aa4 / 2025-08-01
but wait…..
run
antup client --version 0.4.5
then run
ant --version
see if it gets you the right version
we are looking for this as the result for –version
Autonomi Client v0.4.5
Package version: 2025.7.1.5
Git info: stable / a66055a / 2025-07-31
dont leave us hanging is that you able to download the file now ?
Away and dangle, ya berry……![]()
Fetching chunk 2/3 [DONE]
Fetching chunk 3/3 …
Fetching chunk 3/3 [DONE]
Successfully fetched all 3 encrypted chunks
Successfully decrypted all 3 chunks
Successfully downloaded data at: 09ce1790489c71388b254d36134e61ae1e4c59df5768c04f3e0bbbdfc0c6c1ad
real 1m25.362s
user 0m1.779s
sys 0m0.907s
I updated my computer and restarted. Still failing for me. Is this correct?
Next rebooting the router.
@riddim
Are you still using speedtest-riddim.py
for scratchpad performance checks?
(venv) willie@gagarin:~/projects/maidsafe/scratch-perf-test$ python3 speedtest-riddim.pyScratchpad-Update time: 82.83 secondspopulation time: 3.12 secondsiterations: 1 - content: b’\x97\xf2\xf0[\xf4\x05\x11\xa3\xbe\x8e’…
Scratchpad-Update time: 19.76 secondspopulation time: 5.37 secondsiterations: 1 - content: b’^\xf9u\x19#\x13\xe8\x16\xf4\x8c’…
Scratchpad-Update time: 22.38 secondspopulation time: 5.38 secondsiterations: 1 - content: b’\xc6j.\xd4\x80\x8d\xd5l\xb3='…
Scratchpad-Update time: 14.40 secondspopulation time: 0.99 secondsiterations: 1 - content: b’\y\x85:\x07w;\xba\xf9_'…
Scratchpad-Update time: 8.83 secondspopulation time: 1.07 secondsiterations: 1 - content: b’l{!\x0f\x97\xce\x17\xde\xd3s’…
error on scratchpad update - time to error: 44.36 secondserror on scratchpad update - time to error: 39.20 secondsScratchpad-Update time: 10.80 secondspopulation time: 0.24 secondsiterations: 1 - content: b’@\xb9\xb2\x1f\xa1\x1b\x89\x83z\xd5’…
Scratchpad-Update time: 6.45 secondspopulation time: 0.24 secondsiterations: 1 - content: b’\xa0\xabR\x85\xdf\xf17\xbczn’…
Scratchpad-Update time: 8.86 secondspopulation time: 0.24 secondsiterations: 1 - content: b’I\x0f\x94\x11I\x83g1\xd8-'…
Scratchpad-Update time: 10.06 secondspopulation time: 0.24 secondsiterations: 1 - content: b’`r\x9bt[\xed\xc9\xc1\xbf+'…
Scratchpad-Update time: 5.82 secondspopulation time: 0.24 secondsiterations: 1 - content: b’\xe5hx\x05\xfeC<\x17\x0e9’…
Still some problems…….
Oh nice - there’s a new python release indeed
pip install --upgrade autonomi-client
looking pretty good on my cloud machine ![]()
Didn’t help.
Switched over to wifi via phone. Didn’t help.
I’m not sure how it’s possible that I see <100ms to read the scratchpad oO that shouldn’t be possible technologically imho …
ps: oh well - it’s broken now again
not ideal yet in python when getting back multiple scratchpad versions … but the team knows
and will probably sort it soonish … not really ideal to get no version at all because there’s multiple versions returned …
possibly someone else was interacting with the same scratchpad which resulted in the fork … dunno …
right now it seems to work again (ah - no - it doesn’t
worked only once … should have executed an update then …)
