UPnP problem
Counted UPnP forwards from my router, found 79 entries. I have 80 nodes running. One of them had 0 connections, and it’s port number matches with the missing UPnP forward.
Router log has this entry:
Mar 20 19:45:56 miniupnpd[2020]: removed 1 unused rules
Node has been running for 36 hours. Maybe the UPnP forward should be renewed at some points?
But for now, I’ll change back to manually forwarded ports.
Months ago I briefly tried pfSense with upnp. Worked great until the upnp ports started to time out. So back to port forwarding…
Sorry for digging old threads.
Im using node launcher for now, upnp was working, now isnt, what ports shoulsmd we be forwarding, tcp, udp, both?
UDP only. If you use port forward you can start nodes without uPnP.
