Hi! I’ve started writing a tutorial for the next vault test if any one is interessted. I’ll update it when I do the test myself This is so you can setup a vps account and get ready
To not have to worry about individual user setups (windows/linux etc). This will look the same to everyone. And most importantly to not worry about port forwarding This is just the easieas way I could think of
Lookit this, a guide to port-forwarding of many makes of router (just close the popup ads trying to sell you their stupid software):
Notes:
Once you have selected the make of router, then select a model, on that page then click on the link for “default guide.”
Even if your particular model isn’t there, pick a model with a similar name, the procedure is almost always very similar for a given manufacturer, across their model range.
EDIT: And to login to a domestic router, either google for the default login credentials, or look on the underside for a label that helpfully tells you. Hardly any home users ever change the admin password.
