[status: offline] SAFE Network Testnet - Vaults from home with IGD - Iteration 2.2
Hi everyone. Thank you for your participation in the last testnet. As mentioned earlier today, the Vaults in the testnet were killed by the operating system because of high memory usage. We have been studying the logs and there are no signs that show that there a sudden spike in memory usage led to the out of memory error. We suspect that certain components are using more memory than expected.
To help us study the memory usage of the Vault we will be doing memory profiling on the vault processes. We would like all of you to join the network once again. Both client and vaults are welcome. The goal is to replicate the OOM error once again so we can study the results of memory profiling. In other words, help us take down the network again :smile:
Instructions to join the network are exactly the same. Please visit the release post for iteration 2 for more information.
Thanks in advance.
Yesterday could connect, today not. (All router configuration are the same)
INFO 2020-07-17T15:21:54.185662158+02:00 [/usr/local/cargo/registry/src/github.com-1ecc6299db9ec823/quic-p2p-0.7.0/src/lib.rs:335] IGD request failed: Could not find the gateway device for IGD - IgdSearch(IoError(Custom { kind: TimedOut, error: “search timed out” }))
ERROR 2020-07-17T15:21:54.185787171+02:00 [src/bin/safe_vault.rs:169] Cannot start vault due to error: Routing(Network(IgdNotSupported))
ERROR 2020-07-17T15:21:54.185811574+02:00 [src/bin/safe_vault.rs:170] Automatic Port forwarding Failed. Check if UPnP is enabled in your router’s settings and try again. Note that not all routers are supported in this testnet. Visit https://forum.autonomi.community for more information.
Could you confirm that the vault configuration is correct? You can ensure by running:
safe networks check
Which platform are you on? I can give you the path to check the vault config file.
I am successfully connected.
I uploaded genesis.json of cosmos network … just for test
Its size is about 60M
if you want to test get speed, please use it. It took about 20sec in my case.
safe files get safe://hnyynyxjgtidjwufr5hiodnkrn33yrq9pco6xoczknq67n3dw55kk4y6wgbnc
After trying several times, I was able to connect. :+1:
As a first pass these simple sites all upload well and should be available with safe dog and safe cat through the CLI.
Some, like play.chess you’ll have to wait for that browser.
safe://burns.bard
safe://circle
safe://digger
safe://emptybag
safe://eye.eye
safe://eye.test
safe://fault
safe://freedom
safe://god
safe://hello
safe://joker
safe://know.your.enemy
safe://matryoshka
safe://medusa
safe://play.chess
safe://pluto
safe://quote
safe://savant.chess
safe://voyeur.chess
safe://security
safe://space.balls
safe://sweaty.palms
safe://the.odyssey
safe://the.teapot
safe://trust
safe://udhr
safe://uni
safe://V
safe://wallpaper
safe://website
safe://خليل.جبران
safe://Журавли
safe://无题
safe://i
safe://plutosmoon
safe://empty
safe://አለምአቀፍየጎራስምያስፈልጋል!
:smiley:
safe://moneygoeshere
SafeKey’s current balance: 0.000000000
déjà vu !
will more user slows down network or opposite is true?
In small network it’s likely they will, whether we notice it or not though is not clear. Larger network then not so much. A lot depends on number of sections and concurrent accesses.
tl;dr Yes they can over a certain limit.
Expecting we know when the last network booted and fell over.
Do we have a count down for the same this occasion?.. wonder some issues might just be time limited.
I’ll bet all the testsafecoin I have on 3.24AM BST!
I got this message from network
[2020-07-17T15:14:47Z TRACE safe_core::connection_manager::connection_group] 0: Recvd connection failure for 165.22.115.111:12000, Connection cancelled
on the back of what action/request??
I just did
safe cat safe://hello
and works ok.
I did safe files get command
$ safe cat safe://V
Files of FilesContainer (version 0) at "safe://V":
| Name          | Type            | Size | Created              | Modified             | Link                                                              |
| /V            | inode/directory | 0    | 2020-07-17T14:22:01Z | 2020-07-17T14:22:01Z |        |
| /V/index.html | text/html       | 1375 | 2020-07-17T14:22:01Z | 2020-07-17T14:22:01Z | safe://hbhybydr9toxojot8i56j183bghdynb59p5i6gwpctrddg1pn69h5jm74m |
| /V/style.css  | text/css        | 387  | 2020-07-17T14:22:01Z | 2020-07-17T14:22:01Z | safe://hbhyyydcftn8474rp9fdobjr98mdegqh3gba1hurez5ohdwauoeiusiww7 |
| /V/v.gif      | image/gif       | 3583 | 2020-07-17T14:22:01Z | 2020-07-17T14:22:01Z | safe://hbwyyodwgh3qzadykmety6cjtupc4djfok3kwh9e7eidgu5sdf7oanezk1 |
$ safe files get safe://V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
File [1 of 4]: V
  [00:00:00] [----------------------------------------] 0B/1.34KB (0B/s, 0s)  FiFile [1 of 4]: V
⠁ [00:00:00] [----------------------------------------] 0B/1.34KB (0B/s, 0s)  FiFile [2 of 4]: V/index.html
⠉ [00:00:00] [----------------------------------------] 0B/1.34KB (0B/s, 0s)  FiFile [2 of 4]: V/index.html
⠉ [00:00:00] [----------------------------------------] 0B/1.34KB (0B/s, 0s)  File
⠉ [00:00:01] [----------------------------------------] 0B/5.22KB (0B/s, 0s)  Transfer
still waiting for index.html
but
$ safe cat safe://V/index.html
[2020-07-17T15:33:05Z ERROR safe] safe-cli error: [Error] ContentError - No data found for path "/index.html/" on the FilesContainer at "safe://hnyynyqkjnqqigng479bb9uz6e8751yn5e5hcsk7mcugxg3nnriygt5h8cbnc/index.html?v=0"
suggests a problem.
So, safe files get should have picked up on that??..
also safe files get progress, is not well presented… spawning many lines.
Thanks for all the help guys! And great job I must say. We have been doing quite the bashing and reproduced the OOM issue on some of the nodes. We should have what we need to continue investigating the issue. I’ll leave the remaining nodes running, however with a reduced number of elders there is no certainity that all requests will go through. The logs after nodes fail, will help plan ahead for the next steps.
Thanks once again for all your help. Have a good weekend.
Is IP 157.245.43.31:12000 correct?
Can’t connect to it:
INFO 2020-07-18T14:57:25.405639900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\quic-p2p-0.7.0\src\lib.rs:543] Node 157.245.43.31:12000 is unresponsive, removing it from bootstrap contacts; 0 contacts left
Is this iteration also crashed like previous two?
That is the way of saying “157.245.43.31:12000 down”?
As it says here
