A thread to keep issues arising from this new tool in one place
@dirvine gave some pointers to get started - copied below
On left
Status → shows states tried, all unique states and depth of the tries, i.e. how many levels deep of finding new routes (states) to take.
Properties
Global
Shows the properties we are looking to achieve i.e. no doublespend all membership sets converge and so on.
Path of actions
Here you manually click on messages in any order you wish. If you select Per State in the checkbox you will see for every message we are either green or we found a counterexample.
I usually though click the run to completion and it does that automatically, but for early testing, it’s good to have the manual option.
If we find a counterexample, it looks like this (I will make a bug) Below you will see the counterexample it found. I clicked on that to show you this picture. You can see the sequence diagram of messages it sent to get the counterexample (bug). It also shows the state of all nodes, what they know etc.
If you go through the path of actions you can see the sequence diagram filling up and there you will find the bug.
Then of course you work out why and then fix it It’s very very good
I dragged out an old monitorr with a swivel stand so I could view this in portrait.
With the mess it caused to my nvidia settings it was prob more bother than its worth but I’ll stick with it for a day or two.
