and another http://web.chunky101.safenet
Front
Front
Keep getting cannot create file/directory. Tried creating more than one account and/or ID as well.
Is that UDP progress still available and open source? So when The world is all watching and wants to create it, they will have a solid foundation to start from?
Thanks for this, providing the droplets obviously comes at a cost to the company. Much appreciated.
No problems at all here, logging into an account I created five hours ago and checking the data.
Try a fresh start with a default local network, no redirections, with download of launcher 0.4.5 in an empty folder, start without any vaults since this network uses later binaries and @dirvine requested no community binaries.
I am, however, now running a community1 vault (on community1 of course) as well as a launcher for client_test_2 (this network): they operate quite separately each on its own network.
Thanks for talking to us directly David, it really is a lift when you give out precise info like this.
Are you still in Beta? ![]()
Are you mainly talking about the trollbox?
Good point! The very reason Iāll be trying hosted servers for my first farming attemptsā¦rather than low watted machines from behind ADSL.
http://dir.yvette.safenet
http://a.random.safenet
http://this.is.safenet
http://test.bluebird2.safenet
http://hello.safenet
http://test.bluebird1.safenet
http://frostbyte.safenet
http://polpolrene.safenet
http://ithanium.safenet
http://test.bluebird.safenet
http://pacman.safenet
http://maidsafe.safenet
http://abittner.safenet
http://test.bluebird3.safenet
http://John.safenet
http://anon.safenet
http://yvette.safenet
Donāt know about developing something yet but just so Iāll have a story to tell my grandchildren one day: http://me.too.safenet
Hi
Please add
http://oldhold.southside.safenet/
Its just an old set of holding pages - I wanted more than just the template and this was the only semi-complete site I could quickly upload.
If SAFE could circumvent the Great Fire Wall in China, itās going to be a killer app in China.
It already has. As I understand there have been tests to log into the test networks from behind the firewall that have been successful!!
A great step forward for freedom of information! ![]()
Itās not that easy. Even Tor cannot work in China. There will be a relentless fight from the Chinese government using the GFW.
Here is a quote that I think explains some of the added features of SAFE that allow it to be more secure and firewall resistant than other options (such as Tor)
āMaidSafe doesnāt use DNS. Everything goes through routers in a thing called encrypted RUDP packets, so basically the packets go through the router but nothing can tell whatās inside it. And it doesnāt use DNS so they donāt know that itās traffic for the MaidSafe network. So countries canāt shut MaidSafe down. So China couldnāt shut off the Safe network the way they could now, or Turkey couldnāt shut it off the way they shut off Twitter. So the only way they can actually stop the Safe network in a country is to shut off the whole Internet. It just canāt be shut down,ā
OK, but you canāt rule out the possibility that it simply hasnāt yet been noticed by the people who run the GFW.
One obvious tactic they can deploy is to block the IPs in the test config files.
For the test network yes, but as I understand it, once the network is up for real, there will not be IP addresses to block at allā¦
As i understand it, the seed IP addresses wonāt need to be in a config file, thatās all. They will be able to be found on many channels outside of SAFEnet. So it will be a constant easter egg hunt by the GFW admins, blocking SAFE seeder IPs wherever they are found, and they would need to get all of them. If one is available then the client is straight onto the network. With IPV6 and unlimited IPs it gets even better.
