Safe token to MAID, how it going to be?
I am curious how exatly it will be if someone now have MAID on BTC adress, then in finished network I assume conversion from token to “maid” will be see in blockchain as when I send from one adress to another? I am bit scared that EU will denny anonymous coins, and this (even if its not finished) will be included it in. What do you think?
Thanks
After conversion you no longer have MAID, you have the Safe Network Token which is anonymous. You can then do what you want with it anonymously.
I’m not sure what you fear a government may do about this.
