SAFE Network - TEST 7
According to my experience the launcher does pop up under Linux (Ubuntu 14.04) when the demo app asks for permission (at least until “test 7A”, I did not try “test 7B” yet)
EDIT: I mean when the launcher window is in the background, I don’t know what happens when it is minimized…
Yes, it does some form of pop-under but that just creates a flicker without putting the question directly in front of the user.
I did not test it since the 20th of June. Congratulation for the progress accomplished. It’s fluid and fast. And I really like the user interface.
Finally got time to mess around with it. It is solid!
http://bam.savage.safenet
Wow! I pause for 5 seconds due to loading times… Resume playing, it played all the way to end of the video. That’s really impressive!
Hello! Please tell me:
is this actual list of SAFE apps? Or are the more somewhere?
I believe it is the current list of available applications on the test network. I’m not sure every application has been updated to run on test 7.
If you want to try out something that certainly works on test 7, you can download this: Install SAFE Demo App
secret & password to enter the SAFE network just works for me ,
I wouldn’t mind if it is preferred to swap the order of the fields to
password & secret , as this might be more familiar to some users .
I’d love to see a 24h time delay after x-failed attempts built into SAFE
but if we cannot have time awareness on such requests in the core ,
so be it … let’s not give up searching for a hack that can map it .
Choosing a long enough string that is still humanly rememberable
while receiving a semantic guidance and feedback from the app
regarding the strength is useful , let’s also state the bit depth .
We should explicitly display a line stating that SAFE sites are visitable
even without creating any credentials , just by running the launcher app …
( and currently also by pointing to the proxy file to translate our addresses )
It cannot be obviated enough for the very first experiences and beginners .
Sites seem to work really fast from what I have been playing around ,
and managing or creating services have experienced improvements .
We are really getting closer to the core goals of the vision : Can’t wait !
I’ve got my site updated and running on SAFE with the Content Security Policy issues fixed now.
Please enjoy:
http://ko-live-edit-template.eggmunkee.safenet/
Basically, this is a live editor for KnockoutJS templates; you can edit an HTML template on the left and JSON data on the right and it renders the combined template below.
Thanks for the help, @davidpbrown.
Anyone know if its possible to make more diffrent ID’s when mainnet is live ?
I have three projects that i would love to switch one day to safenet.
Will there be a lock on IP adress, for squitting?
Yes that is the plan for sure.
Also you will be able to have multiple accounts if that is more suitable
I think multiple accounts is good for sure, easy to separate them from each other.
I like to keep everything organised, otherwise i will lose my way in all the mess :wink:
http://123.buliang.safenet/
That looks good !
I can not seem to find the vault binaries. Are those not released this time?
20characters…
Vaults are not yet allowed in this test, sorry. I’m not sure if they will be or not but for now users can only run the Launcher, Demo App and create/browse websites.
Can anyone describe why it appears multiple requests are made for files that have already been downloaded successfully?
For example, I see 16 instances below for /dns/www/000/index.html
I’ve seen this many times before and wondered about it; this time I caught it and could see the whole of that index file had downloaded and yet still the requests kept coming.
Every time I see this it appears to move on after a while but I wonder some of those requests are not needed. Perhaps it’s a deliberate part of the test or perhaps there’s a good reason for it but if the file is downloaded to a point that I can open it, then I wondered there is nothing more that truly needed downloading.
DEBUG 19:19:4.973 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:4.980 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:4.981 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:4.983 - Sending message to FFI - 15be6bd6-69a6-4bb1-8648-dba74da1b750 - dns - get-file-metadata
DEBUG 19:19:5.193 - FFI response code 0 for id - 15be6bd6-69a6-4bb1-8648-dba74da1b750
VERBOSE 19:19:5.194 - Invoking response callback :: callback id - 15be6bd6-69a6-4bb1-8648-dba74da1b750
DEBUG 19:19:5.196 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:5.201 - DNS - Ready to stream file for range0-627/627
DEBUG 19:19:5.217 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:5.218 - Sending message to FFI - ec1537db-b58c-4be4-a72e-5ac9f83a5dad - dns - get-file
DEBUG 19:19:5.492 - FFI response code 0 for id - ec1537db-b58c-4be4-a72e-5ac9f83a5dad
VERBOSE 19:19:5.498 - Invoking response callback :: callback id - ec1537db-b58c-4be4-a72e-5ac9f83a5dad
DEBUG 19:19:6.551 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:6.553 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:6.554 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:6.555 - Sending message to FFI - 7da977c3-3f92-4dda-a799-03a77860dd3b - dns - get-file-metadata
DEBUG 19:19:6.770 - FFI response code 0 for id - 7da977c3-3f92-4dda-a799-03a77860dd3b
VERBOSE 19:19:6.772 - Invoking response callback :: callback id - 7da977c3-3f92-4dda-a799-03a77860dd3b
DEBUG 19:19:6.772 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:6.774 - DNS - Ready to stream file for range627-627/627
DEBUG 19:19:8.806 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:8.808 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:8.809 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:8.810 - Sending message to FFI - 7bd8aa52-7fbe-4963-8db9-f9797d78506f - dns - get-file-metadata
DEBUG 19:19:9.51 - FFI response code 0 for id - 7bd8aa52-7fbe-4963-8db9-f9797d78506f
VERBOSE 19:19:9.55 - Invoking response callback :: callback id - 7bd8aa52-7fbe-4963-8db9-f9797d78506f
DEBUG 19:19:9.56 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:9.58 - DNS - Ready to stream file for range627-627/627
DEBUG 19:19:12.78 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:12.80 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:12.81 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:12.82 - Sending message to FFI - 89322055-2db2-470f-940f-688421b66e89 - dns - get-file-metadata
DEBUG 19:19:12.291 - FFI response code 0 for id - 89322055-2db2-470f-940f-688421b66e89
VERBOSE 19:19:12.293 - Invoking response callback :: callback id - 89322055-2db2-470f-940f-688421b66e89
DEBUG 19:19:12.295 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:12.300 - DNS - Ready to stream file for range627-627/627
DEBUG 19:19:16.321 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:16.323 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:16.324 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:16.325 - Sending message to FFI - e45825a4-198a-480f-abd0-633770c64a82 - dns - get-file-metadata
DEBUG 19:19:16.531 - FFI response code 0 for id - e45825a4-198a-480f-abd0-633770c64a82
VERBOSE 19:19:16.532 - Invoking response callback :: callback id - e45825a4-198a-480f-abd0-633770c64a82
DEBUG 19:19:16.544 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:16.545 - DNS - Ready to stream file for range627-627/627
DEBUG 19:19:21.566 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:21.569 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:21.572 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:21.574 - Sending message to FFI - 5c2cc393-2b7b-4b77-87d9-eb02ddd134c4 - dns - get-file-metadata
DEBUG 19:19:21.797 - FFI response code 0 for id - 5c2cc393-2b7b-4b77-87d9-eb02ddd134c4
VERBOSE 19:19:21.798 - Invoking response callback :: callback id - 5c2cc393-2b7b-4b77-87d9-eb02ddd134c4
DEBUG 19:19:21.800 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:21.801 - DNS - Ready to stream file for range627-627/627
DEBUG 19:19:27.823 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:27.825 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:27.826 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:27.827 - Sending message to FFI - 5fc023dd-bb7f-4cdb-b70e-aeac9e36a3ad - dns - get-file-metadata
DEBUG 19:19:28.398 - FFI response code 0 for id - 5fc023dd-bb7f-4cdb-b70e-aeac9e36a3ad
VERBOSE 19:19:28.399 - Invoking response callback :: callback id - 5fc023dd-bb7f-4cdb-b70e-aeac9e36a3ad
DEBUG 19:19:28.400 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:28.401 - DNS - Ready to stream file for range627-627/627
DEBUG 19:19:35.448 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:35.452 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:35.453 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:35.455 - Sending message to FFI - ab1a3a34-304f-489c-b366-f62de9d2c1eb - dns - get-file-metadata
DEBUG 19:19:35.667 - FFI response code 0 for id - ab1a3a34-304f-489c-b366-f62de9d2c1eb
VERBOSE 19:19:35.670 - Invoking response callback :: callback id - ab1a3a34-304f-489c-b366-f62de9d2c1eb
DEBUG 19:19:35.672 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:35.675 - DNS - Ready to stream file for range627-627/627
DEBUG 19:19:43.699 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:43.702 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:43.703 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:43.704 - Sending message to FFI - 0d68cc16-b977-4f7b-825c-7c7496b887de - dns - get-file-metadata
DEBUG 19:19:43.924 - FFI response code 0 for id - 0d68cc16-b977-4f7b-825c-7c7496b887de
VERBOSE 19:19:43.926 - Invoking response callback :: callback id - 0d68cc16-b977-4f7b-825c-7c7496b887de
DEBUG 19:19:43.928 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:43.929 - DNS - Ready to stream file for range627-627/627
DEBUG 19:19:52.945 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:19:52.947 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:19:52.948 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:19:52.949 - Sending message to FFI - b6f8f638-577b-40bb-b750-60fa170bd910 - dns - get-file-metadata
DEBUG 19:19:53.158 - FFI response code 0 for id - b6f8f638-577b-40bb-b750-60fa170bd910
VERBOSE 19:19:53.159 - Invoking response callback :: callback id - b6f8f638-577b-40bb-b750-60fa170bd910
DEBUG 19:19:53.160 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:19:53.161 - DNS - Ready to stream file for range627-627/627
DEBUG 19:19:53.298 - Invoking CLIENT STATS API:: GETs COUNT::client-stats
DEBUG 19:19:53.300 - Sending message to FFI - 2fcb85a8-63d2-4162-9067-35523405f53f - client-stats - gets
DEBUG 19:19:53.317 - FFI response code 0 for id - 2fcb85a8-63d2-4162-9067-35523405f53f
VERBOSE 19:19:53.318 - Invoking response callback :: callback id - 2fcb85a8-63d2-4162-9067-35523405f53f
DEBUG 19:20:3.181 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:20:3.183 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:20:3.186 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:20:3.187 - Sending message to FFI - 56e6ca1b-b5ab-427f-9a43-2ac356b04785 - dns - get-file-metadata
DEBUG 19:20:3.423 - FFI response code 0 for id - 56e6ca1b-b5ab-427f-9a43-2ac356b04785
VERBOSE 19:20:3.426 - Invoking response callback :: callback id - 56e6ca1b-b5ab-427f-9a43-2ac356b04785
DEBUG 19:20:3.427 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:20:3.429 - DNS - Ready to stream file for range627-627/627
DEBUG 19:20:13.450 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:20:13.454 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:20:13.455 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:20:13.458 - Sending message to FFI - 0aadbc1e-825f-40b4-8c6a-22ee043cd9fe - dns - get-file-metadata
DEBUG 19:20:13.673 - FFI response code 0 for id - 0aadbc1e-825f-40b4-8c6a-22ee043cd9fe
VERBOSE 19:20:13.674 - Invoking response callback :: callback id - 0aadbc1e-825f-40b4-8c6a-22ee043cd9fe
DEBUG 19:20:13.675 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:20:13.676 - DNS - Ready to stream file for range627-627/627
DEBUG 19:20:23.697 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:20:23.700 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:20:23.701 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:20:23.702 - Sending message to FFI - d20cd19d-f614-4b65-a3e8-678675a208ef - dns - get-file-metadata
DEBUG 19:20:23.956 - FFI response code 0 for id - d20cd19d-f614-4b65-a3e8-678675a208ef
VERBOSE 19:20:23.957 - Invoking response callback :: callback id - d20cd19d-f614-4b65-a3e8-678675a208ef
DEBUG 19:20:23.958 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:20:23.961 - DNS - Ready to stream file for range627-627/627
DEBUG 19:20:33.988 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:20:33.989 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:20:33.990 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:20:33.993 - Sending message to FFI - a9c963ea-183c-4a13-995f-f0d135c6bbf9 - dns - get-file-metadata
DEBUG 19:20:34.236 - FFI response code 0 for id - a9c963ea-183c-4a13-995f-f0d135c6bbf9
VERBOSE 19:20:34.237 - Invoking response callback :: callback id - a9c963ea-183c-4a13-995f-f0d135c6bbf9
DEBUG 19:20:34.238 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:20:34.239 - DNS - Ready to stream file for range627-627/627
DEBUG 19:20:44.260 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:20:44.261 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:20:44.262 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:20:44.263 - Sending message to FFI - 584774c5-4cc2-4780-ab49-179eeb94b812 - dns - get-file-metadata
DEBUG 19:20:44.627 - FFI response code 0 for id - 584774c5-4cc2-4780-ab49-179eeb94b812
VERBOSE 19:20:44.629 - Invoking response callback :: callback id - 584774c5-4cc2-4780-ab49-179eeb94b812
DEBUG 19:20:44.630 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:20:44.631 - DNS - Ready to stream file for range627-627/627
DEBUG 19:20:53.298 - Invoking CLIENT STATS API:: GETs COUNT::client-stats
DEBUG 19:20:53.299 - Sending message to FFI - fdaa4e19-86e3-4717-87ef-0cd29c52343f - client-stats - gets
DEBUG 19:20:53.304 - FFI response code 0 for id - fdaa4e19-86e3-4717-87ef-0cd29c52343f
VERBOSE 19:20:53.305 - Invoking response callback :: callback id - fdaa4e19-86e3-4717-87ef-0cd29c52343f
DEBUG 19:20:54.654 - Unauthorised request ::/dns/www/000/index.html
DEBUG 19:20:54.658 - DNS - Invoking getFile API for 000, www, index.html
DEBUG 19:20:54.659 - Invoking API DNS::getFile - FFI::dns::get-file
DEBUG 19:20:54.661 - Sending message to FFI - 1953035a-5e34-4835-a8cd-c1da06766488 - dns - get-file-metadata
DEBUG 19:20:54.888 - FFI response code 0 for id - 1953035a-5e34-4835-a8cd-c1da06766488
VERBOSE 19:20:54.890 - Invoking response callback :: callback id - 1953035a-5e34-4835-a8cd-c1da06766488
DEBUG 19:20:54.891 - DNS - File metadata for reading - {"name":"index.html","size":627,"created_time_sec":1469979154,"created_time_nsec":67677000,"modified_time_sec":1469979154,"modified_time_nsec":71350000,"user_metadata":[],"version":2}
DEBUG 19:20:54.892 - DNS - Ready to stream file for range627-627/627
INFO 19:21:3.257 - Stopping proxy server
DEBUG 19:21:3.261 - Closing FFI worker client
WARN 19:21:3.287 - FFI worker client closed already
INFO 19:21:3.294 - Proxy server stopped
Got mail:
Hi David
I’m a big Maidsafe fan. I noticed you made a list of current safenet
sites on SAFE Network - TEST 7 - #166 by 19eddyjohn75.
I have a few sites but I don’t have an account on safenetforum.org.
So I hoped you might add them to your list (if it’s not too much trouble).
One isn’t perfect because of some HTTP CSS problem with the system.
http://trump.brown.safenet/
http://trump3.brown.safenet/
http://iraq.brown.safenet/
http://irexit.brown.safenet/
http://ihaveadream.brown.safenet/
http://flag.brown.safenet/
http://comfortably.brown.safenet/ (no CSS)
I really appreciate If yoy could do this.
Thanks
Fox
Out of 74 PublicIDs, fell 53 websites
http://dir.yvette.safenet/
So, Test7b seems to be working well from here and I’ve only spotted two minor issues..
Freshly uploaded for your enjoyment. =^-.-^=
http://amvs.blindsite.safenet/
And of course
http://quotes.blindsite.safenet/
Oh and can we get a rename file feature at some point? It seems rather wasteful to have to delete and upload an entire file (especially if it’s a big file taking up significant chunkage) just to change a typo in a file name. I mean a file name is a significantly small part of the file correct? So isn’t there some way we could, store most of the file, just change that one minor part and then just upload the filename change instead of the entire thing?
