Quite frankly I think there needs to be a revisement of the batch uploading for the demo app. If we’re going to charged safecoin for individual files then we should be able to manipulate individual files. So far if you upload a folder for a site and it fails you get charged puts for the partial upload but don’t have access to the files you supposidly uploaded and can’t reupload the files. I already submitted a bug report for this a couple days ago (no response so far). But the bug aside I think it points out a larger issue. I like being able to upload an entire batch but I think it should be modified so it’s not just 0 - 100% but rather one can see each individual file’s progress being uploaded (like on say a window manager of some kind when copying files) and have acces to each file that has been copied to SAFE regardless of whether the complete list of files in the batch finishes or not.
Probably not if the files are titled correctly and hey i liked Van helsing. It was a good movie and a nice tribute to the classics.
Deleting more than one private file at a time within a folder seems not possible either.
Yeah that needs to be fixed as well. Though the files I was uploading were public not private. Still I’d like to have access to files that I’m being charged PUTs for.
Any idea how to fix the problem I was having, where if I’m logged in, all the connections seem to time out?
Unfortunately I can’t test much if I can’t upload ![]()
If the keyword and PIN are still nesesary for an account I think the user should have access to them. I can’t log into the same account via different operating systems. Haven’t tried via the same OS/different machines yet. But it would seem to be a problem, especially if the idea is that SAFE is to be accessed from any machine.
I’m having issues viewing safenet sites. The .pac is in place, the launcher is up and running. So I’m not sure what the problem is.
It’s pretty convenient to go to the relevant issues page listed in the OP and see if it’s been reported already. Add a new issue or comment on an already opened issue.
i.e launcher: Issues · maidsafe-archive/safe_launcher · GitHub
Feedback is not instant from the Devs, but they do send a confirmation email once the issue has been addressed.
For the last couple of days all I’ve had is this
Edit: I already had an active account since TEST6 was set up and I know my password is definitely correct.
Edit 2: Might my account have been deleted? I just created a new account with the password that I used for my first account.
Everything seems to just autostart when you download them from the Demo app. This could also be a way to spread malware easily, because people are always so fond to just click on stuff. Exe & vids just auto start.
Sorry that I ask this, but did you create an account first. Because I checked it and that happened when I didn’t create an account
Have you clicked on “create account”?
That is what happened to me first time.
EDIT: beaten by @19eddyjohn75
Agree - a “Save As” dialogue would be much better.
Yes I had been using my account no problem since TEST6 was set up, it just suddenly stopped working
The MaidSafe Demo App is stuck at “Waiting for Response”.
I don’t know if the following Launcher log helps any way, but here we go:
DEBUG 5:54:3.5 - Starting FFI worker client
DEBUG 5:54:3.25 - Sending FFI initialisation request
DEBUG 5:54:3.26 - Sending message to FFI - a3d0351b-375e-4bcd-af39-5425c5023c19
- connect -
DEBUG 5:54:3.31 - Application starting
DEBUG 5:54:4.824 - FFI/mod/auth.js - Create Unregistered Client Handle
DEBUG 5:54:6.800 - FFI/mod/auth.js - Registering observer
DEBUG 5:54:6.801 - Network state change event received :: 0 :: false
INFO 5:54:6.801 - Connected with network
INFO 5:54:6.804 - Starting proxy server
DEBUG 5:54:6.998 - Proxy Server - onMessage event - received - {"type":"connecti
on","msg":{"status":true,"msg":"Proxy started"}}
INFO 5:54:6.998 - Proxy server started
DEBUG 5:54:15.9 - Invoking Auth::login API
DEBUG 5:54:15.9 - Sending message to FFI - 326dbd99-c2ee-4254-8245-01f78be6f8c0
- auth - login
INFO 05:54:17.120053000 [routing::core core.rs:1181] Bootstrapping(PeerId(2c6e..
), 0)(028755..) Connection failed: Proxy node needs a larger routing table to ac
cept clients.
INFO 05:54:18.319856200 [routing::core core.rs:1181] Bootstrapping(PeerId(2c6e..
), 1)(028755..) Connection failed: Proxy node needs a larger routing table to ac
cept clients.
DEBUG 5:54:47.882 - FFI/mod/auth.js - Registering observer
DEBUG 5:54:47.883 - FFI/mod/auth.js - get SafeDrive Dir Key
DEBUG 5:54:47.884 - FFI response code 0 for id - 326dbd99-c2ee-4254-8245-01f78be
6f8c0
VERBOSE 5:54:47.884 - Invoking response callback :: callback id - 326dbd99-c2ee-
DEBUG 5:54:47.885 - Network state change event received :: 0 :: true
INFO 5:54:47.885 - Connected with network
DEBUG 5:54:47.886 - Dropping unregistered client
DEBUG 5:54:47.886 - Invoking Auth::dropUnregisteredClient API
DEBUG 5:54:47.886 - Sending message to FFI - 83541f42-86fd-4aff-aa72-eeb633e136c
5 - auth - drop-unregistered-client
DEBUG 5:54:47.888 - Invoking CLIENT STATS API:: Account Info ::client-stats
DEBUG 5:54:47.888 - Sending message to FFI - 5fc9bd73-d3bf-4711-9e2a-0322a3f7c80
d - client-stats - acc-info
DEBUG 5:54:47.889 - FFI/mod/auth.js - Dropping unregisteredClientHandle
DEBUG 5:54:47.899 - FFI response code 0 for id - 83541f42-86fd-4aff-aa72-eeb633e
136c5
VERBOSE 5:54:47.899 - Invoking response callback :: callback id - 83541f42-86fd-
4aff-aa72-eeb633e136c5
DEBUG 5:54:50.616 - FFI response code 0 for id - 5fc9bd73-d3bf-4711-9e2a-0322a3f
7c80d
VERBOSE 5:54:50.616 - Invoking response callback :: callback id - 5fc9bd73-d3bf-
4711-9e2a-0322a3f7c80d
DEBUG 5:55:1.853 - Unauthorised request ::/auth
DEBUG 5:55:1.855 - Authorisation request received
DEBUG 5:55:1.856 - Emitting event for auth request received
DEBUG 5:55:3.326 - Waiting for directory key for creating an session
DEBUG 5:55:3.326 - Invoking Auth::getAppDirectoryKey API
DEBUG 5:55:3.327 - Sending message to FFI - 2edd56e4-5eaf-4240-b3c8-f8a081998f5a
- auth - app-dir-key
DEBUG 5:55:3.333 - FFI/mod/auth.js - Getting App Root Dir Key
DEBUG 5:55:47.889 - Invoking CLIENT STATS API:: GETs COUNT::client-stats
DEBUG 5:55:47.890 - Sending message to FFI - 4bf6a85c-7e3f-411c-968f-777b5ea5742
3 - client-stats - gets
DEBUG 5:55:47.891 - Invoking CLIENT STATS API:: DELETEs COUNT::client-stats
DEBUG 5:55:47.891 - Sending message to FFI - f74ec699-8dab-4d0b-a64b-723cedd795d
8 - client-stats - deletes
DEBUG 5:55:47.892 - Invoking CLIENT STATS API:: POSTs COUNT::client-stats
DEBUG 5:55:47.892 - Sending message to FFI - 50e7c386-544a-4294-a072-ce5922ea6e9
9 - client-stats - posts
DEBUG 5:55:47.893 - Invoking CLIENT STATS API:: PUTs COUNT::client-stats
DEBUG 5:55:47.893 - Sending message to FFI - 65b43037-a5dc-405a-bd22-681e1796df3
b - client-stats - puts
DEBUG 5:55:47.898 - FFI response code 0 for id - 4bf6a85c-7e3f-411c-968f-777b5ea
57423
VERBOSE 5:55:47.899 - Invoking response callback :: callback id - 4bf6a85c-7e3f-
411c-968f-777b5ea57423
DEBUG 5:55:47.900 - FFI response code 0 for id - f74ec699-8dab-4d0b-a64b-723cedd
795d8
VERBOSE 5:55:47.901 - Invoking response callback :: callback id - f74ec699-8dab-
4d0b-a64b-723cedd795d8
DEBUG 5:55:47.901 - FFI response code 0 for id - 50e7c386-544a-4294-a072-ce5922e
a6e99
VERBOSE 5:55:47.902 - Invoking response callback :: callback id - 50e7c386-544a-
4294-a072-ce5922ea6e99
DEBUG 5:55:47.903 - FFI response code 0 for id - 65b43037-a5dc-405a-bd22-681e179
6df3b
VERBOSE 5:55:47.903 - Invoking response callback :: callback id - 65b43037-a5dc-
405a-bd22-681e1796df3b
DEBUG 5:56:47.889 - Invoking CLIENT STATS API:: GETs COUNT::client-stats
DEBUG 5:56:47.890 - Sending message to FFI - 344225d4-e028-4ffe-8c03-f9ccabab370
1 - client-stats - gets
DEBUG 5:56:47.890 - Invoking CLIENT STATS API:: DELETEs COUNT::client-stats
DEBUG 5:56:47.891 - Sending message to FFI - ce7b45a5-8411-4d32-be95-fb53f0e3dd0
1 - client-stats - deletes
DEBUG 5:56:47.891 - Invoking CLIENT STATS API:: POSTs COUNT::client-stats
DEBUG 5:56:47.892 - Sending message to FFI - 222d196a-cd30-4a8c-97d3-c64725b6b2a
4 - client-stats - posts
DEBUG 5:56:47.892 - Invoking CLIENT STATS API:: PUTs COUNT::client-stats
DEBUG 5:56:47.892 - Sending message to FFI - c0329fef-9768-4919-b9c7-fd0ae8c9fe6
6 - client-stats - puts
DEBUG 5:56:47.895 - FFI response code 0 for id - 344225d4-e028-4ffe-8c03-f9ccaba
b3701
VERBOSE 5:56:47.896 - Invoking response callback :: callback id - 344225d4-e028-
4ffe-8c03-f9ccabab3701
DEBUG 5:56:47.899 - FFI response code 0 for id - ce7b45a5-8411-4d32-be95-fb53f0e
3dd01
VERBOSE 5:56:47.900 - Invoking response callback :: callback id - ce7b45a5-8411-
4d32-be95-fb53f0e3dd01
DEBUG 5:56:47.901 - FFI response code 0 for id - 222d196a-cd30-4a8c-97d3-c64725b
6b2a4
VERBOSE 5:56:47.902 - Invoking response callback :: callback id - 222d196a-cd30-
4a8c-97d3-c64725b6b2a4
DEBUG 5:56:47.904 - FFI response code 0 for id - c0329fef-9768-4919-b9c7-fd0ae8c
9fe66
VERBOSE 5:56:47.904 - Invoking response callback :: callback id - c0329fef-9768-
4919-b9c7-fd0ae8c9fe66
DEBUG 5:57:1.833 - Authorised request :://auth
DEBUG 5:57:1.833 - Decrypted session id :: undefined
WARN 5:57:1.834 - Session ID not found
I find interesting the last log entry> “SESSION ID NOT FOUND”.
Take care
