SAFE Network Alpha Release!
still kicking a**
Not sure about Alpha 2.0
btw, nice video
8 posts were split to a new topic: New funding for Maidsafe using ā€˜bank to the future’
Did you figure it out yet? I tried with a VPN through Thailand and it seems fine here/through that. Maybe you want to try a VPN through a different location. Can only imagine local DNS proxies messing up …
Techcrunch link wasn’t added to reddit.com/r/Futurology/ yet so I just did.
Here’s the direct link for those who like to vote.
Thanks @lightyear for checking. No - I still get the same result when I try to connect to anything at maidsafe.net.
I haven’t tried the VPN option yet (bit of an old noob) but will check it out.
Thank you
Out of 111 PublicIDs, fell 52 websites
http://dir.yvette.safenet
http://dirvine.safenet
http://mysongs.fiee.safenet
http://polpolrene.safenet
http://safecoin.savage.safenet
http://comfortably.brown.safenet
http://flag.brown.safenet
http://maze.safenet
http://onaka.safenet
http://eye.eye.safenet
http://spandan.safenet
http://ihaveadream.brown.safenet
http://website.catmar1944.safenet
http://nms.safenet
http://trump3.brown.safenet
http://nike.safenet
http://irexit.brown.safenet
http://pacman.safenet
http://base.hdastwb.safenet
http://google.safenet
http://maidsafeu.whiteoutmashups.safenet
http://iraq.brown.safenet
http://hdastwb.safenet
http://yvette.safenet
http://stabbyland.stabby.safenet
http://frabrunelle.safenet
http://trump.brown.safenet
http://app.ghost.safenet
http://chunky101.safenet
http://secrets.aden.safenet
http://the.odyssey.safenet
again, Bruce Lee wisdom :slight_smile:
http://brucelee1.wisdom.safenet/
Thanks @lightyear - I downloaded open source VPN software and connected through Canada with no problem. Not quite sure why it is a problem for me direct from Thailand. Thanks again.
SAFE Network Alpha Release:
http://yes.getting.there.for.sure.safenet/
The beaker SAFEbrowser poc already allows you to browse without the proxy (not tested with alpha yet, though. YMMV). Although (for now) you need to compile and rebuild it etc (which is a pain, I understand).
I’m going to look at updating the POC soon, which should enable compilation (at least for OSX) so accessing SAFE sans proxy will become actually accessible. Then we can start to look at dropping this .safenet lark!
will this alpha run all the way until beta drops or will it close soon?
There will be at least 3 Alpha releases, not weekly, much more every 6 weeks or so, we are not sure yet. Alpha 1 will allow us to set up the release schedule though.
How are the downloads from the website? And how are the droplets? Smoking :grinning:??
I am not sure, the guys will probably check that all on Monday, perhaps we should include this in the dev update actually.
Thanks for that update. Do you think you will turn on the vaults for public use this year? - if you had to guess ? - or is this on track for next year some time?
I will be developing a website for when safenet launches.@anon40790172: lets say a big time exchange wants to use safenet once it launches, will it be easy to port an existing site like Poloniex over to Poloniex.safe ?
Will Test Safecoin be part of one of the Alpha releases?
I really don’t know. Have to move from SQL database to the SAFE protocol with it’s addresses. Polo is quite active and ā€œliveā€ with updating charts. Static websites are probably more easy, but the dynamic ones should work as well.
Thank for the hard work guys! The experience is better than ever!
http://2048.utopik.safenet/ (cloned from GitHub - gabrielecirulli/2048: A small clone of 1024 (https://play.google.com/store/apps/details?id=com.veewo.a1024))
I installed on Ubuntu the safe launcher and the demo app.
How do I launch it? I don’t see any link on my menu (the install didn’t create any start links).
Do i need to start it via command line?
Type in shell :
safe_launcher or safe_demo_app if you followed the apt-get procedure.
