owning an address is not the same as burning a token. If you want to issue SAFE-FS ERC20 tokens to your address and have it, you must burn the same amount of omni SAFE-FS that you currently hold.
Otherwise, more than the total 5 million SAFE-FS coins would exist, which can’t work. It would dilute our market.
You would have to go through the hassle if you want the new version of SAFE-FS coins
