https://groups.google.com/forum/#!topic/maidsafe-development/KfVo-d5Eyx8
David suggested that I post this internal memo onto this public list so the community can see our technical deliberations on the upcoming future of the Maidsafe platform in public and decisions are transparent.
I should explain some context to help readers not versed in this field: RUDP is one of the oldest parts of the code base, and it was originally designed and written by Chris Kohloff, the same engineer behind Boost.ASIO (Boost.Asio - 1.56.0) which is the de facto high performance networking library for C++, and is expected to be standardised as the C++ 17 networking implementation. As a result, its pedigree is second to none.
However, Chris designed RUDP before any of the rest of the Maidsafe design was finished, and he aimed it at a target which ended up never existing. Today’s Maidsafe mostly misuses RUDP and it more just happens to work at all than work well. In particular, the rest of the Maidsafe codebase is threaded, while RUDP is not; RUDP was never designed to tax much more than a single CPU with a 10Mbit network connection let alone multicore CPUs with Gigabit ethernet or even the 4G mobile networks imminent; RUDP’s present design is woefully power inefficient, and blows away the battery on a mobile device in almost no time because low power consumption wasn’t considered; congestion control - this being the algorithms which let RUDP coexist well with other traffic using the same network - never worked well, and has been disabled for a long time now; and the lack of peaceful coexistence with other network traffic makes Maidsafe traffic appear like a DDoS attack, which invites the wrong sort of attention from network providers such as ISPs and mobile networks; lastly we also have a resource management problem in that currently RUDP will accept as much data as you feed it, even if the network will never catch up, which eventually causes us to exhaust RAM.
The below memo sets out a rearchitecture of RUDP to fix all of the above problems. A key theme is “zero copy networking”, you can read more about this at Zero-copy - Wikipedia. Also, reading that ancient-but-still-useful site the C10K problem at The C10K problem is worthwhile, just replace C10K with C100K on modern hardware.
Any thoughts on the below are welcome.
Niall
So rudp will need to be rewritten?
will project safe still be live this year?
