You do have the latest SAFE launcher release? Also, a HTML5 compatible browser?
this looks very much like an issue that several people including me experimented , when using an older version of the launcher. Are you sure you are using 0.4.1, the latest today ?
yea figured maybe thats the issue so i’m downloading it again, not sure which version i had
ok it works.
very impressive.
As a workaround I think you could use NFS API instead and create small files and directories. Directories that are < 100 kb and files that are < 3 kb are stored entirely in SD objects which are adapted for dynamic data. It would bring no weird effects to the user’s profile.
