Private crypto using Zano
I’m a bit confused to see what seems very like a privacy coin BTCx which is a way to make your BTC private (and in future other Blockchain coins, so ANT too).
I thought privacy coins were on the way out due to regulation.
Edge wallet now support BTCx:
Does anyone know if their Revolut integration works in UK?
I’ve not tried it, but I’ve had Revolut reject some (very) old Bitcoin before. No reason given. They just didn’t like the history of them, I assume.
That reason alone is a good reason to have privacy, as otherwise your coins aren’t truly fungible.
regulation is on the way out due to privacy coins. :face_with_hand_over_mouth:
:beer_mug: Budweiser :clinking_beer_mugs: is everybody who already figured out that soon nothing will be shut down :robot:
BYOB “Be your Own Bank" and start transacting and operating peer to peer?
Imo That’ notion is exactly what ‘rips the rug out from underneath the matrix’ and those foisting more regulations on top of what is a very old layer cake of regulations served up to us daily, in their attempt to stay in control, top down. :slight_smile:
That’s what the native Autonomi token ‘NAT’ should enable, the “Rug Rip”
which imo is really the transformation of fiat into RWA backed money,
(your noderunner system revalued to be RWA based on it’s capital worth+utility ability to run nodes)
that can then be ‘mobilized’ to dynamically as a full reserve money,
stake and back layer 3 Peer 2 Peer ANT/$Autonomi currency transactions or SC services involving ANT earning a return,
to provide the liquidity and security needed for transaction volumes.
To re-state the old SUN Microsystems buy line: “The Network is the computer” (John Gage 1984)
with the Autonomi Network supporting the above ‘Rug Rip’ capability,
such a full reserve, liquidity on demand capability means the “The Network is The Money”.
My shameless pitch below to do exactly that, is called “Dynamic Liquidity Ocean” for the Autonomi Network.
DLO is here on gdocs for anyone to read and comment on .
Warning ‘DLO’ is a ‘heavy lift’ reading comprehension exercise, better read with Red Bull or strong teas/black coffee. :wink:
IDK what this is; I’m surrounded by endless matrices and they’re all beating me with electronic dopamine treats to keep me satiated. But I hope it’s cool!
