Possible to get gas cost estimate using the rust API?
Hello fellow developers. I’m doing some polishing on Colony and realized I’m missing a big piece of the puzzle when doing uploads. The API gives you a way to get the cost in ANT for an upload, but what about the gas? I’ve looked around and I don’t see a way to get this. Maybe I need to dig deeper into the libs themselves? Has somebody else figured this out?
Edit: Even if the Autonomi libs don’t do it, is there some kind of basic calculation I can do, like number of chunks X gas per chunk where gas per chunk is based on the current market rate? I don’t think it has to be super accurate, +/- 10% would be ideal I think, if that’s possible.
It’ll be an EVM function. So look for that interface. Not even sure they do that. They only set the maximum fee per gas
Thanks @neo. I’ll poke around there. I thought for sure somebody else would have something clever I could steal… er.. use :smile: It just seems like something that should be in the core libs, especially while gas is 99%+ of the cost to upload anything. I may have to file an enhancement request ticket for this one.
Yea agreed, even if it’s just an API reexport. Less of a fragmented DX.
I think I observed same operations costing different amounts of gas on arbitrum… Not sure it’s an easy/obvious task…(I think it has to do with L1 & L2 gas and arbitrum balancing something …)
Thanks @riddim. That makes sense. I’ll probably just drop the upload cost calculation until there is some more clarity. Maybe this gets better when we get the paymaster stuff in place.
When you think about it, there is no reason the client needs to know the fees estimate. (I think it should)
  • it tells the EVM the max gas fee
  • the EVM does the transactions specifying the max fee per gas
  • If the ARB network rejects the transaction(s) then the client reports the error.
At no time does it actually need to have an estimate on the eth fees.
And I doubt they will introduce that extra complexity anytime soon
I agree that the client doesn’t care, but the end user does.
Interesting, the docs say that the CLI file cost will return both ANT and gas cost, but only ANT cost is returned when I tested it: autonomi/ant-cli at main · maidsafe/autonomi · GitHub
