I was running a local baby-fleming with the std 11 nodes and noticed this
willie@gagarin:~$ safe files put -r /fgfs/fguk/Satnightroutes/
Error:
0: ClientError: Error received from the network: InsufficientAdults { prefix: Prefix(), expected: 4, found: 3 } for cmd: MsgId(78e3..8d0a)
1: Error received from the network: InsufficientAdults { prefix: Prefix(), expected: 4, found: 3 } for cmd: MsgId(78e3..8d0a)
2: Failed to store data. Insufficient replication count at section Prefix(). Expected 4, found 3.
sn_cli/src/subcommands/files.rs:218
Grepping for “insufficient” in the logs threw up another surprise - this time in Italiano …
willie@gagarin:~/projects/maidsafe$ grep -rn insufficient ~/.safe/node/baby-fleming-nodes/
/home/willie/.safe/node/baby-fleming-nodes/sn-node-9/chunkdb/0/0/0/0/0/1/0/0/1/0/1/1/0/0/1/0/0/0/0/1/hy13bn1cjceacm4f5zk8aksjtzrkfejpisf9u7zht4rf54siixzco:15: "Not enough non-option arguments: got %s, need at least %s": "Numero insufficiente di argomenti non opzione: inseriti %s, richiesti almeno %s",
/home/willie/.safe/node/baby-fleming-nodes/sn-node-9/chunkdb/0/0/0/0/0/1/0/0/1/0/1/1/0/0/1/0/0/0/0/1/hy13bn1cjceacm4f5zk8aksjtzrkfejpisf9u7zht4rf54siixzco:33: "Not enough arguments following: %s": "Argomenti insufficienti dopo: %s",
/home/willie/.safe/node/baby-fleming-nodes/sn-node-9/chunkdb/1/0/0/1/1/1/1/1/1/1/1/0/1/0/0/0/1/0/1/1/hu9wmoigoigdhnhaxjmub8ydg43c3y6g44dy8ca1qgs8cqabhboxo:15: "Not enough non-option arguments: got %s, need at least %s": "Numero insufficiente di argomenti non opzione: inseriti %s, richiesti almeno %s",
/home/willie/.safe/node/baby-fleming-nodes/sn-node-9/chunkdb/1/0/0/1/1/1/1/1/1/1/1/0/1/0/0/0/1/0/1/1/hu9wmoigoigdhnhaxjmub8ydg43c3y6g44dy8ca1qgs8cqabhboxo:33: "Not enough arguments following: %s": "Argomenti insufficienti dopo: %s",
Now where did these messages come from? A pizza with your choice of toppings (max 4) for the first person with a sane answer that does not mention Italy
ubuntu@safe:~/safe$ safe files put crow.mkv
Error:
0: ClientError: Error received from the network: InsufficientAdults { prefix: Prefix(), expected: 4, found: 0 } for cmd: MsgId(7cfc..3c3a)
1: Error received from the network: InsufficientAdults { prefix: Prefix(), expected: 4, found: 0 } for cmd: MsgId(7cfc..3c3a)
2: Failed to store data. Insufficient replication count at section Prefix(). Expected 4, found 0.
ubuntu@safe:~/safe$ grep -rn Insufficient ~/.safe/node/baby-fleming-nodes/
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24213: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24240: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24252: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24271: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24288: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24308: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24320: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24332: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24351: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24385: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24423: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24429: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24437: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24453: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24467: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24475: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24483: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24492: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24504: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24510: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24544: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24552: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24555: ➤ InsufficientAdults for storing data reliably
/home/ubuntu/.safe/node/baby-fleming-nodes/sn-node-genesis/sn_node.log:24561: ➤ InsufficientAdults for storing data reliably
Are you seeing GETs when you expect PUTs? Or did you not get to PUT any chunks at all?
Also is vdash reporting sane values for space available and space free across all nodes?
Does the load show anything other than zero ?
I know load was working ok a week or so back but its only showing zeroes now . Im about to write this up as a GH issue for @happybeing but I’ll wait to see if you can confirm any of it.
I would hang fire I think it’s due to the nodes getting voted off ass the the network is set to be overly strict at the minnute. If I understood Weekley update correctly?
I rebooted the box cos upgrades and started agian. I got no errors about insufficient elders. Again the vault size was shown as 2.1GB and when I filled that it stopped. I cannot quickly see where this max vault size is being set.
There is no --max-capacity value set on the sn_node processes as shown by ps aux and there are no leftover env variables set from old comnet-install runs.
What vault size are you seeing on vdash?
I launched such a big recursive put more than one hour ago. Not with baby fleming, but compiled from latest safe_network source. Directory size to upload is 776 MB (release directory of safe_network crate).
It’s still running. The Grafana dashboard on one of my adults shows this:
I compiled here a couple of days ago, run-baby-fleming just launches 11 sn_node processes with whatever is in .safe/node/sn_node - safe_network 0.58.5 for me
Aye, @yogesh has just noticed the same working on some droplet logging. That’ll get looked into soon.
Can baby-fleming launch 15 nodes? I generally use the cargo run --release --bin testnet for launching nodes (which you can configure, but also defaults to 15 nodes).
11 nodes was throwing this error up oreviously. I think related to the membership flow. There may not be all the nodes joined as yet (due to the way node joins work atm). So with 15 this was largely avoided.
(This should be sorted w/ the upcoming membership work, but also I think 15 seems like a better default number as that’s what sections will have as a lower bound after the genesis section)
I changed safe_network/sn/src/node/cfg/config_handler.rs to give a default 10GB node Update config_handler.rs · safenetwork-community/safe_network@14a14d1 · GitHub and ran baby-fleming with 20 nodes. Then ran out of memory on a box with 32GB RAM and the same in swap and saw a peak 1min CPU load of >5000 while trying to put 2.6Gb of photos. Probably best not to try this at home, folks.
However I can confirm baby-fleming will run with 15 and 20 nodes with default 1 sec wait between nodes. I also started with default 11 nodes and added nodes individually up to a total of 18. Again not for any machine that is doing anything else important at the time.
I am hopeful that we will see less resource-hogging on upcoming releases. But then again is 20-off vaults of 10GB each on a single box a sensible real-world scenario? Or just for eejits like me that want to poke?
EDIT Vdash showed 10.7GB available after I recompiled. Which is strange as it is defined as 10 * 1024 * 1024 * 1024. @happybeing
As a programmer I think your calculation is the preferred one. I think there’s a convention that K is 1000 and k is 1024, so perhaps similarly for M/m and G/g?
