And the REST API
Maidsafe App REST API [DRAFT]
NOTE: This API is subject to change.
The Maidsafe REST API strives to be easy to use, consistent, and flexible for advanced users requiring performance.
Storage Abstractions
Blobs
Data on the SAFE network is stored in Blobs. A Blob can contain text or binary data, and the SAFE network has no upward limit on size. However, local system contraints may apply to maximum size. Each Blob is immutable, once it is stored it cannot be modified.
Container
A Container stores Blobs at keys that have no restrictions (any sequence of bytes are valid). Each key is versioned, so past Blobs can be retrieved (which gives the appearance of mutability since a new Blobs can be stored at an existing key).
Storage
Storage has 0 more Containers. The Storage can be public, private, or privately-shared.
StorageID
A StorageID identifies a particular Storage instance on the SAFE network, and contains the necessary information to decrypt the contents.
Behavior Overview
Every REST API function call that requires a network operation returns a Future<T> object. This prevents the interface from blocking, and provides an interface for signalling completion. Every Future<T> object in the REST API returns an expected object, which either holds the result of the operation or a network related error. An expected object allows for exception-style programming, return-code style programming, or monadic style programming. When an expected object contains a successful operation, it will have the result of the operation and version information. When an expected object contains a failed operation, it will contain an error code and a retry mechanism that returns a Future<T> with the same type as the original Future<T>.
Examples
Hello World (Exception Style)
bool HelloWorld(maidsafe::nfs::Storage& storage) {
try {
maidsafe::nfs::Container container(
storage.OpenContainer("example_container").get().value().result());
const auto put_operation = container.Put(
"example_blob", "hello world", maidsafe::nfs::ModifyBlobVersion::Create()).get();
const auto get_operation = container.Get(
"example_blob", put_operation.value().version()).get();
std::cout << get_operation.value().result() << std::endl;
catch (const std::runtime_error& error) {
std::cerr << "Error : " << error.what() << std::endl;
return false;
catch (…) {
std::cerr << “Uknown Error” << std::endl;
return false;
return true;
The `.get()` calls after `GetContainer`, `Put` and `Get` indicate that the process should wait until the SAFE network successfully completes the requested operation (the `.get()` is called on the `Future<T>` object). The `Future<T>` object allows a process to make additional requests before prior requests have completed (see [Hello World Concatenation](#hello-world-concatenation)). If the above example issued the `Get` call without waiting for the `Put` `Future<T>` to signal completion, the `Get` could've failed. So the `Future<T>` will signal when the result of that operation can be seen by calls locally or remotely.
The Future<T> returns a boost::expected object. In this example, exception style error-handling was used, so .value() was invoked on the boost::expected. The .value() function checks the error status, and throws std::system_error if the boost::expected object has an error instead of a valid operation.
The Put call uses ModifyBlobVersion::Create() to indicate that it is creating and storing a new file. If an existing file exists at example_blob, then an exception will be thrown in the Get call because put_operation contains an error (so after running this program once, all subsequent runs should fail). The Get call uses the BlobVersion returned by the Put, guaranteeing that the contents from the original Put (“hello world”), are retrieved. Alternatively, RetrieveBlobVersion::Latest() could’ve been used instead, but if another process or thread updated the file, the new contents would be returned, which may not be “hello world” as desired.
Hello World Retry (Return-Code Style)
namespace {
template<typename Result>
boost::optional<maidsafe::nfs::BlobOperation<Result>> GetOperationResult(
maidsafe::nfs::ExpectedBlobOperation<Result> operation) {
while (!operation) {
if (operation.error().code() != std::errc::network_down) {
std::cerr <<
"Error: " << operation.error().code().message() << std::endl;
return boost::none;
operation = operation.error().Retry().get();
return *operation;
bool HelloWorld(maidsafe::nfs::Container& storage) {
const boost::optional<maidsafe::nfs::BlobOperation<>> put_operation(
GetOperationResult(
storage.Put(
“example_blob”, “hello world”, maidsafe::nfs::ModifyBlobVersion::Create()).get()));
if (put_operation) {
const boost::optional<maidsafe::nfs::BlobOperationstd::string> get_operation(
GetOperationResult(
storage.Get(
“example_blob”, put_operation->version()).get()));
if (get_operation) {
std::cout << get_operation->result() << std::endl;
return true;
return false;
This example starts from the `Container` object for brevity. It is identical to the [hello world](#hello-world) example, except `Put` and `Get` operations that failed due to the network being down (no connection) are retried. In production code you may want to limit the attempts, or have a signal that indicates the return of network connectivity.
If the retry mechanism returns std::errc::not_supported then no retry is possible. It is important that clients check the error code after a retry, or clients could continually attempt an operation that will never succeed.
Hello World (Monad Style)
bool HelloWorld(const maidsafe::nfs::Storage& storage) {
namespace nfs = maidsafe::nfs;
return nfs::monadic(storage.OpenContainer(“example_container”).get()).bind(
[](nfs::ContainerOperation<nfs::Container> open_operation) {
open_operation.result().Put(
"example_blob", "hello world", nfs::ModifyBlobVersion::Create()).get()).bind(
[&open_operation](nfs::BlobOperation<> put_operation) {
open_operation.result().Get("example_blob", put_operation.version()).get());
}).bind([](nfs::BlobOperation<std::string> get_operation) {
std::cout << get_operation.result() << std::endl;
}).catch_error([](std::error_code error) {
std::cerr << "Error: " << error.message() << std::endl;
return boost::make_unexpected(error);
}).valid();
This is an example of monadic programming, which is better described in the [Expected](#expected) documentation. The callbacks provided to the `bind` function calls are only invoked if the operation was successful, and the `catch_error` callback is only invoked if *any* of the previous operations failed. This eliminates the need for client code to check for errors after each operation. Also, in this example all values are *moved*, not copied, so it is efficient as well.
Using monadic programming with boost expected will require the usage of maidsafe::nfs::monadic.
bool HelloWorld(maidsafe::nfs::Container& container) {
auto put_part1 = container.Put(
"split_example/part1", "hello ", maidsafe::nfs::ModifyBlobVersion::Create());
auto put_part2 = container.Put(
"split_example/part2", "world", maidsafe::nfs::ModifyBlobVersion::Create());
const auto put_part1_result = put_part1.get();
const auto put_part2_result = put_part2.get();
if (put_part1_result && put_part2_result) {
auto get_part1 = container.Get(“split_example/part1”, put_part1_result->version());
auto get_part2 = container.Get(“split_example/part2”, put_part2_result->version());
const auto get_part1_result = get_part1.get();
const auto get_part2_result = get_part2.get();
if (get_part1_result && get_part2_result) {
std::cout <<
get_part1_result->result() <<
get_part2_result->result() <<
std::endl;
return true;
return false;
In this example, both `Put` calls are done in parallel, and both `Get` calls are done in parallel. Each `Get` call cannot be requested until the corresponding `Put` operation completes. Also, these files are **not** stored in a child `Container` called "split_example", but are stored in the `container` object directly.
This examples uses the -> operator on the boost::expected object instead of .value() like in the exception example. The -> operator does not check if the boost::expected has an error (similar to -> being unchecked for boost::optional); the conversion to bool in the if statement is the check for validity.
REST Style API
All public functions listed in this API provide the strong exception guarantee. All public const methods are thread-safe.
StorageID
maidsafe/nfs/storage_id.h
- Thread-safe Public Functions
- Copyable
- Movable
Represents the StorageID abstraction listed above. Obtaining relevant StorageID objects are out of the scope of this document.
class StorageID { /* No Public Elements */ };
BlobVersion
maidsafe/nfs/blob_version.h
- Copyable
- Movable
Blobs stored at the same key are differentiated/identified by a BlobVersion object. The BlobVersion allows REST API users to retrieve older revisions of Blobs, or place constraints on operations that change the blob associated with a key.
class BlobVersion {
static BlobVersion Defunct();
- Defunct()
- Returns a
BlobVersion that is used to indicate a deleted Blob. This is never returned by a BlobOperation, and is only used when retrieving the history of the Blobs stored at a key.
ContainerVersion
maidsafe/nfs/container_version.h
- Copyable
- Movable
Containers are also versioned, but none of the REST API functions accept a ContainerVersion. This class is mentioned/returned by Container operations for users that wish to use the Posix API in some situations.
class ContainerVersion { /* No Public Elements */ };
ModifyBlobVersion
maidsafe/nfs/modfy_blob_version.h
- Copyable
- Movable
Operations in Container that change the Blob stored at a key require a ModifyBlobVersion object.
class ModifyBlobVersion {
static ModifyBlobVersion Create();
static ModifyBlobVersion Latest();
ModifyBlobVersion(BlobVersion);
- Create()
- Returns an object that indicates the REST API should only succeed if the specified key is unused.
- Latest()
- Returns an object that indicates the REST API should overwrite any existing Blob at the specified key.
- ModifyBlobVersion(BlobVersion)
- Creates an object that indicates the REST API should only overwrite the Blob at the specified key if it matches the BlobVersion.
RetrieveBlobVersion
maidsafe/nfs/retrieve_blob_version.h
- Copyable
- Movable
Operations in Container that retrieve a Blob stored at a key require a RetrieveBlobVersion object.
class RetrieveBlobVersion {
static RetrieveBlobVersion Latest();
RetrieveBlobVersion(BlobVersion);
- Latest()
- Returns an object that indicates the REST API should retrieve the latest Blob stored at the specified key.
- RetrieveBlobVersion(BlobVersion)
- Creates an object that indicates the REST API needs to retrieve a specific Blob version stored at the specified key.
ContainerOperation
maidsafe/nfs/container_operation.h
- Copyable
- Movable
Most REST API users should only need to invoke the result() function to retrieve a Container returned in a Storage::OpenContainer call. A version is returned for consistency with BlobOperations, and for users that wish to use the Posix API in some situations.
template<typename T = void>
class ContainerOperation {
const ContainerVersion& version() const;
const T& result() const; // iff T != void
BlobOperation
- Copyable
- Movable
Every operation on Blobs return a BlobOperation object.
class BlobOperation {
const BlobVersion& version() const;
- version
- Returns the
BlobVersion involved in the operation.
- result()
- If the operation is NOT void, this will return the result of the operation. Compile error on void.
OperationError
maidsafe/nfs/operation_error.h
- Copyable
- Movable
This object is returned if a network operation fails.
In the event of a failure, retrieving the cause of the error and a Retry attempt can be done with the OperationError interface. The error is a std::error_code object, and the retry attempt will return a new Future object with the exact type of the previous failed attempt.
template<typename ExpectedOperation>
class OperationError {
using RetryResult = Future<boost::expected<ExpectedOperation, OperationError<ExpectedOperation>>;
RetryResult Retry() const;
std::error_code code() const;
- Retry
- Return a Future to another attempt at the failed operation. Be careful of infinite loops - some operations could fail indefinitely (ModifyBlobVersion::Create() for example). If the retry returns an error code
std::errc::not_supported, then a retry is not possible.
- code()
- Return error code for the failed operation.
Future
maidafe/nfs/future.h
- Copyable
- Movable
Currently maidsafe::nfs::Future is a boost::future object, but this may be changed to a non-allocating design. It is recommended that you use the typedef (maidsafe::nfs::Future) in case the implementation changes.
In the REST API, the Future will only throw exceptions on non-network related errors (std::bad_alloc, std::bad_promise, etc.). Values and network related errors are returned in a boost::expected object.
template<typename T>
using Future = boost::future<T>;
Expected
When a network operation has completed, the future will return a boost::expected object. On network errors, the boost::expected object will contain a OperationError object, and on success the object will contain a BlobOperation or a ContainerOperation object depending on the operation requested. For convenience, the templated types ExpectedContainerOperation<T> and ExpectedBlobOperation<T> are provided, where T is the result of the operation (i.e. a std::string on a Get request). Both types assume OperationError as the error object for the operation.
maidsafe/nfs/expected_container_operation.h
- Copyable
- Movable
using ExpectedContainerOperation =
boost::expected<ContainerOperation<T>, OperationError<ContainerOperation<T>>>;
maidsafe/nfs/expected_blob_operation.h
- Copyable
- Movable
using ExpectedBlobOperation =
boost::expected<BlobOperation<T>, OperationError<BlobOperation<T>>>;
Monadic
The REST API returns ExpectedContainerOperation<T> or ExpectedBlobOperation<T> objects which use an error type that depends on T. This makes monadic programming difficult because the unwrap functions in boost::expected will not work as desired. The REST API includes some standalone functions that return a boost::expected object with a consistent error type, std::error_code. After removing the OperationError<T>, retrying the failed operation is not possible. An example of the standalone functions in use.
boost::expected<BlobOperation<T>, std::error_code> monadic(
const ExpectedBlobOperation<T>& expected);
template
boost::expected<BlobOperation, std::error_code> monadic(
ExpectedBlobOperation&& expected);
boost::expected<ContainerOperation<T>, std::error_code> monadic(
const ExpectedContainerOperation<T>& expected);
template
boost::expected<ContainerOperation, std::error_code> monadic(
ExpectedContainerOperation&& expected);
Storage
maidsafe/nfs/storage.h
- Copyable
- Movable
This object has a single shared_ptr, and is shallow-copied. This makes it extremely quick to copy.
Represents the Storage abstraction listed above. Constructing a Storage object requires a StorageID object.
class Storage {
explicit Storage(StorageID);
Future<ExpectedContainerOperation<std::vectorstd::string>> GetContainers();
Future<ExpectedContainerOperation> OpenContainer(std::string);
Future<ExpectedContainerOperation<>> DeleteContainer(std::string);
- **Storage(const StorageID)**
- Creates a Storage object. The `StorageID` provides the keys necessary for decrypting the data.
- **GetContainers()**
- Retrieves the names of containers currently in Storage.
- **OpenContainer(std::string)**
- Retrieves a `Container` with the specified name. The Container is created as necessary.
- **DeleteContainer(std::string)**
- Deletes a container with the specified name.
Container
maidsafe/nfs/container.h
- Copyable
- Movable
Represents the Container abstraction listed above. Constructing a Container object cannot be done directly; Container objects can only be retrieved from Storage::OpenContainer.
class Container {
Future<ExpectedContainerOperation<std::vector<std::pair<std::string, BlobVersion>>>> GetBlobs();
Future<ExpectedContainerOperation<std::vector>> GetBlobVersions(std::string key);
Future<ExpectedBlobOperation<>> PutMetadata(
std::string key, std::string, ModifyBlobVersion);
Future<ExpectedBlobOperationstd::string> GetMetadata(std::string key, RetrieveBlobVersion);
Future<ExpectedBlobOperation<>> Put(std::string key, std::string, ModifyBlobVersion);
Future<ExpectedBlobOperationstd::string> Get(std::string key, RetrieveBlobVersion);
Future<ExpectedBlobOperation<>> Delete(std::string key, RetrieveBlobVersion);
Future<ExpectedBlobOperation<>> ModifyRange(
std::string key, std::string, std::uint64_t offset, ModifyBlobVersion);
Future<ExpectedBlobOperationstd::string> GetRange(
std::string key, std::size_t length, std::uint64_t offset, RetrieveBlobVersion);
Future<ExpectedBlobOperation<>> Copy(
std::string from, RetrieveBlobVersion, std::string to, ModifyBlobVersion);
- **GetBlobs()**
- Retrieves the names of Blobs in the Container. The `BlobVersion` is provided for each Blob.
- **GetBlobVersions()**
- Retrieves the history of `BlobVersion`s at the key. Oldest BlobVersion is always `BlobVersion::Defunct()`, and is used subsequently when the key had no associated Blob for some period of time. `std::vector::begin()` will be the newest `BlobVersion`, and `std::vector::end() - 1` will have the oldest `BlobVersion` (which is always `BlobVersion::Defunct()`).
- **PutMetadata(std::string key, std::string, ModifyBlobVersion)**
- Stores the contents at the key as user metadata. Same effect as storing a blob (new BlobVersion). Maximum size is 64KB.
- **GetMetadata(std::string key, RetrieveBlobVersion)**
- Retrieves the user controlled metadata for a Blob.
- **Put(std::string key, std::string, ModifyBlobVersion)**
- Stores the Blob contents at the key.
- **Get(std::string key, RetrieveBlobVersion)**
- Retrieves the Blob contents at the key.
- **Delete(std::string key, RetrieveBlobVersion)**
- Removes the key from the Container.
- **ModifyRange(std::string key, std::string, std::uint64_t offset, ModifyBlobVersion)**
- Stores a new Blob by re-using a portion of an existing Blob. The size of the Blob is automatically extended if offset exceeds the size of the original Blob.
- **GetRange(std::string key, std::size_t length, std::uint64_t offset, RetrieveBlobVersion)**
- Retrieves a portion of the Blob contents at the key. Returned std::string is automatically truncated if length + offset exceeds Blob size.
- **Copy(std::string from, RetrieveBlobVersion, std::string to, ModifyBlobVersion)**
- Copies user metadata + data from a Blob at one key to a Blob at another key.
