anyone still managing anything ?
im trying a put and a cat and its looking like its hanging ![]()
Damn I take 2 mins out from charades to catch up and you broke it already…
45 nodes, vcpu4-8gb droplets.
I’m seeing some node full errors! That went faster than I’d anticipated
This seems to be stuck for me too now.
yeap it seems down
safe cat safe://hygoygyybjxqmgxq83kq8me8fei6ohfg8q4ph8tg15h999rsais1as88871eo > racer.jpg
^[[A^[[B^[[D^[[CError:
0: NetDataError: Failed to GET Blob: NoResponse
/rustc/f1edd0429582dd29cccacaf50fd134b05593bd9c/library/core/src/result.rs:1914
Backtrace omitted.
Dead?
Was about to give it a go ![]()
it was a nice present anyhow!!! ![]()
someone didn’t read the OP?
Nice to see, hope it was useful.
Aye we seem to have flooded it. Definitely I did not expect that to go so fast. But seeing:
"Avg storage usage among Adults is between 70-80 %" logged (and they’re considered full at 90%.
I’ll trawl the logs over the weekend to see if that’s a valid number or the storage calc is off.
It also doesn’t make sense that GET should fail either.(edit: as the network fills I mean) So something to look at there.
Hopefully we’ll be back with another one for you soon enough!
Fair play.
From sounds of it, it was super fast until it got full ![]()
I observed some “lag” in this testnet, on older testnets it would be instant, not in this testnet!
@Southside trying to safe cat when he gets home later
Oof, blink and you miss it. Or, in my case, slumber in a chair with a book on your lap, because of a hard week and a large glass of mulled wine, and you miss it. Check the logs, dot the i s and cross the t s. Awesome effort Safe and community.
This is what a call a flash net, it came and went so fast I couldn’t even turn on my PC to give it a try. MerryX
I suspect we need to consider folk will flood it as soon as they can. So we probably do need farming and DBC transfers in place. Otherwise folk will upload the world as soon as we make it available, which is probably a good test.
In the end of course, but meanwhile bigger nodes and expanding network should give longer uptime for sure.
Absolutely, also though flooding should only fill it and definitely not have it lose data. So we need to kill that bug. I suspect the fill flag is stopping data relocating. Paging @yogesh on this one
Good work all! Too late to the party, but I see that there are some interesting results, and that’s what counts.
Waiting eagerly for a next testnet. Hope I will not be too late for the next one…
An observation from combing the testnet logs: There seems to be an issue with nodes trying to join the network. The network, once it notices that it reaches an X%(configurable) of avg storage capacity, it is designed to start accepting new nodes as demand for resources increases. This consequently triggers data relocation within the section and its Adults rearrange the data they hold. Moreover, we do have the always-joinable flag set to true in this testnet, meaning the network should take new nodes no matter what capacity it is at.
Since nodes are not able to join, which mainly seems to be due to connection timeouts at first glance, we start snowballing downhill and the network does not take any new data nor does it relocate the already present data. And if Adults that are present, leave at this point, they leave with the data resulting in a data loss and coupling that with connection timeouts during GETs makes data ungettable. So seems like we have some communication shenanigans when dealing with high throughput amongst nodes here(which we haven’t seen to this extent when testing internally, so thanks to the community for showing its strength
We should though relocate the data to the remaining Adults at least. Something to look into.
