Can you please publish FOUNDATION_PK
, GENESIS_PK
and NETWORK_ROYALTIES_PK
so we could connect to the network with API? Thanks. cc @chriso
edit: Found it myself:
FOUNDATION_PK: b20c916c7a28707018292f06dfdb66ab88ebcbad9c78d18135e843a91b1d66b875b24d2c27d8d1ad4637c2d5811896fe
GENESIS_PK: 93f7355906fa8c1a639bac80f4619dbb4cf5f71c47827d1ff2c30f0d133f6b841859662cbf7e0bbceca0eb0f521f6ebc
NETWORK_ROYALTIES_PK: af451aa34a0d16c50eb217b91ab6b2ca75ef43b9c20449384ff1e90dbf8477351499cca985828e33b208805dadc80c63
PAYMENT_FORWARD_PK: adc6401588af49c60af6717a60546207abddb4e150014b4ab6c407ef6d7b3d3899b8892a91ab23042378b7b285e655fc
In GitHub repo go to Actions tab, filter workflow runs by branch (stable), click a release workflow run, and then under Jobs on the left, select one of starting with build. Then, on the right you’ll see list of logs, select build release artifacts and search for PKs.
Check out the Dev Forum
