Node-launchpad TUI
Right, cool, thanks.
Yeah, the auto restart has now been bumped up to a very high priority issue and will be dealt with before the beta launch. Thanks for the feedback.
Edit: in both the node manager and the launchpad.
i think that’s a very good time point to having removed the autostart - yes :slight_smile: … people will want to go up in node count then and test out their limits … might well result in blocked systems otherwise …
Actually, I just want to make sure we’re talking about the same thing here.
When I say “auto restart”, what I mean is that the services will automatically start after the operating system has rebooted.
Do you mean the same thing? Or are you talking about the launchpad starting all the nodes after resource allocation?
exactly what i’m talking about - yes
ps: after reboot / user login (user services)
Has anyone had any success in starting a small no of nodes?
say 20 ish and then allocating more resources - hit O and change 100 to 150 to give 30 nodes?
I can get 20 nodes started OK but cannot add any more, not 10 not 4, not 2…
Yep once again failing to start >20 nodes
2024-05-30T18:58:35.279533Z DEBUG sn_node_manager/src/cmd/node.rs:101: Parsing peers...
2024-05-30T18:58:35.279563Z  INFO sn_peers_acquisition/src/lib.rs:88: Using peers supplied with the --peer argument(s) or SAFE_PEERS
2024-05-30T18:58:44.220073Z ERROR node-launchpad/src/components/home.rs:401: Error while maintaining 24 running nodes
   0: Failed to add one or more services
Suggestion: However, any services that were successfully added will be usable.
2024-05-30T18:58:44.220122Z DEBUG node-launchpad/src/app.rs:139: HomeActions(ServiceManagerOperationCompleted)
2024-05-30T18:58:44.220307Z  INFO node-launchpad/src/components/home.rs:82: Loaded node registry. Runnign nodes: 20
Remind me to submit a trivial PR to sort “Runnign” - Its doing my spelling-nazi head in…
EDIT: done PR #1795
Yes, I went from 1 to 5 to 10 in stages by changing resource allocation and using ctrl+g to start them
Let me know how you get on trying to get over 20
I just restarted there with 80Gb (16 nodes) and then added another 40GB to take me to a notional 24
Launchpad currently won’t show me any more than 20 nodes here.
Has anyone seen launchpad display >20 nodes?
EDIT: Yes @anon26713768 see below
and in the launchpad logs there is little to be gleaned other than it now thinks its running 20 nodes but admits there was an error trying for 24. Doesnt say much about the error - though I have still to look at node-launchpad/src/components/home.rs:401
2024-05-30T22:16:50.194874Z DEBUG node-launchpad/src/app.rs:139: HomeActions(StartNodes)
2024-05-30T22:16:50.194884Z  INFO node-launchpad/src/components/home.rs:205: Running maintain node count: 24
2024-05-30T22:16:50.195571Z  INFO sn_node_manager/src/cmd/node.rs:588: We are adding+starting 4 nodes + starting these services: ["safenode17", "safenode18", "safenode19", "safenode20"] max_nodes_to_run=24 to_add_count=4
2024-05-30T22:16:50.196317Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/reqwest-0.12.4/src/connect.rs:497: starting new connection: https://crates.io/
2024-05-30T22:16:50.196532Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/hyper-util-0.1.3/src/client/legacy/connect/dns.rs:122: resolving host="crates.io"
2024-05-30T22:16:50.197541Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/hyper-util-0.1.3/src/client/legacy/connect/http.rs:622: connecting to 143.204.194.57:443
2024-05-30T22:16:50.211340Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/hyper-util-0.1.3/src/client/legacy/connect/http.rs:625: connected to 143.204.194.57:443
2024-05-30T22:16:50.211412Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/rustls-0.22.4/src/client/hs.rs:78: No cached session for DnsName("crates.io")
2024-05-30T22:16:50.211517Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/rustls-0.22.4/src/client/hs.rs:131: Not resuming any session
2024-05-30T22:16:50.225665Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/rustls-0.22.4/src/client/hs.rs:605: Using ciphersuite TLS13_AES_128_GCM_SHA256
2024-05-30T22:16:50.225697Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/rustls-0.22.4/src/client/tls13.rs:144: Not resuming
2024-05-30T22:16:50.225859Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/rustls-0.22.4/src/client/tls13.rs:389: TLS1.3 encrypted extensions: [ServerNameAck, Protocols([ProtocolName(687474702f312e31)])]
2024-05-30T22:16:50.225879Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/rustls-0.22.4/src/client/hs.rs:469: ALPN protocol is Some(b"http/1.1")
2024-05-30T22:16:50.826122Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/hyper-util-0.1.3/src/client/legacy/pool.rs:397: pooling idle connection for ("https", crates.io)
2024-05-30T22:16:50.860730Z DEBUG /home/runner/.cargo/registry/src/index.crates.io-6f17d22bba15001f/rustls-0.22.4/src/common_state.rs:492: Sending warning alert CloseNotify
2024-05-30T22:16:51.018604Z DEBUG sn_node_manager/src/cmd/node.rs:101: Parsing peers...
2024-05-30T22:16:51.018624Z  INFO sn_peers_acquisition/src/lib.rs:88: Using peers supplied with the --peer argument(s) or SAFE_PEERS
2024-05-30T22:16:51.646554Z ERROR node-launchpad/src/components/home.rs:401: Error while maintaining 24 running nodes
2024-05-30T22:16:51.646593Z DEBUG node-launchpad/src/app.rs:139: HomeActions(ServiceManagerOperationCompleted)
2024-05-30T22:16:51.646971Z  INFO node-launchpad/src/components/home.rs:82: Loaded node registry. Runnign nodes: 20
Like such?
OK so the problem is NOT that launchpad will only ever display 20 nodes - ticks that off the list…
CPU usage? I am adding another 10 to my 10 nodes and the cpu usage (4 cpu, 4 thread) hits 100% as it starts them all at once. So nodes falling over is more likely under launchpad than using the manager with long interval. [EDIT:] Waiting till cpu settles before adding more
[EDIT:] added one more when cpu was down a tad and it added OK. Will try 4 more when CPU settled more
[EDIT:] CPU down at 50% so added 4 more and have all 25 nodes running (this is on my Odyssey SBC)
Not CPU usage AFAICS - the graph shows me repeatedly pressing ctrl-G half a dozen times - it goes from maybe 5 to 10%
Now this is a Ryzen 3600 with 32Gb RAM, not an old dual Xeon but thats not it…
I have still to clear out / and move a lot of stuff to the backup machine. I can get rid of 100s of gigs of scenery for my flightsim as now I have got fibre installed, I can load the scenery on the fly as I fly :slight_smile:
So lets see what if anything changes when I present launchpad with 7-800Gb free rather than 300. Which should still be enough to load 60 nodes anyway…
BTW, my OS is opensuse if that makes a difference
and with 25 nodes its settled down to around the 60% cpu usage, I’ve had 30 on this machine and usage was lower so I expect it to drop more as the new nodes establish themselves.
Also the nodes start with home-network using launchpad. Not sure how it worked out it had to since autonat isn’t there yet, or is it? Starlink doesn’t allow uPnP or port forwarding
Anyhow I am going to drop it back to 10 nodes since the nat table get overwhelmed with 30 nodes and takes a long while to clear out even when reducing nodes. Internet becomes sluggish with too many even though plenty of b/w available for 30 nodes
Im at 3-4% with 16 nodes. Even when I was running 80 nodes, it was my ISP router that was giving up, CPU usage simply was not a factor.
I set one of my laptops as exposed host from my router and I am now starting nodes on that to see if there’s any difference in shunning etc. compared to upnp and homenetwork.
Some notions as I start my nodes in sets of 3, waiting the CPU load to cool down in between.
  1. I press O to increase capacity, then increase it with arrow keys from 15 to 30, and then press enter.
  2. Should I now assign the discord user name to these nodes again, or does the name applied to first batch of three apply to these nodes too?
  3. I didn’t type the discord username. There is nothing on the view that would indicate if the discord username is applied to some nodes and not others.
  4. I think that if user has to input some information, like the discord user name, it would be cool for the program to verify that it has indeed taken the information. It could for example display it on the same line as other information about nodes - as it’s own column. Then, if I see I have mistyped the name, the ability to correct it would be cool.
1 should give you 6 nodes
2 you only need to enter this once, but it doesn’t hurt to hit D and check that your discord name is still displayed
3 see above
4 the UX will get tweaked soon enough, for now the focus is on core functionality - someone (@joshuef ?) said so the other day - an associated discord name column is a great idea.
Unless you have deliberately nuked ~/.local/share/safe/launchpad/config/ then the last selected dedicated disk space and username will persist between runs.
V0.3.0 Alpha release
Does not work much, but looks nicer
appears to be working for me :slight_smile:
you need to use the power shell to install safenode manager and then use safe up to install node-manager.
I has the same problem but on Win11, I am parked until the GUI and matching release shows up, then I will start in on it again.
