I read the SAFE Network primer but didn’t get one thing.
WHY USE A CENTRALISED PROXY SERVER RATHER THAN EXISTING P2P ANONYMITY PROJECTS LIKE TOR OR I2P???
Don’t say that this too has already been discussed.
What do you mean by centralised proxy server? That’s not how it works.
Its built in decentralised routing ensures anonymity.
Any visitors requesting resources from the SAFE Network needs to access the network through a proxy server. These were clearly written in the primer
A proxy node, not a server. It’s just a way of connecting to the network through a random point of contact. It’s not centralised, and is where your IP address is stripped.
If you can indicate the relevant text we can see if it needs clarifying.
EDIT: @JPL see below.
It is better referred to as a bootstrap node. Any node that can give you other nodes to connect to. We recently made this more clear in the code. So the process is
Join these nodes.When joined client or vault can confirm the correct network via the chain of section authorities. It can go all the way back to genesis section if required.
The word proxy was confusing, it was valid in Alpha II but now it’s just a dumb bootstrap node and any vault can do it.
Clients connect via a Proxy Node
To ensure anonymity, the identity of a Client connecting to the Network must be hidden from the nodes (Vaults) that comprise it. For this reason, the initial connection between a Client and a Vault always occurs via a Proxy Node. The Proxy Node knows the Client’s IP address and will allow it to connect to a Section. The Vaults cannot see the Client’s IP address but they know its public key and XOR address. All connections between the Client and the Group(s) are fully encrypted.
The Proxy Node provides a service to the user, connecting him or her to the Network without having any knowledge of activity thereafter. The Group of Vaults to which the user is connected might know a little about what the user is doing on the Network but they can only identify the user by their XOR address and not their IP. In this way, complete anonymity is assured.
Taken from SAFE Primer
It will be updated with Fleming.
What’s a Fleming???
Fleming will be the first working Beta release (named after Alexander Fleming). Thanks for bringing up the ‘proxy’ issue. I’ll amend the Primer in due course since we’re no longer using that term. I agree it has misleading connotations.
Also from the primer:
Bootstrap node – a node to which a new node (Vault) initially connects (via a proxy). Any node can potentially be a bootstrap node, so long as its IP address is written in the Vault’s configuration file
Good point - would appreciate some clarification from MaidSafe.
Any Vault can be bootstrapped off of. As long as you have it’s contact details you can ask it for more nodes to connect to until you find your real section. These vaults will not speak to you beyond that as they have nothing to do with your address (you are from another section).
To join the network
send BootrapRequest to any vault. You get back either
BoostrapNodes A set of nodes (Elders) closer to our address than the boostrap vault. To these nodes you again do a BootstrapRequest
OR
JoinNodes The actual nodes you should send a JoinRequest to. these are your section Elders and you are then in the section corresponding to your address.
Because from primer:
Yes, for all nodes, new/old client/vault.
If the node replying to you knows the section Elders you should connect to then you are good. These will at least be neighbors (i.e. Elders in a section that differs in it’s prefix (section address) by exactly 1 bit)
Thank you for the answers until now.
To be clear:
…that initial connection is dropped immediately after the first hop once the new Vault has connected to others in the Network.
–>This is only applicable for a Vault node as part of the relocation process, or is there another step (also for Client nodes) to get a ‘random’ bootstrap node, to prevent overusage of the ones in the distributed configuration file.
Or in the bootstrap cache that is collected as a node works. Any connection that can be used is kept in a cache file. The cache nodes are preferred and only in failure of each of these would a node use the hardcoded endpoints.
No, this is all local to only the boostraping node and the vault it connects to, no network traffic.
The client connects to its section. This is how we cab do push notifications etc. So the clients section elders will know the client IP address, but only them and any node they tried to bootstrap from.
Thanks again for the answers!
The Client Managers know the account balance of a Client but to them it’s just an address in the Network. They don’t know the IP address of the Client nor do they have any knowledge of a username, public identity or anything else that could link the Client to an individual.
What is meant there is that the IP adress is not stored on the network (the Xor address is stored) in the ‘account data’. But the elders of the Client Managers (=elders of Client Section?) know its IP address when the client is connected. That is of course much less of a problem, but was the cause of my confusion.
Yes that is correct. ![]()
Yes it is a bit tricky, but we are OK now I think. Primer is amazing, it covers so much and as we launch we will need to tweak it, but it is gold.
