Invitation Token - Connection not private
When I try to get an invitation token from the Safe Browser it opens a new tab in Chrome but gives me a ’ Your connection is not private’ message from ’ invite.maidsafe.net.’ It also happens when I try to access the site via Chrome directly.
I have had a token issued in the past, but I am using a different computer now and need a new token.
Thanks :slight_smile:
Looks like the certificate has expired. Is there someone at @maidsafe who can check?
In the meantime @IceCream I’ll DM you a new code.
Make sure you use https and not http there
I also get an error indicating that the certificate has expired when surfing to https://invite.maidsafe.net.
Ohhps that is a problem for sure. We need to sort that for sure, cheers @draw :+1:
