Hi guys continuing on with the luck of prior success in my medium article I’m writing another but I need some advice and feedback.
Not sure if we discuss here or on DM.
The article topic is about Farming / Mining and the target are basically anyone that wants to make money and or wants to mine but don’t have the resources or money to mine other cryptos.
I did not see what tech advice you were looking for, specifically, but I think that a budget build for a farming machine is a good place to start. I found some references to other post/articles that were supposed to speak to this topic, but laying-out specifics for people is, obviously, the most user-friendly avenue and can draw-in those that fit the niche of which you speak.
I think the design is pretty good and the copy excellent. Simple to understand and hits the spot.
Only one thing struck me - how about a comparison of energy efficiency? A lot has been said about the increasing amount of energy used in blockchain mining, so I think that’s a weak spot we could target. Just a thought, but great job IMO.
C is a language, not a program. I’m not sure why a user should care much about what language a program is written in. I suspect you are getting at mining software being command line based instead of point and click?
difficulty doesn’t necessarily increase with time. In general this has been the case, because difficulty does increase when more hashing power is added to the network (adjusts dynamically, just as the farming rate will). With Bitcoin, what does change with time is the block reward, which halves approx every 4 years.
