what can i do for increasing my level?
See this topic:
ok, what’s the meaning of entering at least 30 topics ? should i create 30 topics?
No, you just need to access / visit 30 topics.
Same problem here, how did you fix it?
2 days visited
1h read time
252 posts read
Are all conditions needed or is needed at least 1/2?
Yes, all conditions are needed.
You’re almost there
You just need to enter / visit a few more topics (you currently have 23 topics viewed).
do you get upgraded to trust level 1 automatically or is it a manual process ?
Yes, it should happen automatically ![]()
is there a way to see how many you read already and how many you have to go ?
You can see how many posts you’ve read and how much time you’ve spent reading by looking at the Summary tab of your user profile. For example:
But it doesn’t show how many topics you’ve entered / visited.
Go here
https://forum.autonomi.community/u?period=all
topics entered is the column titled “viewed”
posts read is the column titled “Read”
Welcome here! This is my day number one
I’m just getting started and I’ll share my experience of getting to level 1. Best of the SAFE Network, immudoug
The read time is 60 minutes and I suspect that the 1Hr showing is a rounding up. So you may need a little more time reading. Otherwise the discourse software needs a little time to update the member level. Or I have noticed that when a person joined less than 24 hours the discourse software doesn’t update the member level.
I suggest you do some more reading of posts and/or topics and you should be at level 1 soon enough. Otherwise post here again after you’ve done a little more reading and we will do something about it.
Thanks for the response. It eventually updated.
Two posts above yours is the answer And I will repeat it here for you
We have found out that this is indeed the issue. So a little more reading and you should be fine to go
I got it. Thank you @neo!
very helpful instruction
