By your own explanation, I could only possibly have 1 flawed response
I don’t understand this, can you elaborate further please?
The point you are making seems to be that the observable token history is irrelevant. But that is simply not practically possible is it.
It must be. USD all have history. And the history for UTXO coins is not tied to anyone. And anyway, coinjoin completely removes this history! So there are three reasons why your position is wrong.
It is not semantics! The definition of fungibility does not presuppose a nonexistent transaction history. And even if it did, coinjoin completely removes this history so even by your definition UTXO coins that have been coinjoined must be fungible!
You say no, because you can always find some sucker to take tokens that some others won’t take because the history of the tokens is morally repugnant to powerful people who can enforce a ban.
This is a complete misrepresentation of my position. History doesn’t matter because UTXO coins are psuedonymous! That means there is no identifying information tied to an address! Neither receiver nor sender! Which means its impossible to generally track coins! Also, history doesn’t matter because standard usage of UTXO coins since around 2013 or so has been to never reuse addresses! And the third reason is because coinjoin exists and coinjoin completely removes a coin’s history!
These are my arguments, please respond to them only and do not put words in my mouth! That will make the debate much smoother.
You point out that if there was the no ability to censor via history, then they’d simply censor the entire token type.
This is true! Monero does not solve this issue since anyone that bans addresses can ban coins! XMR is the least accepted cryptocurrency out of any of the majors! It is not accepted at more than a couple hundred real life stores. DASH and BTC fore example are both accepted at over 10,000 stores. Over 140,000 stores globally accept DASH in fact! Which means that XMR does not solve the problem.
If you are caught in possession of these tokens you might also fall under their ax and you will still find it difficult to transact in jurisdictions these censors control as many people won’t want to risk taking them
Once again, any fud that you can come up with against UTXO coins must equally apply to XMR, there’s no way around this! Removing the history via encryption doesn’t force people to accept XMR and not blacklist it! Your position is illogical.
Much of this is speculative economics on both sides of the arguments, so not really a point of debate, just your opinion versus mine.
There is nothing speculative about my position, nor are my arguments particularly economically based. My argument is quite simple: the XMR community is misrepresenting fungibility in order to gain an unjustly obtained and undeserved position in the space. UTXO coins are not tied to any person’s identity and thus any tracking is completely voluntary (both sender and receiver have to doxx themselves for it to work). Also XMR doesn’t get around selective censorship so the point is moot! Neither of these arguments are speculative nor economic but cryptographic and fundamental.
But there is a clear distinction between coins that have a history and those that don’t. You can say that what such should be called isn’t ‘fungibility’ … but that is simply semantics.
Coinjoined coins have no transaction history nor transaction graph so this point is completely moot!
So I see no further point in this discussion. You believe what you believe and I believe what I believe.
I accept this as your admission of defeat in this debate. Thank you for participating and enjoy the holiday weekend!
