Tried again with a different Linux device (same router). It looks like I can connect OK but the join process times out. I’d be interested to find out if anyone else is having the same problems creating a new safe.
[user@user ~]$ safe auth create --test-coins
Passphrase:
Password:
Sending request to authd to create a Safe…
Error: AuthdClientError: [Error] ClientError - Response not received: read error: connection closed: timed out
Log:
Summary
[user@user ~] cat ~/.safe/authd/logs/sn_authd.log INFO 2021-04-10T17:12:32.009838479+01:00 [sn_authd/operations.rs:144] Running authd instance from executable at "/home/user/.safe/authd/sn_authd" INFO 2021-04-10T17:12:32.009944551+01:00 [sn_authd/operations.rs:150] authd instance starting (PID: 11465)... INFO 2021-04-10T17:12:32.010006396+01:00 [sn_authd/operations.rs:178] Initialising SAFE Authenticator services... INFO 2021-04-10T17:12:32.010044904+01:00 [sn_authd/authd.rs:34] Bootstrapping with contacts: {138.68.146.110:58306, 138.68.152.156:51182, 138.68.131.228:40591, 178.62.58.241:42766, 138.68.138.75:59177, 138.68.154.35:49429, 46.101.48.69:55130, 138.68.131.218:57691, 138.68.137.76:34625, 138.68.137.198:43750, 138.68.154.164:44520, 138.68.142.144:55064, 188.166.169.192:47334, 138.68.141.132:36390, 138.68.139.58:38972, 46.101.17.63:38981, 138.68.146.15:34651, 138.68.142.76:38701, 46.101.1.135:58214, 46.101.93.86:56133, 138.68.133.17:37599, 46.101.72.229:52737, 138.68.131.119:50694, 188.166.146.65:36220, 138.68.139.187:33546, 46.101.78.184:41244, 188.166.146.115:41339, 178.62.101.46:59428, 178.62.80.163:57378, 46.101.55.62:53141, 139.59.181.74:12000, 138.68.138.179:51519, 138.68.139.28:40613} INFO 2021-04-10T17:12:32.010209133+01:00 [qjsonrpc/src/server_endpoint.rs:51] Generating self-signed certificate... INFO 2021-04-10T17:12:32.010570646+01:00 [sn_authd/authd.rs:130] Listening on [::1]:33000 INFO 2021-04-10T17:12:39.804967553+01:00 [sn_authd/requests/mod.rs:77] Processing new incoming request (3292528409): 'status' INFO 2021-04-10T17:12:39.804999416+01:00 [sn_authd/requests/status.rs:29] Preparing authd status report... INFO 2021-04-10T17:12:39.805010545+01:00 [sn_authd/requests/status.rs:55] Status report sent: AuthdStatus { safe_unlocked: false, num_auth_reqs: 0, num_notif_subs: 0, authd_version: "0.5.0" } INFO 2021-04-10T17:12:39.805248770+01:00 [sn_authd/authd.rs:207] Response sent, request 3292528409 complete INFO 2021-04-10T17:13:16.577766702+01:00 [sn_authd/requests/mod.rs:77] Processing new incoming request (2294570910): 'create' INFO 2021-04-10T17:13:16.577828633+01:00 [sn_authd/requests/create.rs:25] Creating a Safe... INFO 2021-04-10T17:13:16.595417063+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/client/mod.rs:109] Client started for specific pk: PublicKey::Ed25519(c235b32efb60f0aec5ad879c094e4e23fa1b261f55e0b7eaa3d94960d23f0b4d) WARN 2021-04-10T17:13:16.595481982+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/config_handler.rs:73] Failed to open config file from '/home/user/.safe/client/sn_client.config': No such file or directory (os error 2) WARN 2021-04-10T17:13:16.595752563+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/qp2p-0.11.7/src/endpoint.rs:235] Ignoring 'forward_port' flag from config since IGD has been disabled (feature 'no-igd' has been set) WARN 2021-04-10T17:13:16.752940585+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:921] Message received at listener from 138.68.146.110:58306 INFO 2021-04-10T17:13:16.788367427+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 46.101.1.135:58214 WARN 2021-04-10T17:13:16.788438008+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 1 new_elders. INFO 2021-04-10T17:13:16.789995598+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 46.101.48.69:55130 WARN 2021-04-10T17:13:16.790050203+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 2 new_elders. INFO 2021-04-10T17:13:16.790759317+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 46.101.55.62:53141 WARN 2021-04-10T17:13:16.790799158+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 3 new_elders. INFO 2021-04-10T17:13:16.796761287+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 138.68.138.179:51519 WARN 2021-04-10T17:13:16.796838869+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 4 new_elders. INFO 2021-04-10T17:13:16.797826839+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 138.68.131.228:40591 WARN 2021-04-10T17:13:16.797879066+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 5 new_elders. INFO 2021-04-10T17:13:16.798046008+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 138.68.131.218:57691 WARN 2021-04-10T17:13:16.798083059+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 6 new_elders. WARN 2021-04-10T17:15:16.579293018+01:00 [qjsonrpc/src/server_endpoint.rs:160] Failed to read incoming request: timed out WARN 2021-04-10T17:15:16.604536162+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:523] Failed to connect to Elder @ : ElderConnection WARN 2021-04-10T17:15:16.604579105+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 6 new_elders. ERROR 2021-04-10T17:15:46.743569866+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:927] Error handling network info message: QuicP2p(Connection(TimedOut)) WARN 2021-04-10T17:15:46.751458543+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:921] Message received at listener from 46.101.1.135:58214 INFO 2021-04-10T17:15:46.779047233+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 46.101.1.135:58214 WARN 2021-04-10T17:15:46.779088090+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 1 new_elders. INFO 2021-04-10T17:15:46.779764778+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 46.101.55.62:53141 WARN 2021-04-10T17:15:46.779807948+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 2 new_elders. INFO 2021-04-10T17:15:46.784496911+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 138.68.142.76:38701 WARN 2021-04-10T17:15:46.784539617+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 3 new_elders. INFO 2021-04-10T17:15:46.785382149+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 46.101.93.86:56133 WARN 2021-04-10T17:15:46.785428593+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 4 new_elders. INFO 2021-04-10T17:15:46.787676882+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 138.68.131.228:40591 WARN 2021-04-10T17:15:46.787720584+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 5 new_elders. INFO 2021-04-10T17:15:46.789413465+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 138.68.131.218:57691 WARN 2021-04-10T17:15:46.789464326+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 6 new_elders. INFO 2021-04-10T17:15:47.159770158+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 46.101.1.135:58214 WARN 2021-04-10T17:15:47.159847444+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 1 new_elders. INFO 2021-04-10T17:15:47.159880636+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 138.68.142.76:38701 WARN 2021-04-10T17:15:47.159903536+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 2 new_elders. INFO 2021-04-10T17:15:47.159927478+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 46.101.55.62:53141 WARN 2021-04-10T17:15:47.159947616+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 3 new_elders. INFO 2021-04-10T17:15:47.159973515+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 138.68.131.228:40591 WARN 2021-04-10T17:15:47.159994344+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 4 new_elders. INFO 2021-04-10T17:15:47.160010399+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 46.101.93.86:56133 WARN 2021-04-10T17:15:47.160023269+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 5 new_elders. INFO 2021-04-10T17:15:47.170415555+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:527] Connected to elder: 138.68.131.218:57691 WARN 2021-04-10T17:15:47.170478740+01:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.9/src/connection_manager.rs:537] Connected to only 6 new_elders. [user@user ~]
