How can anyone in the team sleep.The adrenalin and alcohol will keep them going for 72 hours
What an awesome day! Gotta be such an amazing feeling listening to people say “you can’t do it” for 15+ years. And then you flat out get it done! Excited to hear the core of the test net is solid. It works. And you can speed things up and work on the other pieces over the upcoming weeks/months!
Can someone please fill these nodes?? Trying to join here… although I suspect I’ll run into the IGD issue…
@maidsafe, you guys…your tenacity, ingenuity and morality is truly inspiring!
I have MissingSecretKeyShare
in my logs too.
And looks like my node is failed after that event.
I do not see Handling NodeDuty
anymore. Even No op
Looks like network threw away my node
Here is the log with removed ...connection.rs:286] drive; id=...
lines:
[sn_node] INFO 2021-04-09T02:14:40.612706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: RelocationStarted { previous_name: 3cc3b0.. }
[sn_node] INFO 2021-04-09T02:14:40.613706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: No op.
[tokio-runtime-worker] ERROR 2021-04-09T02:14:41.343706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\bootstrap.rs:177] Network is set to not taking any new joining node, try join later.
[sn_node] INFO 2021-04-09T02:14:41.344706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(071af3..), dst: Node(3cc3b0..) }
[tokio-runtime-worker] ERROR 2021-04-09T02:14:41.347706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: Routing is set to not allow taking any new node
[sn_node] INFO 2021-04-09T02:14:41.369706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:41.372706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:41.372706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:41.372706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 08f135.., 12d336..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(007610..), current_holders: {} }), id: MessageId(590f0c..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:41.373706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:41.373706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:41.373706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(071af3..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:41.373706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:41.373706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:41.374706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:41.374706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 08f135.., 13b946..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(016b2e..), current_holders: {} }), id: MessageId(ce6d76..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:41.374706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:41.374706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:41.375706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(21723a..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:41.375706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:41.375706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:41.375706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:41.375706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 08f135.., 13b946..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(016b2e..), current_holders: {} }), id: MessageId(ce6d76..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:41.375706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:41.375706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:41.376706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:41.376706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:41.376706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:41.376706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 08f135.., 12d336..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(007610..), current_holders: {} }), id: MessageId(590f0c..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:41.376706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:41.376706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:41.496706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(22d760..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:41.496706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:41.496706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:41.496706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:41.496706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 08f135.., 12d336..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(007610..), current_holders: {} }), id: MessageId(590f0c..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:41.497706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:41.497706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:41.673706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(2d2664..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:41.673706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:41.673706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:41.673706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:41.673706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 1077ba.., 12d336..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(04bd44..), current_holders: {} }), id: MessageId(fdc79c..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:41.673706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:41.673706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:41.674706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(2d2664..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:41.674706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:41.674706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:41.674706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:41.674706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 1077ba.., 12d336..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(04d88f..), current_holders: {} }), id: MessageId(bbd324..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:41.674706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:41.674706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:41.753706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(08f135..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:41.754706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:41.754706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:41.754706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:41.754706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 12d336.., 13b946..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(031a7b..), current_holders: {} }), id: MessageId(83438c..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:41.754706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:41.754706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:41.755706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(08f135..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:41.755706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:41.755706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:41.755706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:41.755706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 1077ba.., 12d336..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(04bd44..), current_holders: {} }), id: MessageId(fdc79c..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:41.755706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:41.755706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:42.005706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(2c83dc..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:42.005706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:42.005706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:42.005706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:42.005706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 1077ba.., 12d336..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(04bd44..), current_holders: {} }), id: MessageId(fdc79c..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:42.005706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:42.006706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] ERROR 2021-04-09T02:14:42.006706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] INFO 2021-04-09T02:14:42.006706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(2c83dc..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:42.006706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:42.006706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:42.006706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:42.006706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 1077ba.., 12d336..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(04d88f..), current_holders: {} }), id: MessageId(bbd324..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:42.007706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] ERROR 2021-04-09T02:14:42.007706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] INFO 2021-04-09T02:14:42.051706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(2a4277..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:42.051706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:42.051706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:42.051706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:42.051706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 08f135.., 12d336..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(007610..), current_holders: {} }), id: MessageId(590f0c..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:42.052706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:42.052706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
[sn_node] INFO 2021-04-09T02:14:42.052706900+03:00 [src\event_mapping\mod.rs:46] Handling RoutingEvent: MessageReceived { content: "000500..", src: Node(2a4277..), dst: Node(3cc3b0..) }
[sn_node] INFO 2021-04-09T02:14:42.052706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: ReplicateChunk
[sn_node] INFO 2021-04-09T02:14:42.052706900+03:00 [src\chunks\mod.rs:80] Creating new Message for acquiring chunk from current_holders
[sn_node] INFO 2021-04-09T02:14:42.056706900+03:00 [src\chunks\chunk_storage.rs:136] Sending NodeSystemQuery::GetChunk to existing holders
[sn_node] INFO 2021-04-09T02:14:42.056706900+03:00 [src\node\handle.rs:36] Handling NodeDuty: SendToNodes [ targets: {063f50.., 08f135.., 13b946..}, msg: NodeQuery { query: System(GetChunk { new_holder: 3cc3b0.., address: Public(016b2e..), current_holders: {} }), id: MessageId(ce6d76..), target_section_pk: None } ]
[sn_node] ERROR 2021-04-09T02:14:42.057706900+03:00 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_routing-0.58.1\src\routing\dispatcher.rs:78] Error encountered when handling command: The secret key share is missing.
[sn_node] ERROR 2021-04-09T02:14:42.057706900+03:00 [src\node\messaging.rs:68] Unable to send Message to Peer: MissingSecretKeyShare
? Failed to store Safe on a Map: Insufficient balance to complete this operation
$ safe auth create --test-coins
Passphrase:
Password:
Sending request to authd to create a Safe...
Error: AuthdError: AuthenticatorError: Failed to store Safe on a Map: Insufficient balance to complete this operation
I’m getting an InsufficientBalance
error while trying to PUT, how I deal with that?
[tom@jutsu Documents]$ safe files put ./Notes
Error: NetDataError: Failed to PUT Public Blob: Transfer(InsufficientBalance)
Can anyone confirm that test network is still alive?
I am having doubts.
For example, previously uploaded file is not available anymore for me:
Error: NetDataError: Failed to GET Public Blob: ErrorMessage(NoSuchData)
Something is off…
$ safe dog safe://hello
Error: ContentNotFound: Content not found at safe://hello
where had been a few minutes ago as normal
== URL resolution step 1 ==
Resolved from: safe://hello
= NRS Map Container =
PublicName: "hello"
XOR-URL: safe://hyryygy3u8n9g1u4oaz3utykjo5g9y4drkqwetqnxejgz1kzwzron8g8u1en7a
Version: 0
Type tag: 1500
XOR name: 0x3338be694f50c5f338814986cdf0686453a888b84f424d792af4b9202398f392
Native data type: PublicSequence
Native data XOR-URL: safe://hyryyyy3u8n9g1u4oaz3utykjo5g9y4drkqwetqnxejgz1kzwzron8g8u1en7a
| NRS name/subname | Created | Modified | Link |
| hello | 2021-04-08T16:33:22Z | 2021-04-08T16:33:22Z | safe://hyryyry999x547c4qphhzhg15jgexkrx8snh6awwxu8gx45ufyueek4at4enra?v=0 |
== URL resolution step 2 ==
etc
It does seem as if the network went kablooey. I’m sure the devs are going to have a fun morning
Someone probably went to sleep and their forehead hit the off switch
aaaahhhhh!!! you guys already break it? the kid just fell asleep and I was finally sitting down to test it!
It’s not entirely broken. I was able to get a response back on my wallet balance. Although, it did take 3 minutes and 10 seconds.
me@testhost:~$ time safe keys balance --sk privatekey
SafeKey’s current balance: 8453656.000000000real 3m10.055s
user 0m58.974s
sys 0m1.942s
It is good that I went to sleep not waiting till my 800 MB file finishes uploading.
Upload was running for 10 hours, used 4 GB of RAM, 4.6 GB of incoming and 9.2 GB of outgoing traffic.
And now I am cancelling it since I see no way for it to succeed.
I am also on MacOS. After running:
$ curl -so- https://sn-api.s3.amazonaws.com/install.sh | bash
The terminal read Permission Denied when adding safe to the bash profile. In this case you need to give write access to your .bash_profile to staff. At least this fixed the problem for me
I followed the original guide by using GIT and I already installed several other programs. So if anyone could make clear overview what all programs are needed for Windows / Mac OS users, it would be great.
$ cargo build
note:
link.exe returned an unexpected error
note: you may need to install Visual Studio build tools with the "C++ build tools" workload
Congrats on the milestone.
Will give it a try this weekend
I’m not allowed to join as a node yet, but it looks like the network is still up.
sascha@sascha-Librem-15-v3:~$ safe dog safe://hello
PublicName: "hello"
Version: 0
Type tag: 1500
Resolved from: safe://hyryyry999x547c4qphhzhg15jgexkrx8snh6awwxu8gx45ufyueek4at4enra?v=0
= FilesContainer =
XOR-URL: safe://hyryyry999x547c4qphhzhg15jgexkrx8snh6awwxu8gx45ufyueek4at4enra?v=0
Version: 0
Type tag: 1100
XOR name: 0xfffbf7aeb34e6f397e1a5b4990f511e7b0b9ec528f99ccfd6e6504d0856b11d2
Native data XOR-URL: safe://hyryyyy999x547c4qphhzhg15jgexkrx8snh6awwxu8gx45ufyueek4at4enra?v=0
I more expect shutdown today and days (or weeks) of fixing before next test.
The Safe Network Telegram Bot is now connected to the public fleming testnet!
You can view all files uploaded to the shared testnet, your own and those from others! You can also send coins from your CLI to any address generated by the bot or vice versa, or receive/tip people on Telegram if they initialized their Tip Wallet!
Starting the bot and doing
/init
to create a tip wallet.
Viewing all commands and some info.
Your secret data, for this test it’s will not have any value but once live you don’t want to share this with anyone.
Adding testcoins, sending, tipping, etc.
Telegram Test Chat, user tipping another user that has initialized his Tip Wallet.
Feel free to join, first we had this bot in the public SafeNetwork chat but it was too spammy and the admins feel it’s more appropriate if there is a different chat for this. Here you can ask questions and tip each other for fun.
Will add more features like viewing images directly from the network if the file is png/jpg/gif or if there is a file with movie format. Currently you can inspect text files and it will show the content, but for images/videos it will tell you it cannot be displayed.
My logs have got over the the issue I was having and returned to normal.
I can retrieve safe://deusnexus but not safe://lazydog.
Sorry @Nigel I was asleep did you get in?
