At a 100-200 Watt roughly for a standard (active) desktop (without screen), this is about 30-60 (CORRECTED) pence a day. So better to have a bigger disk; more farming space for roughly equal electricity cost (not so if you start adding disks though!!)
Another reason why I should deploy my NAS storage @happybeing ! I’m really curious to see how the B3 will perform as a farming device. Sorry Ive not come around to doing that yet!
B3 @Ross and @dirvine have been helping me and we got quite a long way. I’m not sure if all avenues are exhausted, but it may not be best use of their time and I don’t think I can proceed further on my own so I’m looking at alternatives (see my Farming Hardware posts under Safecoin topic).
BeagleBone boards are cheap and low power, but I’m not sure about storage for them. Beaglebone Black Rev C should ship soon but only has 4GB flash RAM, which is why I’m looking at the Odroid-U3 (about 5W) which has up to 64G flash RAM and can handle a HDD / SSD via USB2.0.
I’ve been exploring netbooks and other devices with low-power intel atom processors, then attaching external usb drives for storage. With a low-resource OS, like ubuntu xfce, etc., the speed of these is pretty good, the power usage is minimal, and they have built in battery backup (laptop battery). Most of these are dual core, run 64 bit, and can have between 2 and 4 gb ram.
There are some thin clients with same specs (sans battery) in which an internal hard drive can be installed.
Not high end processing, but from all I’ve heard @dirvine say in interviews, etc., they should be more than adequite for nodes.
Some of our CI machines on the dashboard are odroids, they seem pretty powerful. @Ross can maybe add some comment here. We have an ubuntu version we tweaked for them, when I say we I mean me and I cannot remember what I did, but we have an image that works
@fergish I like hope you’ll post your findings at some point
@dirvine I was going to ask :-). I like the odroid cos its a bit beefier than the other sbcs and probably than B3, still low power, plus the option to add a USB drive. Not as cheap as beagles but maybe better farmer in the longer term?
The odroid is pretty impressive as just now it is running the same CI builds and tests as linux boxes with 6 cores and 24gb of ram and almost passing the same amount of tests - check our nightly jobs I need to explore / test how it functions purely as a stand alone vault more, but thus far I have been pleasantly surprised. Also it is very small, silent and the 24/7 uptime has not been an issue either. I am not on commission
The B3 device has also impressed and I have not given up yet on these… I am stubborn and will return to it.
Oops, thanks @HelloWorld! You know as I looked at those I thought, “gosh, that looks too cheap” but couldn’t see my error, which was confusing pence and pounds I think! Thank you - I have updated the figures.
