I’m trying to connect to my baby-fleming network from another box on my LAN. Just to make it difficult I’m using Win 10 on the laptop and Ubuntu on the machine running the vaults.
What is the correct way to state the authd endpoint on a LAN?
I get these errors:
My plan is to log in from the Win 10 box, upload some files, download some stuff I uploaded earlier and then if that goes OK, start a vault on the Win box and try to get it to connect to the baby-fleming section.
so authd seems not to like IP addresses at all…
Is this by design?
Does authd only respond to localhost and the --endpoint option is there if another local port other than 33000 was specified for some reason? No - that just doesnt make sense…
I suppose I could look at the source… but it’s much easier to just ask here
$ safe auth start --endpoint https://localhost:50000
Starting SAFE Authenticator daemon (safe-authd)...
safe-authd started (PID: 72169)
$ safe auth status --endpoint https://localhost:50000
Sending request to authd to obtain a status report...
| SAFE Authenticator status | |
| Authenticator daemon version | 0.0.10 |
| Logged in to a SAFE account? | No |
| Number of pending authorisation requests | 0 |
| Number of notifications subscribers | 0 |
Thank you. Yes I can confirm that here too.
But can you start a vault (or network of vaults) and then create an account using –endpoint https://localhost:50000? And then can you connect to that account from another machine in your LAN?
I’m busy with other stuff right now but I will look at this again later this afternoon.
$ safe auth --endpoint https://localhost:50000 create-acc --test-coins
Passphrase:
Password:
Creating a SafeKey with test-coins...
Sending account creation request to authd...
Account was created successfully!
SafeKey created and preloaded with test-coins. Owner key pair generated:
Public Key = 8f0379beeea4c2c22139abd253ac981740f794c26c2c383559f103583855217c086adab86439da99ed8361be02f7161e
Secret Key = 0f16fcd28a44a824c25617f26d826f92f422f43335e2eb222e56f0108946c653
$ safe auth --endpoint https://localhost:50000 login --self-auth
Passphrase:
Password:
Sending login action request to authd...
Logged in successfully
Authorising CLI application...
Awaiting for authorising response from authd...
SAFE CLI app was successfully authorised
Credentials were stored in /home/bochaco/.local/share/safe-cli/credentials
I don’t have another laptop now to test from, but that would fail as CLI doesn’t like IPs, it also fails for me with --endpoint https://127.0.0.1:50000.
