yup, that is correct
Needles to say, but let us know how it goes! I might try to join later today, if you have any success.
I have not had any issues with port forwarding for any of the last number of tests, I ask because I have not been running many per machine.
10 nodes up, all getting chunks!
The year of testnets continue. YAY ![]()
Could you be so kind and post the exact commands how you do it, please? I’d melt away and join the oceans soon after, if I had a node running from home.
(Just the commands for Safe, I can handle the setup of my router myself.)
Sure np.
Assuming you have opened good old 12000 on your router I do this on Linux, I don’t know that there is an equivalent for nohup on windows.
export SAFE_PEERS="/ip4/178.128.45.252/tcp/32923/p2p/12D3KooWRokYkFYg698Wk1fm7RcDGj4tJ9dsdgDx6FgSypuhm8Pm"
export SN_LOG=all safenode
nohup safenode --log-output-dest data-dir --port=12000 &
Does this seem right?
topi@topi-HP-ProBook-450-G5:~$ nohup safenode --log-output-dest data-dir --port=12000 &
[1] 12319
topi@topi-HP-ProBook-450-G5:~$ nohup: ignoring input and appending output to 'nohup.out'
Do I have any way to make sure if I’m in or not?
The stuff in record_store folder, they are chunks, right? I have five of them. Got those right in the beginning, but no more after ten minutes.
In some previous versions, months ago, I was getting some chunks, but was not able to really connect. How to tell the difference now?
From logs at some point:
[2023-08-31T13:05:23.982317Z INFO sn_networking::event] Connected peers: 787
I run this script, it gives me a fair idea of what is going on.
(If you run multiple nodes it will display the data for each)
This is what the output looks like.
Timestamp: Thu Aug 31 09:13:43 AM EDT 2023
Node: 12D3KooWPB31RS7gLkRD6grQBEJKHcx3myaQddQT5BKT6GE3Rh3p
PID: 26168
Memory used: 51.8984MB
CPU usage: 3.1%
File descriptors: 1186
IO operations:
rchar: 10851181
wchar: 46466301
syscr: 44243
syscw: 168900
read_bytes: 0
write_bytes: 46739456
cancelled_write_bytes: 0
Threads: 7
Records: 16
Disk usage: 7.4MB
#!/bin/bash
base_dir="$HOME/.local/share/safe/node"
declare -A dir_pid
for dir in "$base_dir"/*; do
if [[ -f "$dir/safenode.pid" ]]; then
dir_name=$(basename "$dir")
dir_pid["$dir_name"]=$(cat "$dir/safenode.pid")
fi
done
for dir in "${!dir_pid[@]}"; do
pid=${dir_pid[$dir]}
echo "------------------------------------------"
echo "Timestamp: $(TZ='America/New_York' date)"
echo "Node: $dir"
echo "PID: $pid"
mem_used=$(ps -o pid,rss -p $pid | awk 'NR>1 {print $2/1024 "MB"}')
echo "Memory used: $mem_used"
cpu_usage=$(ps -p $pid -o %cpu | awk 'NR>1 {print $1"%"}')
echo "CPU usage: $cpu_usage"
file_descriptors=$(ls /proc/$pid/fd/ | wc -l)
echo "File descriptors: $file_descriptors"
echo "IO operations:"
cat /proc/$pid/io
threads=$(ls /proc/$pid/task/ | wc -l)
echo "Threads: $threads"
record_store_dir="$base_dir/$dir/record_store"
if [ -d "$record_store_dir" ]; then
records=$(ls -1 $record_store_dir | wc -l)
echo "Records: $records"
disk_usage=$(du -sh "$record_store_dir" | awk '{print $1}' | sed 's/M/MB/')
echo "Disk usage: $disk_usage"
else
echo "$dir does not contain record_store"
fi
echo
done
Cool, thanks! Seems to be working, but I’m still not sure.
Question: read_bytes = sending chunks?
Timestamp: to 31.8.2023 09.59.46 -0400
Node: 12D3KooWKpB3KuUviu2UxJKLuGXoArPv7CvW5jmtmbVS2md5a7o2
PID: 12319
Memory used: 53.8047MB
CPU usage: 4.1%
File descriptors: 1662
IO operations:
rchar: 13984051
wchar: 408927581
syscr: 82439
syscw: 320535
read_bytes: 40960
write_bytes: 35508224
Threads: 11
Records: 7
Disk usage: 3,0MB
Ok this is a freaky coincidence.
I downloaded this file; not knowing what it was, I called it mah
Then I opened it, assuming it was a picture, and guess what:
What are the bloody chances?
I’ll take it as a good omen for SAFE!
edit; ok not quite like that…turns out the file I was opening is one I already had in the directory I run the command from…still a series of weird coincidences, let’s not get in the way of a good story!
It is PE binary ![]()
Are your psychic powers for hire at all?
vdash it man.
As it often happens, there actually was a logical explanation (see spoiler above)…lol
Is there anyway to have vdash load all the log files from all the different nodes easily without having to specify each path indevidualy?
Is a proper pain now having 30 nodes on a system
Alright, I’ll think about it.
First I need to install Rust, right?
You can pass multiple node logfiles using a wild card path.
So if all your nodes have a common root directory you can use an asterisk in the path instead of the node ID.
As above - failing to upload large files/dirs/no of chunks
willie@gagarin:~/projects/maidsafe/safe_network$ time safe files upload /fgfs/Aircraft/A320-family/
Built with git version: 794fca7 / main / 794fca7
🔗 Connected to the Network Loaded wallet from "/home/willie/.local/share/safe/client/wallet" with balance Token(199999999184)
Preparing (chunking) files at '/fgfs/Aircraft/A320-family/'...
Making payment for 4608 Chunks that belong to 976 file/s.
Error: Transfer error Not enough balance, 199.999999184 available, 316096398.846066688 required
Caused by:
sn_cli/src/subcommands/wallet.rs:305:26
real 0m32.759s
user 0m37.371s
sys 0m11.227s
Smaller uploads seem OK, I uploaded and then downloaded a dir wirh ~50 files of tatal size ~8MB without problems.
Failing to get a node running from AWS
My inbound rule is
– sgr-053885758c5104e5a 12000 - 12020 TCP 0.0.0.0/0SAFE port
which has worked OK in the past - only other rule is allowing SSH to my desktop IP only.
