I have to admit I’m getting a bit confused about current and future features of the network, so I thought I’d start this topic, which hopefully will be useful to others as well.
In particular, I’m trying to understand what’s the status of the current network live on the shared vault (Vault Phase 2a?) And what is planned for the next phases.
In terms of routing, that’s relatively clear (if still current):
Phase 2a : we will have a small section of only elders (a few nodes) and test that.
phase 2b : We will then add more nodes to create a large section.
phase 3: Add farming algorithm (this may happen in parallel with above)
phase 4: Add more nodes to allow the network to split (sharding)
In terms of data type, that’s where I start getting confused; my understanding is (from @oetyng [RFC] Data Types Refinement :
The current types…
UnpublishedUnsequencedMutableData
UnpublishedSequencedMutableData
UnpublishedUnsequencedAppendOnlyData
PublishedUnsequencedAppendOnlyData
UnpublishedSequencedAppendOnlyData
PublishedSequencedAppendOnlyData
UnpublishedImmutableData
PublishedImmutableData
…thus become the following:
PrivateMap
PublicMap
PrivateSequence
PublicSequence
PrivateBlob
PublicBlob
And then comes consensus…PARSEC, CRDT/BLS, safecoin (AT2?)
So, I’d really appreciate if someone could help summarising as follows:
- Vault Phase 2a (current):
Shared Vault, Single section, Elders only
Data types implemented: not sure what data types are currently implemented??)
Consensus: PARSEC (is that right, everything currently goes through PARSEC??)
Safecoin implementation: PARSEC (??)
- Vault Phase 2b:
Single section, Elders+Adults (?)
Data types implemented: (?)
Consensus: (?)
Safecoin implementation: (?)
- Vault Phase 3:
Consensus: (?)
Safecoin implementation: (?) + farming
- Vault Phase 4:
Multiple sections, Elders+Adults (?)
Consensus: (?)
- FLEMMING (?):
Multiple sections, Elders+Adults + (?)
Consensus: (?)
