Restarted the network again.
I know, itās getting close to 48 hours, instead of the originally planned 18. I suspect it will be another 24 hours before Testnet6.
Vault seems to be working although thereās nothing in the chunk store but I canāt log in via the launcher now or create a new account. Was working for most of the day.
The serverās acting a bit strange, so Iāll reboot it.
Server malfunction, so it seems, and a maintenance ticket has been raised at the provider.
A post was merged into an existing topic: TEST5 (AKA destructive test) - is now running
hi,
yes test5 is still running, but dabbling and tweaking on the comm network does aid learning about the operational side of things while not really effecting the test network at all⦠given the ease involved in running the test network release vaults for instance, there isnāt much to be gained knowledge wise, download, untar, runā¦
i do both, so run test and then swap over to support bluebirds comm network, hopefully this helps everyone and provides a way for me to support the progress of the systemā¦
rup
The provider came through and gave me access in ārescue modeā because the server was not ping-able after booting. The server is now booted on a foreign kernel and file system and I can examine my partitions, change, backup and edit them.
Almost certainly I messed something up in the networking and/or firewall. Well, thatās what it is for after all, as a learning tool.
And indeed, I now have done previously unfamiliar things such as mounting volumes, tar-gzippāing directory trees and then scpāing them down to a local machine. Kewel!
In anticipation of Testnet6 I am rebuilding it from a stock Debian image, as the most deterministic recovery path, and then restore of data.
Apologies for the inconvenience, people. Community1 shall return after Testnet6 ābigger and badderā than ever. ![]()
