Looks like something is wrong with downloading of .iso file.
Well this is sub-optimalā¦
Running safe_network v0.32.0
Oct 06 14:27:41.859 INFO safe_network::routing::routing_api: f4d7bc⦠Bootstrapping a new node.
Oct 06 14:27:41.926 INFO safe_network::routing::routing_api: f4d7bc⦠Joining as a new node (PID: 1382) our socket: 164.90.226.179:55931, bootstrapper was: 165.227.228.183:12000, networkās genesis key: PublicKey(0cb6ā¦a5ba)
Oct 06 14:27:41.927 INFO safe_network::routing::core::bootstrap::join: Sending JoinRequest { section_key: PublicKey(0cb6ā¦a5ba), resource_proof_response: None } to [(f4d7bc(11110100)ā¦, 165.227.228.183:12000)]
Encountered a timeout while trying to join the network. Retrying after 3 minutes.
Oct 06 14:30:41.855 ERROR sn_node: Encountered a timeout while trying to join the network. Retrying after 3 minutes.
Iāll review and try again later. RealLife is causing me grief right now.
I have a node waiting to join and I get the output to terminal as normal, but no logfile. Is this the same for others?
Previously there would be ā.logā files created in .safe/node/local-node but Iām not seeing that and canāt find them anywhere else.
EDIT: Also, I have two machines trying to download 1234.jpeg but the commands are just sitting there after several minutes.
Just guessing here but perhaps the join command I posted, maybe export the log?
What I see in my logs:
Node started:
Oct 06 16:26:26.159 INFO sn_node safe_network::routing::routing_api:7a644b.. Joining as a new node (PID: 5096)
Lots of chunk writes
Oct 06 16:40:20.947 INFO tokio-runtime-worker safe_network::dbs::kv_store:Writing value succeeded!
Something wrong with connections:
Oct 06 16:43:25.061 WARN tokio-runtime-worker qp2p::connections:Failed reading from a uni-stream for peer 68.183.47.224:12000 with: ConnectionLost(TimedOut)
Writing stops with such messages
Oct 06 16:54:43.582 INFO tokio-runtime-worker safe_network::routing::core::msg_handling:Handling system message
Only occasional gets happens since then
Oct 06 17:50:49.076 DEBUG tokio-runtime-worker safe_network::routing::core::chunk_store:Getting chunk at address Address(b6011a(10110110)..)
I suspect than network failed either at 16:43 or at 16:54.
But my analysis was wrong many times.
So it is better to recheck it.
Do you have a logfile? If so what is the full path and what command did you run to start the node? I think you are on WIndows, is that correct?
I use NSSM with such parameters for binary:
-vv --max-capacity 50000000000 --skip-igd --hard-coded-contacts [\"165.227.228.183:12000\"] --genesis-key 8cb627387821cd0a516d038efa9588d1a5e6c759be23d9575a09fae0bf1ae76e0390c0ef59275a3526db13be23aca3c4 --root-dir "g:\SN_Root" --log-dir "d:\SN"
There are more tweaks there. Ask if this info is not enough.
My binary is at d:\SN\sn_node.exe, logs at d:\SN\sn_node.log.2021-10-06-13 and d:\SN\sn_node.log.2021-10-06-14.
Oh wow.
.iso catāting finally showed result:
d:\SN>safe cat safe://hyfeynyybm59mfec3tinyykxoksesmzteq6nojggj53hjphbtbkcu4d79h
x6y > 1.iso
Error:
0: ā[91mNetDataError: Failed to GET Blob: NoResponseā[0m
ā[35m/rustc/c8dfcfe046a7680554bf4eb612bad840e7631c4b\library\core\src\result.
rsā[0m:ā[35m1897ā[0m
Backtrace omitted.
I am getting a bunch of these on the genesis log
{"timestamp":"Oct 06 14:05:13.814","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
I may restart it, if there you all like?
Is 68.183.47.224:12000 node yours?
Can you say if it is running?
yes it is mine.
"timestamp":"Oct 06 15:05:49.422","level":"ERROR","fields":{"message":"Sending message (msg_id: MessageId(079b..df7a)) to 109.87.25.148:62538 (name c7a16a(11000111)..) failed with None"},"target":"safe_network::routing::core::comm","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:06:49.424","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:06:49.427","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:07:49.445","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:08:49.511","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:08:49.574","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:08:49.577","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:09:49.587","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:09:49.589","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:09:49.783","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:10:49.817","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:10:49.819","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:11:49.923","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:12:49.955","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
{"timestamp":"Oct 06 15:13:50.000","level":"ERROR","fields":{"message":"some error: TimedOut"},"target":"qp2p::endpoint","threadName":"tokio-runtime-worker"}
Looks like this version still contains bug which sends messages to nowhere.
Iāll restart and update the OP with new connection info.
Cool. @vort maybe start with smaller uploads ![]()
I will let other community members do uploads this time ![]()
we are back for take 2
Mind what he said about baseball bats? Slap!!!
You know what are the .iso sizes for modern games, right? ![]()
Ah this looks better already - getting non-worrying log messages
Gonny just stick to photos of your favourite pussy, please?
