Can't create test coins. Not enough money
Setup
Client
Hardware: Asrock J5005
OS: Manjaro
    Arch: AMD64
    DE: XFCE
sn-cli: master
sn-authd: master
SAFE Browser: 0.18.beta.1
Server
Hardware: RPi 4
OS: Manjaro
    Arch: Arm
    DE: Minimal
sn-cli: master
sn-authd: master
sn-node: master (edited localhost to 192.x.x.x)
I can’t seem to create test coins.
$ safe auth start
Starting SAFE Authenticator daemon (sn_authd)...
sn_authd started (PID: 5687)
$ safe auth create --test-coins
Passphrase:
Password:
Sending request to authd to create a Safe...
[2020-12-02T08:50:04Z ERROR safe] sn_cli error: [Error] AuthdError - [Error] AuthenticatorError - Failed to store Safe on a Map: Data error -> Not enough money to complete this operation
As mentioned elsewhere, we’re still working on this so I can’t offer any specific help at the moment I’m afraid @folaht.
I’ll ping back here when you could expect this to be working though :+1:
I’ll try and see if I can debug this problem then.
you’ll want to be sure you’re building node and client with simulated-payouts feature flag enabled, it definitely won’t work without that.
I think the issue is that the section (sn_nodes) you are running doesn’t have the simulated-payouts feature enabled, the CLI and authd have them by default in that branch I think.
