Considering the network type (millions of nodes, each block stored to different node), the behviour is quite different compared to normal upload/download. If the timing is not carefully thought, you might very easily accidentally call a DoS attack to your router.
Its quite simple, just send a request that will trigger million nodes to send you one UDP frame. If it happens simultaneously, no router will survive that.
I assume this is taken into account, but since large file uploads does not work, thought it might be good idea to ask.
There should be some kind of flow control to prevent different nodes to send data to the same address simultaneously, is there such thing?
You request a chunk and one node, yes one node will send that chunk to you because you asked that particular node to send it
You request peer list (eg close to an xor address) from a node and that node will return that list.
Not much different to sending a request to a server, except this is to a peer in a distributed network.
There is no operations where you broadcast a request and multiple nodes respond. All communications are node to node (peer to peer), since this is a p2p network.
Now the client uploader will send multiple chunks as part of the programming but it is still one chunk to one node. For some routers the number of chunks being sent in my opinion is too many (8 I think) but its 8 nodes not millions the data is sent to.
downloading is multiple chunks too but again like requesting from 4 or 8 nodes at this time. One different chunk from each node.
Sorry, I disagree with this. The network has a problem with large file upload, you should welcome any suggestion that has even remote chance to help solving the problem.
But maybe i first should read the documents (or source code) before posting. And maybe this should be on the dev forum.
You started 20 years before me, congrats!
Yes, back then knowing flow control was much more important than nowdays when almost all is TCP etc with ready made flow control. That’s why I raised this question, UDP for multiple endpoints is so different compared to TCP.
And why i am examining the flow control in quic. The team is super busy and maybe not enough time to try out different combinations of the 2 main parameters controlling flow. Imbalance of one to the other can just clog things down and it’ll take them time to try different combinations in the real world. That is why i want to do some graphs for them (theory) so hopefully guide them to combination that will work good for not only the potato routers but also high end setups. In that topic I did explain what was happening in the potato routers with buffer overflows due to UDP protocol.
Well I got to play with unix in 75 when it came here on a 11/4? computer. Going from RT11 to Unix required toggling in a bootloader to get the image from the removable rp05 (think I remember the model right)
