Now I am achieving 200nodes 3W, 40%cpu load(not going to max out, since sometimes having spikes to around 80%)
Now building cost around £50
8 posts were merged into an existing topic: The Emissions Thread -aka lollipops
Some people like RPi systems.
Here is a cheap cluster RPi solution some one might be interested in. Maybe run docker images on it,
https://sipeed.com/nanocluster (the site is in english)
Review
Whats your recommendation for the best bang for buck for nodes from this?
Not sure, it is a cheap product so not as wonderful as some expensive ones.
But looking at the site and for running nodes the NanoCluster 7xLM3H package for 260USD (preorder) seems promising. 23USD per module plus the 100USD for the cluster unit. It comes with a managed switch on the underside so only need the one network connection. Would need external storage as the module only has a 32GB eMMC for storage. IE just OS + binaries
But look at the video and then look for his review of the 3xlm3h modules he said he would test and post on his review site.
yeah, I thought the NanoCluster 7xLM3H myself but I wanted your thoughts.
I’ll check the videos and other reviews and see what the optimal external storage would be.
It’s a noble idea Superalignment, however that ship has sailed imo and this group will languish in a ‘plasma like’ Hopium, until they are vanquished by the pure evil that is already out there..
The ‘playing field’ has shifted upward one order of magnitude since October of 2023.
Many already have been, and will be left behind, either directly involved or acquiescing. Those climbing up to this new level will be both good and evil. The battle we think now as being ‘intense’ on the current playing field in which we live and operate today, is, when viewed from this 'elevated playing field, which is a renewed battle between light and darkness, with really no rules, is seen from that ‘elevated’ vantage point like ‘child’s play’ , not in a few short years, but right now.
Look up aholes like ‘Palmer Luckey’ and you will see what I mean..
The real Tony Stark and Stark Enterprises before ironman was built. ![]()
That ‘elevated playing field’ exists today, Slaughter bots are real, so are autonomous weapon systems.
The only way to protect ones self is to dis-engage from the current Digital Gulag and join a protected silo (Autonomi with good gateway 'draw bridges they control)
A secure silo world that is not this current and age old good/evil battlefield which is now powered by AI.
That insulated distributed silo layer will really only happen if Autonomi actually gets built on a Layer 4/3/2 stack other than TCP/IP and MAC Addresses (to get away from the military complex snoop dogging everyone when ever they want..)
which is possible if Layers 7/6/5 of the ISO Stack are pointed at something like CXL 3.2 in the data center bound to a reworked software defined WAN/MAN infrastructure technology like ATM… and for the end user the reinvention of something like software defined narrow band ISDN tied to that.. to replace cable modems and routers as we know them..
Building an Automi Router+FW with Quantum encryption with a new address scheme that also does TCP/IP for now is likely the bridging mechanism for the end user,
all of the above needed to create a parallel universe on the same to keep these war mongers out…, The encryption is there and AI can be re-purposed to help build the above…
look at LISPERS.net and alternative ICAN addressing categories in LISP routing for clues on how that could work (The Airline Industry uses LISP today with this tech running on Cisco routers using completely different addressing schemes and with LISP routing )
Of course what the heck do I know, it’s a dream at the moment, that’s all… to escape from TCP/IP and MAC addresses, and the milcomplex.
