Maybe not the roadmap…
Psst, don’t tell anyone until your bags are full and then I’ll announce it.
lalala
random idea
riddim: i’ll see if i can drop a super simple forum soonish and how expensive it will be xD
maybe having a common ant-owner-secret, using a history for deriving a shared history (and every participant being able to precompute all needed graphEntry addresses from current pointer value + known derivation chain → parallel fetching of those graphEntries is possible → then parallel fetching of all posts is possible) and putting posts as chunks would be good enough to start a super simple forum app xD …
(and just to state the obvious clearly … this is a first draft xD … don’t expect anything too soon from me
- but having an autonomi forum would be pretty awesome imho - no matter how bad/half-baked it is xD)
@riddim you are such a helpful and capable chap. ![]()
Don’t celebrate too early… For now it’s just a concept… I will look more into it tonight / the following days
Yeh, but we both know what that means ![]()
It should pick up the key from your system like dweb serve, so if it isn’t that would be a bug.
Check the terminal to see if that gives a clue.
iv got the private key set in bashrc
export SECRET_KEY=<KEY>
this was testing on the app image
Must be a bug then. If you can, try installing it using dweb-app.deb
I’ve only tested my own builds so far. It shouldn’t make a difference though.
I’ll do some tests myself when I can. Thanks for checking it out and reporting back.
Good job nobody knows about it yet ![]()
#WorksForMe
The balance of the wallet I set in $SECRET_KEY is shown at the top
Thank you @happybeing
Can you figure out with @aatonnomicc what he’s doing wrong
er, I mean what’s different in how you are doing things
He’s never been the same since he had to get that shot of extra-strong antibiotics after that “girl” in Georgetown Guyana…
But I’ll try…
You could try setting the secret key in your .profile if you started the app image via double click from file manager - chatgpt sais that bashrc doesn’t work then and only .profile gets executed
I was thinking the same but couldn’t remember the name .profile ![]()
@riddim solved it set the key in .profile instead of .bashed then reboot the system and the app image works just fine ![]()
Or just the buy the rumour and sell the news cycle.
Not much of a pump though
So vapourware?
Steam was part of the early Earth’s atmosphere and surface processes. It influenced the formation of oceans, helped drive prebiotic chemical reactions, powered hydrothermal systems, and enabled concentration and cycling of molecules — all of which made life’s emergence possible.
Autonomi facilitates the creation of ecosystems and life is a similar manner ![]()
Not gonna lie, the cup and handle pattern looks pretty perfect to me. The general consensus is the breakout will take us somewhere to the $0.11 range. Personally I do not really fully believe in the price target of the cup and handle pattern anymore since it became such a mainstream analysis.
However, the trend reversal pattern is something I strongly believe in as mentioned here and it’s working out beautifully. Pixel perfect I might say. If you got your allocation, good. If you’re still a disbeliever, you’re going to start chasing the market real soon.
And just a small edit: I’m gonna enjoy seeing the disbelievers FOMO back in. Worth it.
just getting the pop corn ready ![]()
I thought I was too much of a boomer to get a GIF working on this forum. But turns out I’m still in the safe zone. Kinda
