Oh well, learned something new then!
I haven’t reproduced that install problem on Ubuntu 20.04 either.
vagrant@ubuntu2004:~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="20.04.3 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.3 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
vagrant@ubuntu2004:~$ curl -so- https://raw.githubusercontent.com/maidsafe/safe_network/main/resources/scripts/install.sh | bash
=> Downloading Safe CLI package from 'https://github.com/maidsafe/safe_network/releases/download/0.58.4-0.57.1-0.50.4/sn_cli-0.50.4-x86_64-unknown-linux-musl.tar.gz'...
=> Saving to '/tmp/tmp.cFdeluxCkj/sn_cli-0.50.4-x86_64-unknown-linux-musl.tar.gz'...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 685 100 685 0 0 2088 0 --:--:-- --:--:-- --:--:-- 2088
100 9.8M 100 9.8M 0 0 3762k 0 0:00:02 0:00:02 --:--:-- 5833k
=> Unpacking Safe CLI to '/home/vagrant/.safe/cli'...
=> Adding statement to '/home/vagrant/.bashrc' profile to have Safe CLI binary path in the $PATH
=> Profile '/home/vagrant/.bashrc' already contains a statement to set Safe CLI in the $PATH
@southside I had similar problem when I was installing safe from different user accounts.
try cleaning the /tmp folder and try again if its the case with multiple users
I have an adult that tries to “cleanuppeerlinks” all the time and a put that is still purring, is the playground really offline?
I’m on night shift and wake up to find iv missed all the fun
Well done to everyone who took part in this playground!!
@neik it was said that if a new release with a bugfix goes through, the playground will relaunch soon!
Hope so but I’d hope it will be next week as its time for the team to rest and enjoy some down time over the weekend.
wonder if there is a way to get progress on recursive puts as well ?
since iv been under the same rock as @Josh
You have made my day… I am not alone
reporting on GETs is a client side issue (I know, I know but…). Getting info on recursive PUTs may be a tad too far at this time with other conflicting priorities.
Patience, grasshopper
SooOOooOoo. While there’s no prebuilt files as the CI run failed to generate a new release… (to be investigated during the week). There is another incarnation of the playground up again now, with the nodes attempting to reconnect at least once on fail. (Which while not comprehensive – there’s changes coming soon to help more here – should hopefully stem the tide of harsh ProposeOffline
messages we were seeing yesterday.
I have put nodes built from the latest commit on main up on DO.
Access is as OP. Same test files exist, same need to remove ~/.safe
before you start. There has been a split. At the time of writing I can get the files listed in OP fine.
If you’re just putting/getting, you can use the cli from the install script.
If you’re wanting to join with a node, you’ll have to build yourself manually I’m afraid (to ensure that your node gets the latest connection retry code).
Sorry about that!
So. I cannot upload files more than 4mb on here.
BUT. There is a network up that can hold such things.
There’s a linux build of the node built from main up which you could grab thus:
safe cat safe://hyfenryyban3rya95df67upomjse4wjaumy1awb94hs8oyfezjnpwykunu6zo > sn_node.zip
My node is waiting to join and I’m putting. Thanks @joshuef!
Excellent.
I will make a script to automate this! thank you @joshuef!
On debian:
sudo apt-get update && sudo apt-get install -y git
git clone https://github.com/dreamerchris/dream_sn_node_joiner.git && cd dream_sn_node_joiner
sh dep_installer_debian.sh && sh playground_join_with_built_sn_node.sh
^^ this will:
- install the dep and safe cli
- add playground config and switch to it
- safe file get the sn_node.zip from the playground itself
- unzip it and copy it in ~/.safe/node
- add a service to join as a node
run sh single_down.sh
to remove the node!
On manjaro:
sudo pacman -Syy && sudo pacman -S --noconfirm git
sh dep_installer_manjaro.sh && sh playground_join_with_built_sn_node.sh
^^ this will:
to remove the node!
safe files put yt5s.com-Booth_called_Hartley_dickhead___Red_Notice_2021___Ryan_Reynolds_Dwayne_Johnson1.mp4
FilesContainer created at: "safe://hyryyryynpniqcs6ojp5ue8i5mifwto57zs1wmm71e8aeu3rekccxp5e35keyeuy?v=hdks648ksyntmcet9xbydxmq74bnf1mcswggoqpq4wfw6nyo6sjwy"
| + | yt5s.com-Booth_called_Hartley_dickhead___Red_Notice_2021___Ryan_Reynolds_Dwayne_Johnson1.mp4 | safe://hy8ayqyyb6qd4759nenn16uasufb5ihfqqaijgy5pu4mzg495njz9tp8r3tco |
the test jpg from op but you can paste it and it will download all one by one
safe cat safe://hygoygyyb9nh1sbthce4khak48njcti18uzhba56mgru89bnmzzo3cz8s9j1y > 1.jpg
safe cat safe://hygoygyybbrpbh76ep7dw84t7r3stybfssm9wrpiqhxk19gtj3r7eb3rz384o > 2.jpg
safe cat safe://hygoygyybgsidcu168j7mj4rcd1d6io6uqcpgp9s831rcg75z8qyo6zg58tfy > 3.jpg
safe cat safe://hygoygyybgjptw3xbqqk4uihkr7hyrwnghfnzr5ddpfana4x1bhmy3ys8uffo > 4.jpg
safe cat safe://hygoygyyb11e1edd7u347a4y3d1ypqii88eajho9zuez4mmfmmaqiwg5apj5o > 5.jpg
safe cat safe://hygoygyybgc1kfx4b6u4pan9547o6gnmop5s8a7n953gzti7437qpdqnxxmxy > 6.jpg
safe cat safe://hygoygyyb45179qyo8ipaywqojrzmc1ht6fiiwzsfqgjphji1kfgpzdaqje3y > 7.jpg
safe cat safe://hygoygyybo4bm4ojo8gasdibez4yd5yk34on6d9cxyodypardp8pibcqyrd8o > 8.jpg
safe cat safe://hygoygyyboqgy5rpe1exa7935awsam1zc8wd51jqoxhn4dch817ds4cer3kmy > 9.jpg
safe cat safe://hygoygyyb3n3wqahmai8f9yk3u56hpt49ku7adwhdwhddzbyq51asnd5g9ado > 10.jpg
safe cat safe://hygoygyybsym3syjth5tuf9y5ny79kb1f4g9nnnry73xujejitxs1isqoawxy > 11.jpg
safe cat safe://hygoygyybhp4rcjtie16h3c6xdqdib5d5pb49xk1iohqy9qbu67ihspeodyzo > 12.jpg
safe cat safe://hygoygyyb533c9f6mekkyuu5dj39jctmdck5yp1hpdtwc6ignqerhw3fhpa4o > 13.jpg
safe cat safe://hygoygyybjo6tub35w68z9eyy4qj7j4ms3kxy6t5inf1a16x5enesireewqzo > 14.jpg
safe cat safe://hygoygyybqpzmtyc5twr51x7dwqjgrgwsn5hhtx6ddbrxr1hb41nq7fuhi9zo > 15.jpg
safe cat safe://hygoygyybecotf79qepzj3bdhhhqgptor5q74z8tbfgqg1nurhm6ho65tyw3o > 16.jpg
safe cat safe://hygoygyybn6gi537sw6jt57pxzsxypz1stwb6k9q8tpsm5yy6xyerb5p1bp4o > 17.jpg
safe cat safe://hygoygyybu7ofdt5onp4tk4z97bnqe4h998ou7k5p6hkjqje1j9mjbywgrq6y > 18.jpg
safe cat safe://hygoygyyb13q8pory4pq4c7wtjzwuognmwwtkzw8n9nrsusnummaa1g1gtweo > 19.jpg
Playground: safe cat safe://hy8ayqyybwy43t853ng65n6q79c3ozyypxui7s7tyg8amm8hme3iu33dh4m6o > bigdunc.mp4
Running behind a opnsense firewall with UPNP enabled:
Error:
0: Failed to establish UPnP port forwarding
1: The requested mapping conflicts with a mapping assigned to another client.
/rustc/9d1b2106e23b1abd32fce1f17267604a5102f57a/library/core/src/convert/mod.rs:543
I was trying to use the UPNP instead of manual port forwarding for simplicity. I currently have existing port forwarding on port 2222,3000, 7999, 8089 and 12101 setup for other services. Not sure if those conflict with what SAFE is using, but I thought the point of UPNP was to manage all of that by itself? Not an expert, could be wrong.
All of the above is from a VPS I already have setup.
The results are the same from my home computer behind very standard unifi controller NAT setup. Nothing special happening there.
Both are behind NAT firewalls, and using
--skip-auto-port-forwarding
gives the expected "network not accepting new nodes, try again in 3 minutes.
But I’m unsure if it would actually connect.
safe cat has yet to return me any data, but dog will return file information.
It seems to be down
