You have 2 years to protect magnetic data from a super flare
I wonder if a strong flare would affect the whole Earth or just the facing side? If data on Safe is geographically well distributed and with a bit of luck, we might come away without much data loss … of course the global networks we use to carry that information would have to be rebuilt – no small feat I think.
While true, this doesn’t mean we don’t have flares, it just means there are far fewer of them … and that also means we can still have large ones … I don’t know if the probability of a large one is lessened or not.
Maybe you are being sarcastic, but satellites are not the most protected - in fact they are quite vulnerable to large flares.
I know you are addressing the OP with the 2 years notice. But to clarify for those that don’t know, this could happen anytime and we’d only have (from estimates I found on the web) between 12 to 40 hours to prepare. We would know however as we can see the flares happening and we do monitor the Sun closely. So if you prepared in advance even a little bit, you could unplug all of your personal hardware and place it in a basement - perhaps wrapping it in a conductive box or sack that is well grounded (copper rod hammered deep into the ground). At the least you could probably remove your hard-drives and USB devices and protect them - even if you have to bury them in the ground for a while (protective coverings!).
The REAL issue, IMO, isn’t going to be the loss of cultural data, but the data of business and the networks businesses depend on … a chance of a small dark-age taking over for a time. Quite a scary possibility.
Or find someone who lives in a steel boat :wink: Failing that, an oven or a metal fridge, even a biscuit tin.
Well I wouldn’t like to live in an oven and a biscuit tin would be a bit cramped, but the fridge sounds good right now :sun_with_face: :sun_with_face: :hot_face:
We entered the 40 degree club yesterday, the UK isn’t there (yet).
https://www.reddit.com/r/europe/comments/ci04t2/there_you_have_it_reurope_only_a_few_left_to_join/
Oddly enough, the hot weather may be the product of global cooling!
Off-topic, but …
Cloud-cover generated by increasing GCR’s as a result of lower solar activity (fewer sun spots and hence fewer flares) lends itself to a more wildly shifting jet stream which brings with it both hotter and colder weather around the globe … ultimately the higher albedo of the earth due to greater cloud cover leads to cooler temps and in the medium term higher rainfall.
Less solar wind as a whole due to lower solar activity (not lower sunlight but fewer high energy ions emitted by the sun) allows more GCR’s (galactic-origin cosmic rays - super powerful ions) to pass deeper into our solar system and more hit the Earth’s atmosphere, which causes the production of a cascade of lower energy ions, that in turn seeds the formation of clouds.
There is a huge historical correlation with the sun cycles and global heating and cooling and we are now in a strong solar minimum. Some people, myself included, think that we are starting a “grand solar minimum” which, if it were to reach the levels of the “Maunder minimum” could possibly trigger major glaciation -every time we get a dramatic level of cooling there’s a coin flip on such happening.
Technically we are still in an ice-age geologically speaking and currently we are in an inter-glacial period.
Weather! Sometimes it’s cool stuff. :wink:
