I’ve just published vdash v0.8.9 in readiness for the next testnet. This adds Node Uptime and Earnings to node status, plus an Earnings timeline. It also adds statistics in the timeline labels. See the OP for keyboard commands.
Apologies for another update so soon but this has a few tweaks for the next testnet.
I’ve just published vdash v0.8.11 which re-orders the stats and timelines, and gives better information in the timeline labels (units and vertical scale).
See the OP for keyboard commands and other details.
I’ve just published vdash v0.8.12 which has minor UI tweaks and fixes the missing Earnings. If you re-start vdash you’ll lose some earlier data but see everything that’s in the latest log and anything new.
To install/update:
cargo install vdash
Edit: if you restart your node (do rm -r ~/.local/share/safe/node first) and then restart vdash it’s pretty sweet as you’ll see a pile of PUTS arriving and eventually costs and earnings and your totals will be accurate.
TIPS:
press ‘t’ and ‘T’ to cycle forward and back through the timelines.
press ‘o’ and ‘i’ to zoom the time scale out and back in.
If your nodes run on a Debian(-based, e.g. Ubuntu) system, then depending on how modern the system is you can install as a system-integrated package with the command apt install safe-vdash.
The only Debian-derived distribution that is well-structured enough to reliably correlate packages is Ubuntu, which is shown in the lower right corner.
Currently, according to that info (which is all that I am going to bother looking at, since my focus is Debian, not its derivatives), the version in Ubuntu is apparently 0.8.5-1, and following the link for that version it is apparently part of "Mantic Minosaur which is indicated to be in pre-release freeze state.
I’ve just published vdash v0.10.1 which shows Node Status as ‘INACTIVE’ for nodes that have been killed or crashed and has some minor bugfixes and tweaks, as well as major changes ‘under the hood’.
Mac and Windows Support
I’d be grateful for anyone with Mac or Windows to try installing and running on those OS and let me know how it goes.
I’ve updated the README with instructions for running on Mac and Windows but I can’t test myself.
Instructions
To install/update:
cargo install vdash
If you are already running and re-start vdash you’ll lose some earlier data but see everything that’s in the latest log and anything new.
TIPS:
See keyboard commands in the OP for more, which also contains other details.
I have a big vdash update in the pipeline but am not saying what is in it yet because I’d like to add some more timelines. So here’s a poll to see which might be of most interest to you, the wonderful users of vdash, also known as ‘noderunners’
This opens with a brand new ‘Summary’ screen with statistics for all monitored nodes, and a one line summary for each node. There’s now a ‘Connections’ count for each node, plus minor tweaks and bugfixes.
Here’s my vdash Summary for 20 nodes after 6 minutes in the HeapNet2 test network…
There’s also a new help screen (press ‘?’) which lists all the keyboard commands.
No new timelines in this release but I’ll add those soon. EDIT: now in v0.11.1
I still have no feedback for Mac or Windows so I’d be grateful for anyone with Mac or Windows to try installing and running on those OS and let me know how it goes.
The README contains instructions for running on Mac and Windows which also need checking!
Instructions
To install/update:
cargo install vdash
TIPS:
press ‘n’ to see the familiar Node Details dashboard
press ‘s’ to return to the Summary dashboard
press ‘?’ to see the Help with details of all keyboard commands
