Vdash - dashboard for Autonomi nodes
tried on ubuntu 20.04LTS build the essential installed rust and then exec bash to refresh the terminal and then
cargo install vdash
get two errors
error[E0599]: no function or associated item named `new_immediate` found for trait object `dyn Watcher` in the current scope
  --> /home/smoothie/.cargo/registry/src/github.com-1ecc6299db9ec823/linemux-0.1.3/src/events.rs:61:64
61 |         let inner: notify::RecommendedWatcher = NotifyWatcher::new_immediate(move |res| {
   |        ^^^^^^^^^^^^^ function or associated item not found in `dyn Watcher`
error[E0308]: mismatched types
  --> /home/smoothie/.cargo/registry/src/github.com-1ecc6299db9ec823/linemux-0.1.3/src/events.rs:90:20
88 |     fn watch(watcher: &mut notify::RecommendedWatcher, path: impl AsRef<Path>) -> io::Result<()> {
   |                                                              ---------------- this type parameter
89 |         watcher
90 |             .watch(path, notify::RecursiveMode::NonRecursive)
   |                    ^^^^ expected `&Path`, found type parameter `impl AsRef<Path>`
   = note:   expected reference `&Path`
  --> /home/smoothie/.cargo/registry/src/github.com-1ecc6299db9ec823/linemux-0.1.3/src/events.rs:95:25
94 |     fn unwatch(watcher: &mut notify::RecommendedWatcher, path: impl AsRef<Path>) -> io::Result<()> {
95 |         watcher.unwatch(path).map_err(notify_to_io_error)
Some errors have detailed explanations: E0308, E0599.
For more information about an error, try `rustc --explain E0308`.
error: could not compile `linemux` due to 3 previous errors
warning: build failed, waiting for other jobs to finish...
error: failed to compile `vdash v0.6.3`, intermediate artifacts can be found at `/tmp/cargo-installaNeulF`
Caused by:
  build failed
edit: I see those errors already reported
I thought it might be good to have a room for vdash chat: https://matrix.to/#/#vdash:matrix.org (once there you can sign-in or sign-up if you aren’t already).
Collaborate (& Learn Rust If you like)
I don’t have much time for code now so happy for people to fork and chip in or take this forward yourself. I’ll help you learn along the way too when I have time.
To start, see how far you can get by forking the repo, building and setting up a development environment if you don’t have one yet. Then let me know what you’ve managed and anything you need help with.
@jpl can you or another mod make the OP a wiki so I can add the above.
Done. I think you can do that yourself now btw
No, I looked. I can do it early on but not indefinitely. THanks!
vdash v0.7.0 has been released and now works again with all test networks. There’s more work to do and I’m not sure how reliable what it shows you is yet but it is ready to try out.
Note:
  • nodes must be started with: RUST_LOG=sn_node=trace safe node join #etc
  • same when starting a local test network
  • logfiles must be in default format (text not JSON)
Feedback and help updating welcome in exchange for free Rust coaching (free and worth every penny :wink:). See the OP for more:
This makes me a @happybeing
Thx @happybeing
To update to vdash 0.7.1 (now shows device use and chunk storage space):
cargo install vdash
To update to vdash 0.7.3 (now shows system/node CPU load and resources):
cargo install vdash
on Ubuntu 20.04
willie@gagarin:~/projects/maidsafe/ELK$ cargo install dash
    Updating crates.io index
  Downloaded dash v0.1.0
  Downloaded 1 crate (4.6 KB) in 1.00s
  Installing dash v0.1.0
error: failed to compile `dash v0.1.0`, intermediate artifacts can be found at `/tmp/cargo-installJGScfL`
Caused by:
  failed to select a version for the requirement `clap = "~2.19.0"`
  candidate versions found which didn't match: 3.0.14, 3.0.13, 3.0.12, ...
  location searched: crates.io index
  required by package `dash v0.1.0`
arghh !!!
vdash not dash!
Replaced package vdash v0.7.1 with vdash v0.7.3 (executables vdash, vdash-crossterm)
Exelent work :slight_smile: makes not watching even more fun :slight_smile:
Some issues for anyone wanting to learn a bit of Rust while helping out with vdash:
There’s also some relatively simple refactoring to do, but the things I’ve made issues should be more fun because they are enhancements, rather than refactoring.
vdash 0.8.0 is available, to update:
cargo install vdash
This has minimal changes but should once again display some useful information taken from the logfiles. I’ll be interested if anyone tries it out, to tell me what is still not displayed as I’ve done very little testing. Also useful if you tell me what it does seem to display correctly! I’ve seen it show ‘role’ (e.g. ‘Elder’), PUTS an ERRORS.
For newbies or general information about vdash, see the OP
seems reasonable…
I am assuming the errors are coming from the faceful of OTLP errors that are getting spewed everywhere for now.
THis is with the release from a day or so back, I am not on the latest release yet - and if I was, I believe safe node run-baby-fleming would not work as expected?
Thank you @happybeing - much appreciated
A little more detail…
On a std 11 node baby-fleming, every node is reported as an Elder of age zero. I am unsure if this is all or partially down to vdash.
The chunk bar top centre/right always shows 100%, however the storage figure next to it looks plausible.
Role appears as always Elder, Age is zero and no values for Name and Section. But I cant remember how much of this worked last time anyway. ISTR Role and Age being accurate though…
Values for Device Space Avail and Free are all zero and the Load values are also zero.
You seem to have the same results as I did but only ran briefly, put a handful of files. Let’s see if anything improves with a split and running for longer. I think some more info should start to be shown, so let me know if you see anything improve.
I’m not sure if the ‘run-baby-fleming’ issue is real or not. I did the install using the MaidSafe script and manual install of the relevant node version but can’t see how the problem would arise looking at the source. So :man_shrugging:
from latest release first 7 are reporting as elders
OK I will kill this and pull and build the latest. Then I’ll try to run 40 nodes with baby-fleming so I should get a split and let that run overnight.
