Vdash - dashboard for Autonomi nodes
For me it is displaying everything except Storecost and RAM, as before those updates.
If you run many nodes there is a trick to see how many is active. If example Vdash shows around 70-80/180 nodes active, then choose a node in the list, click enter to see details, wait maybe 10-20 seconds, click enter again and then it will show the correct number example 176/180 or something similar.
Cool.
I just started 12 nodes at one go, and saw 100% CPU for a while - possibly between 1-3 minutes. Few months ago, when I last used Vdash, this would have led some shunning. Now, nothing! Nodes just seem to work without problems.
I look forward to being able to easily roll custom nodes.
If you get the chance to take a look, It is getting a little harder to view earnigns on Vdash at the moment. :slight_smile: :heart:
vdash v0.19.3
I’ve published v0.19.3 which is a quick hack to show higher earnings.
To install/update (after installing Rust):
cargo install vdash
If you have a problem try rustup update and if that fails, see the OP / vdash README.
New look…
Thanks, works great!
Does Vdash work with the latest release?
It shows 5/6 nodes as stopped 1/6 Connected, and Launchpad shows every node as running.
As far as I know yes, but some stats may have been lost. I saw similar yesterday in vdash, some saying stopped others looking ok.
I’m now unable to start nodes at all so we need to wait while things settle down.
Yes I have the same thing - I reset and tried again a few times in a panic but it still says ‘stopped’ and I assumed / hoped as you say @happybeing that it was just something to do with the stats.
Most of my nodes say ‘Stopped’ but they very clearly aren’t. I think it’s just that with the network not being very active the log entries are sometimes too far apart for Vdash to think they are running.
I’d agree with that
This shows 28 nodes only 7 of which have ever seen a PUT, let alone have an actual record stored
Minor update to v0.20.0:
  • use ANT rather than EMAID pricing from your chosen API (Coinmarketcap or CoinGecko are supported. See vdash --help)
  • more squashing refs to ‘safe’ and replacing with ‘ant’
As always, to install or update:
cargo install vdash
But get Rust first as described in the OP.
