Definitely! But I meant using auto-generated key material in addition to a user-supplied passphrase; it’s as secure on your own computer as it is now (with only the user-supplied entropy), but more secure when attacked from other devices.
IMHO the only valid reason not to use any auto-generated entropy is that hardware can fail and you don’t want to rely on it; I think the design decision here is that you want safenet to be hardware-independent.
This post is created as a continuation of another one which I posted in an inappropriate topic.
Current topic is exactly the one that deals with the problem and after reading it, I think there is a majority of people that have expressed a preference for not using 2 passwords:
During a short period of time a name + password pair was implemented, but then it has been changed to usage of 2 passwords. And worse: not only this has been done in the front end (HMI of the launcher) but an evolution made in core prevents any change of this choice in the front end: now the location of the session packet derives exclusively from the first element which forces it to be a password to avoid collisions between users. Initially the location depended on both elements so 2 different users could pick the same name for the first element (call it the way you want: common name, pet name, friendly name …) but this evolution blocks completely this possibility.
So current implementation forces usage of 2 passwords but I think that the choice should be unblocked at the core level and the launcher HMI should be modified so that each one could make his/her own choice: use 2 passwords or use a name and a password. This could be done for example with a check box indicating that we want to use a common name for the first element and which deactivates the password strength control on it (and possibly reinforces it on the second element).
With this solution everyone would be happy: for example I could use a common name corresponding to the category of account for the first element (finance, travels, music …), but this choice is not imposed and other people could use 2 passwords instead (with strength verification on both of them). And anyone could even use both possibilities, for example I intend to take the latter choice for some hidden accounts.
I agree that the existing system is relatively unwieldy for users, but I would prefer a single robust and easy to use/understand system rather than adding options that I think will complicate it further.
I agree it will be important to have a friendly name for each account, but this doesn’t have to be part of the login - I suggested elsewhere having this as a setting within account metadata, which could be accessed and displayed (and edited) by apps. So that’s another option.
One question is: do we need two passwords?
If we do, how do we make this unusual scheme as usable as possible, while ensuring users remain secure.
If not, then can we make the system intuitive without losing security and creating difficulties with clashing friendly names.
I don’t think either is easy to solve. Both have implications for implementation, usability and security in their different ways.
Good to raise this because it’s important - one of the most crucial factors in initial impressions and overall usability.
The preference of many people (and mine) is to have one name + one password. But Maidsafe sees benefits in having 2 passwords, so I proposed an option to please everyone.
I agree that this option is a complication, but it’s only one check box whose label has to be carefully worded to make things clear. Besides it doesn’t impact the robustness of the product because it’s only a matter of HMI and the data flow remains basically the same: 2 elements sent to core that transforms them into the 3 legacy elements (keyword, pin, password).
