For those who have the test net up and running, what is it looking like? I am really curious!
Cool to hear it is splitting and thanks fo reporting!
How about changing default node storage capacity to something very small? Shouldn’t that trigger the “join allowed” behaviour and all the rest?
Exactly. More precisely I set it to a negative number (-1.0) to be sure to always trigger this behavior.~
EDIT: I misread your proposal. What I did is setting the max storage ratio to a negative value:
diff --git a/src/capacity/rate_limit.rs b/src/capacity/rate_limit.rs
index 04d930740..435d5b87c 100644
--- a/src/capacity/rate_limit.rs
+++ b/src/capacity/rate_limit.rs
@@ -12,7 +12,7 @@ use sn_data_types::{Money, PublicKey};
const MAX_CHUNK_SIZE: u64 = 1_000_000;
const MAX_SUPPLY: u64 = u32::MAX as u64 * 1_000_000_000_u64;
-const MAX_NETWORK_STORAGE_RATIO: f64 = 0.5;
+const MAX_NETWORK_STORAGE_RATIO: f64 = -1.0;
/// Calculation of rate limit for writes.
pub struct RateLimit {
Additionally I did this:
diff --git a/src/node/node_duties/network_events.rs b/src/node/node_duties/network_events.rs
index b15ef29d1..3db9d75a3 100644
--- a/src/node/node_duties/network_events.rs
+++ b/src/node/node_duties/network_events.rs
@@ -91,7 +91,7 @@ impl NetworkEvents {
.into();
// Switch joins_allowed off a new adult joining.
- let second: NodeOperation = SwitchNodeJoin(false).into();
+ let second: NodeOperation = SwitchNodeJoin(true).into();
Ok(vec![first, second].into())
} else {
trace!("New node has just joined the network and is a fresh node.",);
In MemberJoined
routing event.
Maybe in the future iterations we should have two kinds of testnets, Bones and Meat:
Bones would be with very small storage per node and help to find out just how the structural evolution of the network etc. goes.
Meat would be with large / normal sized vaults and help to see how the contect flows in and out.
Looks good… just works for me… I was trying to upload some random files to push over the 50MB limit attempting to trigger memory issue but in error spawned 1GB files instead… and it’s just working away putting them… still working but I’m expecting it will complete.
What I haven’t done as above is seen safe join add another node.
So, wonder at this:
looks perhaps like hacking at config or code that’s beyond me to guess at.
vdash as above is useful to watch the node size increase.
The try it and see is simple:
curl -so- https://sn-api.s3.amazonaws.com/install.sh | bash
safe auth install
safe node install
# or is already installed then:
safe auth update
safe node update
safe node run-baby-fleming
safe auth start
safe auth create --test-coins
safe auth unlock --self-auth
## ready to put files.
## stop with
safe node killall
safe auth stop
Note that I never do that, and I always compile from source.
Not every one can do this and very often the repos are not in a stable state, but its a general safety rule that I impose to myself.
You trust the source but not the install from the same author?
Compile and validate is a useful tactic for checking real world binaries are not tampered with but this is testnet. Unless you have an odd bespoke system that needs compile, it just strikes as extra work… I take it if it works that the compile is not a factor in testing.
Also, the point above is just to illustrate how simple it is… we need as many people prodding it as possible.
There is a long unknown path from Maidsafe source files to the downloaded binaries. This path transits on docker containers, Github servers and AWS servers I cannot control.
I agree with this. But the complex way is my personal choice.
Sure… if you’re doing that, I wonder if it’s possible and useful to confirm the sha256 on the release pages of github like https://github.com/maidsafe/sn_api/releases/tag/v0.17.0
though those are suggested as .zip and .tar.gz - I don’t know if a compression necessarily does create the same signature from sha256 or if that’s just to validate the download.
So, I wonder the timeline is less useful … wishing that was a tail of the errors that it seems to have counted.
One of the nodes then showing as having counted three errors… so, curious, I grep for errors but cannot see what those three errors were. What I do see is a 1000 “Error Data(DataExists)” … but I don’t know if that’s just a noting that some duplicate was being put and that counts as an error.
So, this gives no result… unclear then what vdash is counting as errors then… I’ve not studied the log to know if there’s more variety…
$ grep 'Error' ./sn_node.log | grep -v 'CmdError' | grep -v 'DataExists'
but just double checking grep and case, I found one “error” = Logic error “Currently not an Elder”
$ grep 'error' ./sn_node.log | grep -v 'CmdError' | grep -v 'DataExists'
[sn_node] INFO 2020-12-29T18:42:53.258360056+00:00 [src/node/mod.rs:229] unimplemented: Handle errors.. Logic error "Currently not an Elder"
Try grep ERROR
. It is logging error logs rather than a word in the message part of the log.
Glad you’re poking aground with vdash
. It’s very raw at the moment but if you can keep a list of ideas, issues and suggestions that would be helpful.
I’m not sure what will be the most useful now, will also be the most useful once the network is live.
It could also do with a new name folks!
Some nodes show no errors.
Some though have many instances of WriteError(ConnectionClosed(TimedOut))
[sn_node] ERROR 2020-12-29T23:31:57.463320378+00:00 [src/node/elder_duties/key_section/client/client_msg_handling.rs:209] There was an error sending client message on the stream: WriteError(ConnectionClosed(TimedOut))
I shall sleep and see if it’s completed tomorrow regardless of those… though the 3.3GB I threw at it might prove too much.
I don’t know the cost to implement it and it would be useful.
But AFAIK none of these commands verify the sha256 checksum:
safe auth install
safe node install
safe auth update
safe node update
Note that these commands download the compressed assets.
This is an error I get occasionally on unlocking a previously created safe and trying to upload a folder. Anyone else seen it?
Safe unlocked successfully
Authorising CLI application...
Waiting for authorising response from authd...
Safe CLI app was successfully authorised
Credentials were stored in /home/user/.safe/cli/credentials
[user@user]$ safe files put ./to-upload/ --recursive
[2020-12-29T23:48:50Z ERROR sn_client::client::transfer_actor] Error receiving SignatureShare:
Unexpected: CmdError received:
Transfer(TransferValidation(Unexpected("Logic error \"Key does not exist among locks.\""))) -
ClientError::Unexpected::{"CmdError received:
Transfer(TransferValidation(Unexpected(\"Logic error \\\"Key does not exist among locks.\\\"\")))"}
I believe this would require deterministic builds (as mav was investigating on the dev forum)
Everyone here at MaidSafe wishes you a Merry Christmas and a Happy New Year. May 2021…
Many Happy Returns. I think ‘May 2021’ is a hint…
Just tinkering with a new unencrypted drive that is then necessarily much faster.
I can’t see that node join is working and safe networks
and safe networks check
doesn’t seem to show detail of “my-network” and the config file isn’t there for a simple fix for something close to
'my-network' network connection information from '~/.config/sn_cli/networks/my-network_node_connection_info.config'
So, stuck getting more than the default 11.
@happybeing I’ve only just spotted there is a [Node Log] element on vdash at the bottom as that is not apparent without the terminal being maximized… I wonder some toggle for turning off the Timeline stated to the right of [Timeline - 1 second columns][hide with T] would help trip people into seeing it… Node Log is most interesting to see.
Mods - please move to existing thread if you feel this unworthy of a new topic At last I have a little time to start getting into this properly. I have 3 machines that can all run local testnets just fine - well they start, files can be PUT and then retrieved with GET and @happybeing’s vdash tells me they are working - sometimes quite slowly but they work. Now I want them to talk to one another, so as a first step I edited ~/.safe/node/node_connection_info.config to read “192.168.1.100:1200…
Just linking to this problem here. I have not really worked at this again yet but think I could move forward if I knew
where to edit *node_connection_info.config
how to actually use the -endpoint option. If not provided, https://localhost:33000 is assumed
Could some kind person please paste the commands used to set up a auth daemon on one LAN machine and then connect to that process from another machine on the LAN?
Cos mostly I get
➜ ~ safe auth --endpoint https://mir.wiraintld:33000 status
Sending request to authd to obtain a status report...
[2021-01-03T20:25:59Z ERROR safe] sn_cli error: [Error] AuthdClientError - Failed to establish connection with authd: [Error] ClientError - Failed to establish connection with remote QUIC endpoint: the cryptographic handshake failed: invalid certificate: UnknownIssuer
If I try to use a IP rather than a FQDN then I get
➜ ~ safe auth --endpoint https://192.168.100.6:33000 status
[2021-01-03T19:47:47Z ERROR safe] sn_cli error: [Error] AuthdClientError - Failed to establish connection with authd: [Error] ClientError - Failed when attempting to create a connection with remote QUIC endpoint: invalid DNS name: 192.168.100.6
I see this when tailing the sn_authd.log from mir.wiraintld (192.168.100.6)
INFO 2021-01-03T20:25:05.759122309+00:00 [sn_authd/operations.rs:144] Running authd instance from executable at "/home/willie/.safe/authd/sn_authd"
INFO 2021-01-03T20:25:05.759178741+00:00 [sn_authd/operations.rs:150] authd instance starting (PID: 17562)...
INFO 2021-01-03T20:25:05.759269325+00:00 [sn_authd/operations.rs:178] Initialising SAFE Authenticator services...
INFO 2021-01-03T20:25:05.759813946+00:00 [sn_authd/authd.rs:84] Listening on 192.168.100.6:33000
INFO 2021-01-03T20:25:59.092502673+00:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/quinn-0.6.1/src/connection.rs:228] drive; id=0
INFO 2021-01-03T20:25:59.092763739+00:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/quinn-0.6.1/src/connection.rs:228] drive; id=0
INFO 2021-01-03T20:25:59.096415035+00:00 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/quinn-0.6.1/src/connection.rs:228] drive; id=0
sn_authd has a --listen parameter that is supposed to specify the address the daemon listens to.
But I get the same error as yours, even locally.
SNAUTHD defined on my eth0 address:
ubuntu@V0:~$ grep SNAUTHD /etc/hosts
172.30.64.173 SNAUTHD
ubuntu@V0:~$ ping SNAUTHD
PING SNAUTHD (172.30.64.173) 56(84) bytes of data.
64 bytes from SNAUTHD (172.30.64.173): icmp_seq=1 ttl=64 time=0.018 ms
64 bytes from SNAUTHD (172.30.64.173): icmp_seq=2 ttl=64 time=0.039 ms
64 bytes from SNAUTHD (172.30.64.173): icmp_seq=3 ttl=64 time=0.040 ms
^C
--- SNAUTHD ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2050ms
rtt min/avg/max/mdev = 0.018/0.032/0.040/0.010 ms
Launch sn_authd and try to connect safe to it:
ubuntu@V0:~$ ./sn_authd start --listen htpps://SNAUTHD:33000
Starting SAFE Authenticator daemon (sn_authd)...
sn_authd started (PID: 10074)
ubuntu@V0:~$ ./safe auth status --endpoint https://SNAUTHD:33000
[2021-01-03T22:05:50Z ERROR safe] sn_cli error: [Error] AuthdClientError - Failed to establish connection with authd: [Error] ClientError - Failed to establish connection with remote QUIC endpoint: the cryptographic handshake failed: invalid certificate: CertNotValidForName
sn_authd log is also similar to yours:
INFO 2021-01-03T23:05:39.414947150+01:00 [sn_authd/operations.rs:144] Running authd instance from executable at "/home/ubuntu/sn_authd"
INFO 2021-01-03T23:05:39.414975050+01:00 [sn_authd/operations.rs:150] authd instance starting (PID: 10074)...
INFO 2021-01-03T23:05:39.415024650+01:00 [sn_authd/operations.rs:178] Initialising SAFE Authenticator services...
INFO 2021-01-03T23:05:39.415468046+01:00 [sn_authd/authd.rs:84] Listening on 172.30.64.173:33000
INFO 2021-01-03T23:05:50.967147197+01:00 [/home/ubuntu0/.cargo/registry/src/github.com-1ecc6299db9ec823/quinn-0.6.1/src/connection.rs:228] drive; id=0
INFO 2021-01-03T23:05:50.967210096+01:00 [/home/ubuntu0/.cargo/registry/src/github.com-1ecc6299db9ec823/quinn-0.6.1/src/connection.rs:228] drive; id=0
INFO 2021-01-03T23:05:50.967573893+01:00 [/home/ubuntu0/.cargo/registry/src/github.com-1ecc6299db9ec823/quinn-0.6.1/src/connection.rs:228] drive; id=0
Thats what I get for not reading the source…
@bochaco Should this not be in --help?
sn_authd 0.0.13
bochaco <gabrielviganotti@gmail.com>
SAFE Authenticator daemon subcommands
USAGE:
sn_authd <SUBCOMMAND>
FLAGS:
-h, --help Prints help information
-V, --version Prints version information
SUBCOMMANDS:
help Prints this message or the help of the given subcommand(s)
restart Restart a running sn_authd
start Start the sn_authd daemon
stop Stop a running sn_authd
update Update the application to the latest available version
