TEST5 (AKA destructive test) - is now running
Since I had a new publicid registered, I thought I’d upload some data.
Uploaded the 5mb.safenet index.html that is … to 5MB… to http://test.smoke-y.safenet
OMG it was fast… I blinked and it was done.
Something about that file existing perhaps makes the chucks simple to upload. The download was quick too…
I don’t know why that was so quick to upload, as I’d have expected that it would have made chunks different to the original instance. Perhaps there’s some compression before encryption?? Might be worth better understanding the apparent difference though.
Yes, it gets compressed, and of course “…” is very compressible. I also realized that only after I had created the file. Should replace it with random data.
And also the chunks get created only once, although at the moment you still have to upload them with your Put request.
I’ve got the same error with all previous launcher versions , I’ve downloaded the launcher zip from
opened it on my windows 7 64bit computer and double clicked the “safe_launcher.exe” , waiting and still same error “trying to connect with safe network” on the top status bar … why ?
I think it might have to do with the fact that I’m connected to an office internet , but I have permissions to view web pages like google and youtube with no proxy .
Make sure you use the most recent version of the launcher located here.
Will test this on Tuesday, 10x !
Please consider joining the latest iteration of the community1 network: Community1 test network 18-hour run
Meanwhile Test5 is still running and likely putting that through its paces will do more use.
I’d be surprised if the Bleeding Edge compile of the latest patchwork of updates did just work before it’s put forward as something that can work together. Come the alpha, I’d expect each tweak on a repository more likely to not break the whole but at this stage perhaps it’s not there yet and liable to not work in alsorts of ways?
Stopped http://vault-count.safenet/ (the site is not deleted but the result is frozen at that date: 105 vaults at 2016-07-15 21:16:31 UTC).
Added http://mystats.safenet/ which replaces the frozen site and http://safe-galaxy.safenet/ which displays a galaxy of stars representing nodes in the xor space. You can find your own vault by using vault_coordinates utility and passing the id of your vault to it.
I will migrate these sites to test 6 network, I just don’t know how much time the migration will take.
TEST5 network seems to have been terminated.
Because Test 6 started. SAFE Network - TEST 6
