I was just messing around… and it worked! ![]()
safe://💩
safe://💩
i made a site that demos off a portion of the safe js api
safe://safedemo.jam
plan to release topic with video explaining everything next week
Very nice demo, thank you
Only thing I was able to get from this site is “Invalid handle” errors.
upd. Browser restart fixed that problem.
upd2. GET attempt shows error:
D:\SAFE Browser\resources\app\node_modules\pauls-electron-rpc\lib\import-api.js:203 Uncaught (in promise) Error: Core error: Routing client error → Requested entry not found
at onCbReply (D:\SAFE Browser\resources\app\node_modules\pauls-electron-rpc\lib\import-api.js:203:19)
at EventEmitter.onIPCMessage (D:\SAFE Browser\resources\app\node_modules\pauls-electron-rpc\lib\import-api.js:118:14)
at emitMany (events.js:127:13)
at EventEmitter.emit (events.js:201:7)
upd3. This site should be more fool-proof.
upd4. Deleted files are not deleted from the list, but just failing to show up with GET.
The video would be great @Joseph_Meagher, I’ll keep an eye out for that one.
In order to use GET you have to copy and paste the filename e.g. image.jpg into the ‘Select your file’ space above the FILE button.
Thanks, I understood that already.
But it is better to remove that edit box at all.
And make file selection in more user-friendly way.
Agreed the GUI could be more user friendly, but it’s just a demo at this stage. Actually Delete isn’t working for me now, and no error in the console. Seems to be a bug @Joseph_Meagher .
It works only for contents (you can’t anymore view that file).
But not for metadata (file list).
Ah, ok - to avoid cluttering up this thread with bug reports - there are bound to be quite a few as it’s a prototype app - best to DM them to @joseph_meagher
Just a test
safe://home.sam
Hi intrz sorry for the late reply, try again on test 18 and see if you get the screen loading:
safe://test.webgl/Index.html
Still is not working, appears to be a problem with the SAFE browser on my computer.
It doesn’t appear your computer can support WebGL.
Click here for more information.
WebGL works in my other browsers. I tried downloading your site and running it locally in chrome and firefox, then it worked.
Did you do something to turn on WebGL support in the SAFE browser?
No nothing I know of, I wonder if its a security issue but I would expect not. I think we should post a thread see if others have the same issue. I’ll try that now.
You know sites for test 19?
Search the Test 19 Dev Update topic for posts containing safe://
If you make a list, maybe create a topic for it like this one ![]()
